Can anyone identify where this may have came from?
Discussion in 'General Tundra Discussion' started by CAM1794, Apr 16, 2019.
  1. Apr 16, 2019 at 7:44 PM
    CAM1794
    CAM1794 [OP] New Member
    Chad
    2017 MGM 1794
    Can anyone identify where this may have came from? I found it in my driveway this afternoon and assume it must have came from my 2017 Tundra or the wife’s 2018 4 Runner. I know it’s a long shot but figured I would ask the gurus!
  2. Apr 16, 2019 at 8:41 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    This looks like one of the bolts that hold your Tundra bumper in position.
    CAM1794[OP] and Watt maker like this.
  3. Apr 16, 2019 at 9:27 PM
    CAM1794
    Chad
    2017 MGM 1794
    The only mod was a 4” lift kit about 4000 miles ago and I had the re torque done after 500 miles. I will check bumper tomorrow and all the lift components. Thanks.
    Watt maker likes this.
  4. Apr 16, 2019 at 9:42 PM
    Aerindel
    Aerindel New Member
    Montana
    I don't know, but those kinds of flanged nuts are indeed very common on vehicles and not so much anywhere else so it likely is from a car rather than just some random hardware from a bookshelf or something.
    Black Wolf likes this.
  5. Apr 16, 2019 at 10:48 PM
    Bheid
    Bheid It's not a toy, it's a Toyota.
    Doug
    Indiana
    2016 Black Tundra SR5
    Fab Fours Black Steel Elite front bumper Rhino Lined Bed Century Truck Cap Bridgestone KO2 tires K Source tow mirrors Blackvue Dashcam
    I second the bumper mount nut.
  6. Apr 17, 2019 at 1:05 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Got anything for scale in that photo? A quarter or something would be helpful.
  7. Apr 17, 2019 at 4:54 AM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    Flanged nuts I can name a few: Leaf spring forward and rear mounts, U bolts, and rear shock bottom nut. Hope that helps and good luck, better to look over everything and retorque while you are checking around the chassis
  8. Apr 18, 2019 at 10:03 PM
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    WHEELS MotoMetal 962’s 20x12 -44 offset SUSPENSION Energy Suspension Bump Stops Pro Comp 6” Lift Kit Body mount chop - BMC King Front Shocks with Remote Resi King Rear Shocks with Remote Resi Toyota TRD Rear Sway Bar Pro Comp ProRunner UCA's Toytec Adjustable Lift Shackles DRIVETRAIN Energy Suspension Rack Bushings (progress) TIRES Fuel Mudder M/T 37x13.5x20 EXTERIOR BulletLiner Truck Bed Liner PerformanceAccessories 3" Body Lift Performance Accessories Gap Guards Go Rhino Dominator D2 Nerf Bars Undercover SE Tonneau Cover AUDIO JL Audio HD900/5 JL Audio HD750/1 Dynamat Extreme Closed Cell Foam Install (progress) JL Audio Stealthbox Pioneer SPH-DA120 (AppRadio 4) INTERIOR Black Suede Headliner Carbon Fiber Vinyl Wrap Suede Door Panel Insets Steering Wheel Cover AJT Design Shift Knob AJT Design Key Fob LIGHTING Door panel accent lighting Swapped all interior lights to LED Morimoto Custom Retrofit Headlights Morimoto XB LED Fog Lights COSMETIC Debadged All Emblems Powdercoated ProComp Lift Parts Envy Grille (progress) G2 Brake Caliper Paint - Gold Toyota Fender Flares PERFORMANCE Unichip programmer StopTech Drilled and Slotted Rotors Borla Turbo XL Muffler K&N Air Filter STORAGE Rotopax 4 gallon fuel pack Diesel Power Hang A Hitch TOWING Elevated Suspension Tow Brackets Razor Auto Aluminum Shackles ELECTRICAL Optima Yellow Top Battery
    The bottom shock mount nut is flanged like that too.
    Pudge likes this.
  9. Apr 19, 2019 at 6:30 PM
    CAM1794
    Chad
    2017 MGM 1794
    I have crawled all under the truck and see several similar bolts. I can’t see where any are missing however. I guess I will just drive until something falls off. Thanks for all the input!
  10. Apr 19, 2019 at 7:10 PM
    airosey
    East TN
    I’d up my car insurance amounts :rofl:
  11. Apr 19, 2019 at 7:29 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    It's a nut, not a bolt.
    Those are used un a few locations that I can think of. Definitely lower shock mounts and maybe bumpers or sway bars.
    CAM1794[OP] likes this.
  12. Apr 19, 2019 at 7:37 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Amazon Prime Mercedes sprinter van been in your driveway recently? :1up:
  13. Apr 19, 2019 at 7:51 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Do you have a TRD pro skid installed? That’s the same flange nut that goes to the two most rear bolts. The ones that go through the crossmember.
  14. Apr 19, 2019 at 7:55 PM
    CAM1794
    Chad
    2017 MGM 1794
    No TRD skid plate. I will be back under there tomorrow installing Budget SS exhaust from the group buy and will look around again.
  15. Apr 19, 2019 at 8:11 PM
    TheBeast The Beach
    check rear shocks if any missing
