Camper shell clamps constantly loosen
Discussion in 'Tonneau Covers, Caps and Shells' started by rock01, Apr 26, 2023.
  1. Apr 26, 2023 at 5:06 AM
    rock01
    rock01 [OP] New Member
    Rich
    2006 Tundra SR2 2wd
    front hitch, timbrens, camper shell
    I have a heavy leer fiberglass shell for my DC 1st gen with toolboxes on each side. It came kind of messed up, probably from overloading the toolboxes and I have probably continued that habit so there is definite spreading on the bottom edges, particularly at the back window.
    I have tried every clamp I can order and have added locktight as well. But the clamp on the one corner still loosens and falls off, leaving me with only 3 holding it on the bed. I have a plan to remove the stake pockets and add screws there that drill into the fiberglass to hold it down. Any ideas? I love the camper shell and can't live without the toolboxes.
  2. Apr 26, 2023 at 6:06 AM
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    I thought the shop that installed my canopy said you have to tighten the clamps from time to time, though I haven't done a very good job keeping up with that and I haven't had any fall off yet. :fingerscrossed:
  3. Apr 26, 2023 at 6:09 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Does the screw come out the other side of it where you can out an extra lock nut?
    rock01[OP] likes this.
  4. Apr 26, 2023 at 6:11 AM
    rock01
    Rich
    2006 Tundra SR2 2wd
    Yeah, I see that as tire shops telling you to re-tighten lugnuts at 1k miles, too. This shifts the liability onto you. I have run camper shells on 2 other trucks and never seen any loosen except for this one which I know is caused by the fiberglass spreading which then vibrates and shakes off the clamp very quickly. On one of my other trucks I take the shell on and off 3-4 times a year to haul gravel and it has never loosened. That one is an aluminum contractor shell and is by far, my favorite. Super lightweight and you can't destroy it. Just have to accept that it isn't painted and will never look as nice.
  5. Apr 26, 2023 at 3:30 PM
    rock01
    Rich
    2006 Tundra SR2 2wd
    That is a great idea! May try that with locktite as well!
  6. Apr 26, 2023 at 3:37 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Double J style clamps? Three options: 1) try flipping them. 2) Lock washers. 3) Tack weld the nuts.
  7. Apr 26, 2023 at 3:41 PM
    rock01
    Rich
    2006 Tundra SR2 2wd
