Call me crazy...
Discussion in 'General Tundra Discussion' started by Hartsy8, Jul 6, 2020.
  1. Jul 6, 2020 at 5:47 PM
    Hartsy8
    Hartsy8 [OP] Resident Hockey Guy
    Max
    2020 MGM 1794
    Hey all, long time listener, first time caller.
    Pulled trigger on a 2020 1794 today. When I took it on the test drive it had 6 miles on it.. only 6! We went on the highway and had to give the engine some juice to avoid a not so nice driver on the merge. How much is it typical to baby the engines in their infancy? Will getting up to that 4-5k rpm range on a merge matter? I know the break in rule of thumb is some kind of general restriction for 500 miles. Just want to know what to look out for if I have cause any problems on my truck... that has 6 miles. ha! Thanks.
    -Max
  2. Jul 6, 2020 at 6:02 PM
    ezdog
    ezdog New Member
    Gateway To The West
    You are Crazy!
    NewImprovedRon and GODZILLA like this.
  3. Jul 6, 2020 at 6:06 PM
    Hartsy8
    Max
    2020 MGM 1794
    Good to know I am not the only one who thinks so :p had to confirm. Don't have to baby them that much?
  4. Jul 6, 2020 at 6:08 PM
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    You’ll be fine. Just take it easy the first few hundred miles. Occasional hard acceleration due to traffic conditions won’t hurt anything.
    Congrats on the new truck.
    GODZILLA likes this.
  5. Jul 6, 2020 at 6:10 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Nothing to do with that really.
    You asked to be called Crazy plain and simple.
    These trucks are not china dolls so easily broken though so I would avoid driving for hours at high RPMs but normal pattern driving to avoid the insane should be just fine.
    I imagine the owners manual advises exactly how the suggest you drive during the break in period too.
  6. Jul 6, 2020 at 6:14 PM
    Hartsy8
    Max
    2020 MGM 1794
    Thank you. You guys know your stuff. Always puts the mind at ease. Ill throw up some pics in another post shortly.
    Black Wolf likes this.
  7. Jul 6, 2020 at 6:42 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Congrats and Welcome.
    Hartsy8[OP] likes this.
  8. Jul 6, 2020 at 7:20 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Howdy from DFW and :worthless:
  9. Jul 6, 2020 at 9:33 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    I did a 200ft burn out and a figure 8 out of the dealer lot 170,000 miles ago...it still lives to tell the tale.
    :burnrubber:
  10. Jul 7, 2020 at 5:41 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    New owner's worry about hurting their baby, but in fact, most never keep a vehicle long enough to see reduction in service life. If you plan keep the truck 30 years, or sell/trade a maximum-value clean used truck, then probably best to follow their recommendation to "take it easy" for the first few hundred miles. If there was real risk of owner-inflicted damage, not including running with no/low/dirty engine oil, then Toyota wouldn't offer an extended drive train warranty.
    Ideally, on any high-performance engine, good practice is to avoid sporty driving until engine oil temperature is stabilized at normal operating temperature. Since Tundra doesn't have an oil temp gage, you can use coolant temp, but run it a few minutes more before romping on it (oil temp typically lags coolant temp).
  11. Jul 7, 2020 at 5:58 AM
    blanchard7684
    blanchard7684 New Member
    I had a brand new, less than 100 miles 4runner, and had to pass a frac string. About 20 seconds at wide open throttle starting from 65 mph. lol. it was fine.
  12. Jul 7, 2020 at 6:27 AM
    Welcome from NY.
  13. Jul 7, 2020 at 6:30 AM
    LML 3500HD
    NewImprovedRon likes this.
  14. Jul 7, 2020 at 6:48 AM
    Congratulations and welcome.
  15. Jul 7, 2020 at 9:28 AM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    Cjames17 likes this.
  16. Jul 7, 2020 at 10:08 AM
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    welcome from the Bay Area, CA.
    from my homeboy Manual. he knows a lot about the Tundra. of course there are other methods especially from those that build and tune motors but imo you can never go wrong starting off with following Manual's guidance.
    pg 186 4-1.
    Before driving
    Breaking in your new Toyota To extend the life of the vehicle, observing the following precautions is recommended:
    ●For the first 200 miles (300 km): Avoid sudden stops.
    ●For the first 500 miles (800 km): Do not tow a trailer.
    ●For the first 1000 miles (1600 km):
    • Do not drive at extremely high speeds.
    • Avoid sudden acceleration.
    • Do not drive continuously in low gears.
    • Do not drive at a constant speed for extended periods.
