@Cali Raised Led Lighting *Great Affordable LED Bars And Pods* PRICING 15%
Discussion in 'Lighting' started by Caliraisedled, Aug 30, 2016.
  1. Dec 30, 2018 at 9:40 AM
    #271
    ccdawnpatrol
    ccdawnpatrol New Member
    Salt Lake City, UT
    2017 SR5 MGM CM 4x4 5.7L
    Never got one...darn. Bu we are official, moving to Utah March 1st.
    Sunnier[QUOTED] likes this.
  2. Jan 11, 2019 at 10:15 AM
    #272
    Caliraisedled
    Caliraisedled [OP] New Member
    Jake
  3. Jan 14, 2019 at 12:35 PM
    #273
    Caliraisedled
    Jake
    Stormtrooper81 likes this.
  4. Jan 22, 2019 at 11:46 AM
    #274
    Caliraisedled
    Jake
  5. Jan 22, 2019 at 12:27 PM
    #275
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    Any sales going on soon? Interested in fog mounts and pods combo
  6. Jan 22, 2019 at 12:43 PM
    #276
    Caliraisedled
    Jake
    As of right now, I don't think any are coming up. But we are offing 5% off on top of our website if you subscribe to us.
    Let me know if you have any other questions.
    Thanks
    ccdawnpatrol likes this.
  7. Jan 22, 2019 at 12:57 PM
    #277
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    Do you have a light bar for the grille?
  8. Jan 22, 2019 at 1:03 PM
    #278
    Caliraisedled
    Jake
  9. Jan 22, 2019 at 1:30 PM
    #279
    Pat
    Pat Sorta-new Member
    Pat
    Virginia Beach
    '16 MGM SR5 DC
    CAI, 5100's
    Do you know if your 32" Slim Single Row Bar would fit inside the hood bulge for 3rd gens?
  10. Jan 23, 2019 at 3:14 PM
    #280
    Caliraisedled
    Jake
    I am not positive we do not make specified brackets for it. Let me know if you have any other questions.
  11. Jan 23, 2019 at 3:20 PM
    #281
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Super easy install and great product...Thanks again @Caliraisedled
    jewsNbrews and Caliraisedled[OP] like this.
  12. Jan 29, 2019 at 11:33 AM
    #282
    Caliraisedled
    Jake
    Thanks for choosing us! The Truck looks great! Let me know if you need anything else.
    ccdawnpatrol and Major[QUOTED] like this.
  13. Feb 14, 2019 at 1:31 PM
    #283
    Caliraisedled
    Jake
    Show some LOVE to your Tundra this valentines day with our 10% off code "LOVE"
    https://caliraisedled.com
    Sale ends tonight
    Thanks
  14. Feb 21, 2019 at 1:57 PM
    #284
    Caliraisedled
    Jake
    jewsNbrews and Sunnier like this.
  15. Feb 27, 2019 at 7:34 AM
    #285
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Received your lower bumper mounts the other day. I've been thinking about the hidden grille brackets too. Your website says that they will work with most curved 42" light bars. I have a 2019 SR5 with the radar unit in the honeycomb grille's emblem. I've got a couple of questions. Does a curved LED bar touch or cause problems with the radar sensor sticking out toward the rear of the vehicle? Do your brackets work with a straight 42" light bar instead of a curved bar? If so, does a straight light bar cause any problems with the radar unit? Finally, do you have any pics of your kit being used with a honeycombed grille?
    Caliraisedled[OP] likes this.
  16. Apr 2, 2019 at 1:10 PM
    #286
    Caliraisedled
    Jake
    For the grille kit, it must be a 42" Curved LED bar and their will have no interference with the TSS safety sensor. Also I will see if I can find any pictures with the honeycomb grille on it.
    Thanks
  17. Apr 2, 2019 at 3:30 PM
    #287
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    I have the Honeycomb grill with the hidden mounts and TSS. Installed the 42in COmbo from CaliRaised
    Here are my findings...
    1) The actual mounting of the brackets was SUPER simple.
    2) I had some interference issues in the top mounting position. There is a small bracket/connector that goes from the grill to the engine bay that you have to disconnect to get the grill off. Well that connector location is right where the top light bar would go. You might be able to drill an additional set or homes about 3/4in below the existing top mount though. Part of your light might get blocked by the big "T" in the grill though
    3) I mounted my light bar below the emblem.. Using the top of the lower two hole sets, my bottom row was partially hidden by the grill surround. I ended up drilling a new set of holes about 3/4in ABOVE the bottom most mounting holes. Nothing blocked by the emblem and nothing blocked by the grill surround.
    Will try to get pics tonight
  18. Apr 9, 2019 at 7:56 AM
    #288
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    I installed the lower bumper 32" light mount recently. The hardest part was removing the three nuts on each side of the plastic bumper middle piece from the inside. I'm very happy with the mounts, and after a little fiddling with the interface between the actual light bar and the CaliRaised mounts (ended up putting a washer in between), the light bar is solid. Very happy!
    I used a 32" Quake LED Magma bar that throws 100% white light or 100% red light for creeping into hunting spots early.
    https://www.quakeled.com/product/32-led-light-bar-dual-row-magma-whiteamber-whitered-or-whitegreen
    Caliraisedled[OP] and jewsNbrews like this.
  19. Apr 10, 2019 at 3:19 PM
    #289
    Caliraisedled
    Jake
  20. Apr 15, 2019 at 7:55 AM
    #290
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    What are your TUNDRA LOW PROFILE DITCH LIGHT BRACKETS made out of? How thick is the metal?
  21. May 1, 2019 at 6:55 PM
    #291
    bmcdds
    bmcdds New Member
    CA
    2019 Barcelona Platinum
    @Caliraisedled Any Memorial Day specials going to happen?
    I'm looking for ditch lights, lights for sides and back of my Leitner ACS and possibly lower bumper bar if the sale is good!
  22. May 1, 2019 at 7:57 PM
    #292
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    Great question...I shall anxiously await the answer
  23. May 9, 2019 at 8:03 AM
    #293
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    CALIRAISED- what type and thickness is the metal you make the ditch light brackets out of?
    Rica25 likes this.
  24. May 13, 2019 at 8:26 AM
    #294
    TNTundra53
    TNTundra53 New Member
    Looking to fill the factory fog light spots on my 2012 CM any suggestions or other lighting suggestions? i was given a set of the topgear LED projectors and they do not put the light out that i would like them too.
  25. May 16, 2019 at 11:20 AM
    #295
    Caliraisedled
    Jake
    3/16th is the Thickness.
  26. May 23, 2019 at 4:26 AM
    #296
    Bongskie
    Bongskie Mucho LOCO
    2016 Black Crew
    6" Pro Comp Kit, Mayhem 20" rim, Toyo M/Ts
    Yeah< me too!
  27. May 29, 2019 at 2:16 PM
    #297
    Caliraisedled
    Jake
    Last Chance To Take Advantage of Our Memorial Day Sale... ENDS TONIGHT 5/29
    USE CODE " SUMMER2019"
  28. Jun 10, 2019 at 9:59 AM
    #298
    Caliraisedled
    Jake
    Here is a customer with our...
    2014-2020 TOYOTA TUNDRA HIDDEN GRILLE COMBO
    2014-2020 TOYOTA TUNDRA LOW PROFILE DITCH LIGHT COMBO
    2014-2020 TOYOTA TUNDRA LED FOG LIGHT POD REPLACEMENTS COMBO
    Check us out at www.caliraisedled.com
    BigTimeBolo likes this.
  29. Jun 13, 2019 at 7:22 AM
    #299
    Caliraisedled
    Jake
  30. Jun 21, 2019 at 6:59 PM
    #300
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
