Bumper spacers vs chopping for wheel clearance
Discussion in '2.5 Gen Tundras (2014-2021)' started by Allen.Tee, May 25, 2021.
  1. May 25, 2021 at 10:12 PM
    Allen.Tee
    Allen.Tee [OP] New Member
    2018 Cement Tundra TRD OR 4x4
    None, don’t know where to start.
    Bumper spacers vs chopping for wheel clearance. Which is better?
  2. May 25, 2021 at 11:45 PM
    snappy924
    snappy924 New Member
    Garrett
    Pasadena, California
    2017 Tundra Crewmax 4x2
    Bilstein shocks, Tembren bump stops,
    I added bumper spacers to avoid chopping away. If I ever sell her it won’t be an issue if I go back to stock. BP are cheap enough too
    Cg13055 and Allen.Tee[OP] like this.
  3. May 25, 2021 at 11:58 PM
    Allen.Tee
    @snappy924 You added them yourself or went to a shop?
  4. May 26, 2021 at 3:11 AM
    You can get the Coachbuilder spacers and install them yourself by doing 1 side at a time. What size wheels and tires are you trying to fit?
  5. May 26, 2021 at 3:59 AM
    snappy924
    Garrett
    A local shop installed them when I went with a 285 tire last month.
  6. May 26, 2021 at 5:02 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Don't chop when you can space it out. Spacer are expensive, people used stacks of washers to save $, I used these nuts from home depot. Less expensive than doing the washers, but gave same amount of clearance. Loosed up one side of the bumper 4 bts, took off the 4 bolts on the other side, had a friend hold the bumper and slid the nuts over the bolts then pushed bumper back on and do the other side. Year and half, no issues, can't even tell from the side either
    Allen.Tee[OP] likes this.
  7. May 26, 2021 at 12:35 PM
    Allen.Tee
    My goal is to get the wheels to poke out w/o any rubbing issues. Live in a condo, so my garage isn’t that so i can’t lift any higher
  8. May 26, 2021 at 12:37 PM
    Stock wheels and tires? Stock wheels are 60mm so you could run Spidertrax wheel spacers and shouldn't need bumper shims.
  9. May 26, 2021 at 2:29 PM
    Berdine
    Binghamton, NY
    33 12.50 18 18×9 +12 offset no lift,no rubbing, shimmed the front bumper and removed front mud flaps, the stance is perfect right now20200125_100514.jpg
    NumberOfTheDay and Allen.Tee[OP] like this.
  10. May 27, 2021 at 7:24 AM
    Allen.Tee
    @Berdine @Tundra234
    exactly like Berdines, perfect if not i’d probably go alittle more out. Thank you
  11. May 27, 2021 at 7:28 AM
    Allen.Tee
    @Berdine what bumper shims do you in stall?
  12. May 27, 2021 at 7:35 AM
    He just used nuts instead of shims.
    Berdine likes this.
  13. May 27, 2021 at 7:49 AM
    Allen.Tee
    Thanks guys, I’ve never been into cars/trucks till now. All this stuff is new to me and I appreciate the help!
  14. May 27, 2021 at 8:12 AM
    Cg13055
    Cg13055 @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    rather not cut it up
  15. May 27, 2021 at 1:13 PM
    Berdine
    Binghamton, NY
    @Allen.Tee I just used nuts, I posted a pic on the ones I used above. Alot of people use washers, but the nuts give same amount of space with less parts. Worked perfectly
