Bumper shims
Discussion in '2.5 Gen Tundras (2014-2021)' started by neirbot, Feb 5, 2019.
  1. Feb 5, 2019 at 8:22 PM
    neirbot
    neirbot [OP] New Member
    Anyone have a pic of their truck with 1/2" bumper shims installed? I ordered a set and I'm wondering how much of a noticable change they make to the front of the truck, if any at all. Thanks.
  2. Feb 5, 2019 at 8:28 PM
    conlons26
    conlons26 High speed dirt mobile
    Raleighwood, NC
    2018 Quiksand Limited CM
    King 2.5's, Toytec shackles, FN BFD 18", 295/70r18 NItto Ridge Grapplers, Dirty Deeds 8" SS, no more chrome, 17' pro grill, Husky mats, TRD Pro shifter + 15hp...
  3. Feb 6, 2019 at 2:41 AM
    I don't have a 3rd gen but on my 2nd gen you can't even notice with your eye that they are installed.
    15whtrd likes this.
  4. Feb 6, 2019 at 6:27 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    See my build page.
    15whtrd likes this.
  5. Feb 6, 2019 at 6:29 AM
    15whtrd
    15whtrd Mr. Blonde
    nlaroy likes this.
  6. Feb 6, 2019 at 6:32 AM
    neirbot
    Perfect thanks. Not sure how I missed that thread.
  7. Feb 6, 2019 at 6:42 AM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Thanks @15whtrd !
    OP let me know if you have questions. To me it is noticeable. But to everyone else prob not. But I did just install them last night. I think the only place they are noticeable is the wheel well.
    I had to hit them on with a hammer to get them to seat cause they were snug, but that's a good thing.
    15whtrd[QUOTED] likes this.
  8. Feb 6, 2019 at 7:07 AM
    neirbot
    @jmevis -- thanks. What lift/wheel/tire setup prompted you to install the bumper shims? Also, do you think it's necessary to remove the grill and surround? I've seen instructions out there that say to just remove the bumper itself.
  9. Feb 6, 2019 at 7:25 AM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Im to to go with 35x12.5r18 BFG KO2s. There are 4 bolts that hold the end caps to the bumper. In order for me to get to them I had to remove the cowl that is directly under the headlights. In order to remove those cowls, I had to remove the grill. Removing the grill is probably the easiest part of the install, but most scary since its pop clips.
    There are other ways to do this... Like removing the bumper from the bottom of the truck, But I didn't have a right angle air compress torque wrench. So I had to remove the bumper cover to get to the bumper bolt/nuts.
    GELCW likes this.
  10. Feb 6, 2019 at 7:37 AM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Oh also TRD PRO suspension, but I am installing the full CB kit which includes 1" lift up front with a shim and then 1.65" in the rear with the shackles. Stock TRD PRO wheels, with Bora 1.25 spacers. At least this is the plan at the moment.
  11. Feb 6, 2019 at 7:52 AM
    neirbot
    Ok that's helpful. I'm going with 275/65r20 (34") on +50 BBS wheels with a 2.4" lift, so I don't need quite the clearance you do. However I'd like to install these spacers (or maybe just 1/4" worth) rather than removing mud flaps or manipulating the liners.
  12. Feb 6, 2019 at 8:03 AM
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    CB sells them where they stack, so it was 2x .25" shims per side. It wouldn't be a problem to only use 1 per side.
  13. Jan 11, 2020 at 4:49 PM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    19, Limited, CrewMax, Off Road, Cement Gray
    None Yet
    Who sells the bumper shims? Are they 1/2 inch or 1/4 inch? I've seen guys double it .
  14. Jan 11, 2020 at 5:21 PM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    @Coachbuilder1 sells the bumper shims @Willskaf . You can find them on his website or google them for other vendors.
  15. Jan 11, 2020 at 5:31 PM
    Voyagermike
    Voyagermike New Member
    California
  16. Jan 11, 2020 at 6:37 PM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    Thanks fellas
  17. Jan 11, 2020 at 6:39 PM
    Predator Tundra
    Predator Tundra New Member
    Fallon, NV
    2020 Platinum
    Voyagermike[QUOTED] likes this.
  18. Jan 11, 2020 at 6:43 PM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    So if shows on their website that for $85 you get 4 plates. I'm assuming each plate is 1/4 inch thick. Why not just make one plate 1/2 inch thick ?
  19. Jan 11, 2020 at 6:55 PM
    CTPlatinum
    CTPlatinum New Member
    2020 Tundra Platinum 4x4
    None Yet
    Simplicity. People who need either 1/4 or 1/2 inch buy the same kit and CB only has to make one kit with one sku.
  20. Jan 11, 2020 at 7:33 PM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    Got it. It also could be that it's harder to cut a half inch steel .
    I'm going to go with 295/70/18. Can I get away with 1/4 inch or do I need the 1/2 ?
  21. Jan 11, 2020 at 10:19 PM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    On my OEM wheels
  22. Jan 11, 2020 at 10:20 PM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    And stock suspension
  23. Jan 11, 2020 at 10:46 PM
    00PS
    00PS New Member
    2016 Barcelona Red Limited Crewmax TRD 4x4
    FYI - Coachbuilder’s are made from aluminum but other suppliers do make them from steel of that makes any difference to you.
  24. Jan 12, 2020 at 7:38 AM
    TwistedTad
    Tad
    Canyon Lake, CA
    I’m on 295/70/18 and I would probably use 1/2 inch. I rub slightly but the 1/2 inch would provide much better clearance.
  25. Jan 12, 2020 at 8:04 AM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    I definitely like steel better . Who sells the steel one?
  26. Jan 12, 2020 at 8:15 AM
    19TundraPlatinum
    19TundraPlatinum New Member
    Maryland
    2019 Tundra Platinum Magnetic Gray Metallic
    5% Window tint Ceramic coating Weather tech mats Color matched mirror caps and door handles Oem black exhaust tip Blacked out 4x4 badge and added black tundra tailgate insert
    Boss 4x4 are steel i believe
  27. Jan 12, 2020 at 8:16 AM
    19TundraPlatinum
    Maryland
  28. Jan 12, 2020 at 8:24 AM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    Thanks bud
  29. Jan 12, 2020 at 9:16 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
  30. Jan 12, 2020 at 9:56 AM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
