Bump Stop Extensions
Discussion in 'Suspension' started by 70 FJ40, Nov 18, 2020.
  1. Nov 18, 2020 at 8:37 PM
    70 FJ40
    70 FJ40 [OP] New Member
    Max
    '16 Tundra SR5 TRD 4X4 Double Cab
    Just had a tuff country 2" leveling kit installed Saturday. Will likely move to Bilstein 6112 in a couple years when my shocks wear out but I had to do something to get rid of the rake for now. Anyway I need extended bump stops to prevent shock/suspension damage. Ya? Where is best place to get them? What size?
  2. Nov 18, 2020 at 8:50 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Durobump, is what i have or wheelers offroad have them.
    Black Wolf likes this.
  3. Nov 19, 2020 at 12:28 PM
    70 FJ40
    Max
    Thanks. I'll check them out.
  4. Nov 19, 2020 at 1:22 PM
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
  5. Nov 19, 2020 at 1:28 PM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Get the Wheeler's Super Bumps, don't bother with extensions. They use a material that is way better than OEM at absorbing bumps and makes the ride smoother when you hit the bump stops.
  6. Nov 19, 2020 at 2:43 PM
    chickunfut
    chickunfut Low-buck Ramp Truck
    Fort Worth, TX
    2007 Tundra Crewmax
    Wheelers also sells spacers in a few different sizes. I've got a set of bumps with 1/4" spacers on the way. They have 15% off now....
    I was looking at Durobump but they're a bit pricey $$$
  7. Nov 19, 2020 at 3:39 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    They still compress to OE height so he will still need to shim to avoid coil bind / block height issues.
    joonbug, Tundyfundy and equin like this.
  8. Nov 19, 2020 at 4:51 PM
    KaneDog
    KaneDog New Member
    2012 Black SR5 TRD FFV
    Tundyfundy likes this.
  9. Nov 19, 2020 at 6:39 PM
    70 FJ40
    Max
    I checked out the wheelers ones but they only say to put them on the back of the control arm and leave the the ones on the front for harder bumps. If the wheels bump stops still allow the suspension to bottom out on a hard bump then I'm not gaining anything except a smoother feeling ruined spring/shock. Right?
    equin likes this.
  10. Nov 19, 2020 at 7:08 PM
    300BLK
    300BLK New Member
    Good point, i would shim the Wheeler's. Worth the upgrade while you're in there imo.
    14burrito[QUOTED] likes this.
  11. Nov 19, 2020 at 8:12 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I run the superbumps, been very happy with them.
  12. Nov 19, 2020 at 8:22 PM
    70 FJ40
    Max
    I looked at the coachbuilder extensions. Seem pretty good. Fair price but the website say they are for 3" to 4" lifts. Mine only being 2" are they going to be too long? Don't want to hit the bump stops before necessary.
  13. Nov 25, 2020 at 8:13 PM
    70 FJ40
    Max
    Ended up ordering the coachbuilder bump stop extensions. David said they would work great for my application. Got them the other day and installed them tonight. After installation there is only about 3/4" of room between the bump stop and the lower control arm. That's on the back bump stop. There is even less room in the front. Sure seems like I should have more up travel then 3/4" before breaking something on my suspension. Right?
  14. Nov 26, 2020 at 12:11 PM
    aussieaarons
    I thought the same with mine but apparently it’s the angles and distance from the wheel, 1/4” on the bump stop Is 8” of suspension travel etc
  15. Jan 31, 2021 at 3:14 PM
    Steelyhead
    Steelyhead 2016 Tundra TRD
    America
    16 Tundra TRD/03 Limited TRD
    getting a tuff country 2” on Friday. Was not told I need extensions bump stop. Who told you this ?
  16. Jan 31, 2021 at 8:21 PM
    70 FJ40
    Max
    I don't remember exactly. Just read about it several places here in the forum. Apparently the stock suspension can compress too far once it has the spacers. I'm sure you probably have to hit it pretty hard and it probably rarely happens as lots of people are running a level kit without putting in bump stop extensions but I wanted to be safe.
    Steelyhead likes this.
  17. Jan 31, 2021 at 8:40 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    upload_2021-1-31_20-39-11.jpg upload_2021-1-31_20-39-57.jpg upload_2021-1-31_20-40-15.jpg
    From my limited knowledge, whenever you lift using spacers or shims you need to extend the bumpstops. This is due to the fact that if the shocks reaches full compression before the lower control arm is stopped by the frame and bumps, the shock takes the remainder of the force from the bump, which can basically taco your shocks
    14burrito likes this.
  18. Jan 31, 2021 at 8:42 PM
    Tundyfundy
    Bay Area, CA
  19. Feb 1, 2021 at 8:51 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    @Tundyfundy yup,
    Even some aftermarket (like bilstein) setups still require a bump shim to be used. In bilsteins case its due to block height.
