Bully Dog BDX tuner
Discussion in 'Performance and Tuning' started by darkknight2014, Nov 12, 2016.
  1. Feb 12, 2018 at 7:40 PM
    Sanjostuntrider
    Sanjostuntrider New Member
    80 miles ... dam bro :turtleride:
    O'hAodha likes this.
  2. Feb 12, 2018 at 7:48 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    2016 Silver Platinum 4X4
    3/1.5 lift. TRD sway bar. Bakflip V1 cover. Fuel wheels w/BFG A/T.
    I’ve had the performance tune installed for almost 4 months and absolutely love it! Throttle is way more responsive with a more “natural” feel to it. Stock I thought the throttle felt too heavy. Shifting is fast and very smooth. All positive results with no noticeable flaws. Highly recommend.
  3. Feb 12, 2018 at 11:23 PM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    Exactly^
  4. Feb 13, 2018 at 3:31 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    So higher octane = better fuel? I believe this has been proven to be a fallacy.
  5. Feb 13, 2018 at 7:20 AM
    O'hAodha
    O'hAodha New Member
    2014 DC SR5 FFV
    Lift, 35's on 20's, BAmuffler/ dirty deeds budget dump, S&B CAI, NFAB Front and Rear bumpers, blacked out headlights and tailights.
    Looks like performance tune it is tonight. Thanks y'all.
  6. Feb 13, 2018 at 10:33 AM
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    Keep in mind if you run premium tune you need to run 91+ octane.
    O'hAodha[QUOTED] likes this.
  7. Feb 13, 2018 at 10:57 AM
    O'hAodha
    O'hAodha New Member
    2014 DC SR5 FFV
    Thank you!
    Sting Ray[QUOTED] likes this.
  8. Feb 13, 2018 at 5:14 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    So I’ve run through a tank of 91 w performance tune now and wow I love it even more! Defiantly worth the extra $$ at the station lol.
  9. Feb 14, 2018 at 6:23 AM
    Biglagrone13
    Biglagrone13 New Member
    2018 tundra platinum
    Does running a tune void your warranty. I just got my truck but I wanna tune it if it allows it to shift better and get better gas mileage
  10. Feb 14, 2018 at 9:01 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Not all engines/tunes can take advantage of higher octane fuel, but yes, it is better.
    https://en.m.wikipedia.org/wiki/Octane_rating
  11. Feb 14, 2018 at 4:48 PM
    crishard
    crishard Occasional Member
    Cris
    2014 Barcelona Red CM
    3" level in front, ICI Bumper & Skid, 12k lb winch, UCAs, Radtech 2.5s, Kenda 35s, Dual Batteries, 3500w inverter
    I'm planning to take the leap. I was trying to better understand the differences between the GT & BDX models. Here is what I learned:
    I spoke to a bullydog sales rep who seemed quite knowledgeable. I was told that both programmers do exactly the same things including the same three tune programs. The only difference is that the GT is designed to be left mounted to the dash or window to monitor parameters. The BDX is used to upload the tune and then put away until it is needed. Neither are touch-screen. No custom tunes for Toyota either.
    Ol’Remy likes this.
  12. Feb 14, 2018 at 5:17 PM
    BayRunner
    2017 Tundra Platinum
    Who has pics of the GT mounted? Curious as to where and how it stays put.
  13. Feb 14, 2018 at 5:42 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    It mounts using a suction cup bendable arm. It stays put and doesn't move around at all except for a little vibration now and then. I have mine between the dash and the A pillar. The HDMI cable runs down to the driver side kick panel where I have everything mounted behind the kick panel. The cable is tucked away between the dash and the door frame so you can't even see it.
    Not a very good pic but here you go.
  14. Feb 14, 2018 at 5:49 PM
    BayRunner
    Looks good, Thanks!
  15. Feb 14, 2018 at 5:52 PM
    O'hAodha
    O'hAodha New Member
    2014 DC SR5 FFV
    The BDX can read and clear codes. From what I have read, the GT can't. Also read you could mess with Tire size calibration with the GT, where you can't on the BDX.
    Flyinryank likes this.
  16. Feb 14, 2018 at 5:54 PM
    O'hAodha
    O'hAodha New Member
    2014 DC SR5 FFV
    BDX is about the size of the old Zune mp3 player. The brick
  17. Feb 14, 2018 at 6:39 PM
    Taco-Blender
    AZ
    2010 DC 4x4
    GT reads and clears also, at least mine does.
  18. Feb 14, 2018 at 6:53 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Does the BDX read trans temps. I have heard that they can turn off seat belt beep. I would like to confirm before buying one.
  19. Feb 14, 2018 at 7:22 PM
    #49
    crishard
    Cris
    The sales person told me that these tuners cannot correct tire size. Sounded like most of the features that are listed on the BD website aren't possible on the Toyotas.
    Prostar 190 likes this.
  20. Feb 14, 2018 at 8:18 PM
    #50
    Taco-Blender
    AZ
    2010 DC 4x4
    Not entirely true. You absolutely can adjust the speed your speedo displays to compensate for larger tires.
  21. Feb 14, 2018 at 8:22 PM
    #51
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Is this a bully dog? I don’t recall seeing that screen in mine.
  22. Feb 14, 2018 at 8:52 PM
    #52
    Taco-Blender
    AZ
    2010 DC 4x4
    Yeah, GT Platinum.
    Menu/Vehicle Settings/Speed Display
    My speedo matches my GPS speed within 1 mph so I haven't bother to use this feature.
  23. Feb 14, 2018 at 9:03 PM
    #53
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Whats y'alls best setting? I forgot what setting I used but when downshifting it downshifted hard and wasn't a pleasant experience but it was also at sharp turns uphill and downhill, I never used premium tune with premium fuel so I'm gonna load the BD back into the truck and try it. The smooth shifting is part of the tune if Im not mistaken correct? Meaning no matter what tune you select, smooth shifting is in there? Post up yalls best or favorite settings.
  24. Feb 14, 2018 at 9:13 PM
    #54
    O'hAodha
    O'hAodha New Member
    2014 DC SR5 FFV
    Turn off seat belt beep, and remove speed limiter. :)
    equin and Flyinryank like this.
  25. Feb 14, 2018 at 9:23 PM
    #55
    O'hAodha
    O'hAodha New Member
    2014 DC SR5 FFV
    Had this been known to me, my choice would have been GT Gas over the BDX.
  26. Feb 15, 2018 at 2:30 AM
    #56
    crishard
    Cris
    Is the Platinum different than the GT? I don't see a GT platinum offered on the BD website. Maybe that's why I was told that the functions are more limited? I know that I've heard of that model before.
  27. Feb 15, 2018 at 2:41 AM
    #57
    I was told the same thing when I talked to them also.
  28. Feb 15, 2018 at 6:07 AM
    #58
    Theonlyway
    Theonlyway New Member
    User
    what are you all paying? I can get the gt gas for 352. or the gt gas platinum for 299. Are those good deals?
    Prostar 190 and 15whtrd like this.
  29. Feb 15, 2018 at 6:13 AM
    #59
    15whtrd
    15whtrd Mr. Blonde
    Yeah that’s a really good deal. I hate you!
    Go to the BD website and see how much they charge!
  30. Feb 15, 2018 at 6:35 AM
    #60
    Taco-Blender
    AZ
    2010 DC 4x4
    That's quite possible and I'm not really sure they are different.
    I got mine from a member here on Tundras.com for $125 so it's possible the one I have might be a few years old. I can look at the packaging for the part number when I get home today. I do know that when you start the truck and the BD boots the splash screen says "GT Platinum Gas".
