Build thread 08
Discussion in '2nd Gen Tundras (2007-2013)' started by wyoboypt, May 19, 2022.
  1. May 19, 2022 at 2:08 PM
    wyoboypt
    wyoboypt [OP] New Member
    Minty
    Ok so i have an 08 tundra doublecab. It already has a larger 42 gallon gas tank which is good for me and the amount of hunting ect I do. I have fox coil overs sitting in the garage with rears. Reservoirs all the way around. (3” lift) And new icon multi rate Leaf packs With an extra leaf if I need. (2” lift) Also icon upper control arms. It has 18” stock wheels which I hate 18” due to the more expensive tires. I’m planning on running 35 tall by 11.5 wide or narrower. Will I have any issues with the stock wheels? If so then I will invest in some 17s.
    E688146D-FD30-494E-8B3D-1CF7E8968CDE.jpg I will get better pics later. Planning on new gears with at least a rear locker, maybe both. Maybe a topper with a rack. We will see.
    Bikeric and PhotoNerd like this.
  2. May 20, 2022 at 8:35 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    I ran some 35x10.0R17 Swampers with no issues, but the wheels had a +12 offset. If you have any rubbing with stock 18 wheels you could easily get hubcentric spacers to push them out and away from the UCA. I think you will be fine though.
    wyoboypt[OP] likes this.
  3. May 20, 2022 at 1:32 PM
    wyoboypt
    Minty
    I’d rather not have to do spacers. Would +35 offset take care of this? I also don’t want to do any body mount chopping if possible
  4. May 20, 2022 at 2:00 PM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    I honestly don't think a BMC is necessary for any 35's/wheel combination.
