Bsm in 1794 towing mirrors
Discussion in 'Towing & Hauling' started by Makin1980, Apr 7, 2021.
  1. Apr 7, 2021 at 1:00 PM
    Makin1980
    Makin1980 [OP] New Member
    Marcin
    Anyone have same problem
    I have 2017 1794 edition tundra
    Installing towing mirrors with bsm and bsm not working
    Some suggestions???
    I think different pins
  2. Apr 26, 2021 at 7:41 PM
    spacemanluther
    spacemanluther New Member
    Charles
    2018 Tundra CrewMax
    I picked up some from partsgeek which 1aauto referred me to. I have a 2018 sr5 that has bsm. I've been moving pins and can't seem to get it. The bsm lights on the mirror come on at start, and if I have bsm turned on no errors. Then I drive around and when they detect it throws an error. If I toggle the bsm setting I can get it to error as well. The posts about adding a led might work but I have the led on the mirror itself. I might take the mirror off to see if there are loose connections.
  3. Apr 27, 2021 at 10:27 AM
    spacemanluther
    Charles
    2018 Tundra CrewMax
    I started mapping out my pins. I don't think it can be fixed with pins. Anyone have an idea? Take the 5th wire and swap it with the 3rd wire? Move the common negative?
    Found this in another thread... added FACTORY or NOT FACTORY for my Truck.
    Pin 1: Heat + FACTORY
    Pin 2: Heat – FACTORY
    Pin 3: Signal – Running Light - NOT FACTORY
    Pin 4: Signal + NOT FACTORY
    Pin 5: Puddle Lamp – FACTORY GROUND?
    Pin 6: Puddle Lamp + NOT FACTORY
    Pin 7: Mirror Retract (+) NOT FACTORY
    Pin 8: Mirror Fold (–) NOT FACTORY
    Pin 9: Running Light + NOT FACTORY
    Pin 10: Mirror Vert (power) FACTORY
    Pin 11: Mirror + FACTORY
    Pin 12: Mirror Horiz (power) FACTORY
    Pin 13: Auto-Dim – NOT FACTORY
    Pin 14: Auto-Dim + NOT FACTORY
    Pin 15-17: Memory Pins NOT FACTORY
    Pin 18: BSM light FACTORY
    BROCK TOW MIRRORS
    Pin 1: Heat + YES
    Pin 2: Heat – YES
    Pin 3: Signal – Running Light - YES
    Pin 4: Signal + YES
    Pin 5: Puddle Lamp – NO
    Pin 9: Running Light + YES
    Pin 10: Mirror Vert (power) YES
    Pin 11: Mirror + YES
    Pin 12: Mirror Horiz (power) YES
    Pin 18: BSM light YES
  4. Aug 3, 2021 at 9:12 AM
    whiskey_woo
    whiskey_woo New Member
    Same issue here. Were you able to make any progress?
  5. Aug 3, 2021 at 11:50 AM
    whiskey_woo
    You motivated me to try to get mine working and I was successful. I traced the wires from the factory mirror and found the BSM wire in the tow mirrors needed to be flipped from top to bottom. Mine was a purple wire and I believe I just moved it from position 9 to 18 using a pair of pliers. They now function on a 2014 Platinum.
  6. Aug 10, 2021 at 3:04 PM
    spacemanluther
    Charles
    2018 Tundra CrewMax
    @whiskey_woo - I couldn't do that purple wire 9/18 swap. It never worked on my 2018! So I ended up removing the BSM light and about 4 inches of wire from the orig OEM lights. Then I removed the mirror from the tow mirrors, stripped out the light and used the old lights... HUNG them out the side of the mirror - installed them and it worked great! From this thread I think I read the actually light for the bsm triangle was not the right amp? BUT!! I then closed them up and now it doesn't work. I haven't been able to go back and troubleshoot again. Fail. 20210513_134022.jpg 20210513_134031.jpg
  7. Aug 29, 2021 at 3:47 PM
    spacemanluther
    Charles
    2018 Tundra CrewMax
    Update to this - got it working today. My passenger side always lit the light - but the driver side did not. So I got brave and removed the mirror once again - traced the wires, checked the light, traced the wires again, put a meter on the mirror... everything looked in order. So what the heck- reverse the wires. Purple to black, black to purple and walla. Now I am working!! whew. brutal.
    HulkSmurf14 likes this.
  8. Nov 10, 2021 at 2:02 PM
    GoletaGreg
    GoletaGreg New Member
    Hey Charles,
    What pin numbers did you switch?
    Thanks,
    Greg
  9. Nov 12, 2021 at 7:20 AM
    spacemanluther
    Charles
    2018 Tundra CrewMax
    @GoletaGreg This is what my wiring ended up looking like. I believe I always went back to factory pining. Looking for the image before I installed them... upload_2021-11-12_8-17-45.jpg
  10. Nov 12, 2021 at 7:21 AM
    spacemanluther
    Charles
    2018 Tundra CrewMax
    Original image for passenger side... prior to mirror install.
    gDBKnKge4K4vkZFfEIyBU105EGixJMDQwXZGbPWv_66f3e60fd33a6ac828c43844637e73fc0d21b7ea.jpg
