Broken Sway Bar from frame
Discussion in '1st Gen Tundras (2000-2006)' started by Kenny Loggins, Mar 1, 2026.
  1. Mar 1, 2026 at 1:36 PM
    Kenny Loggins
    Kenny Loggins [OP] New Member
    2004 Toyota Tundra V8 SR5 Limited Double Cab
    Hope everyone's been doing well on here.
    Crawled underneath today to take a look at what needs attention and noticed the sway bar broken from the frame. PXL_20260301_212451712.jpg
    What should I be doing next?
    whodatschrome likes this.
  2. Mar 1, 2026 at 1:40 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Dirty Deeds injectors, Addco rear sway, AEM dry flow air filter, K & N cobbled intake tube w/OE filter box, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level with 5100s, and lots of electronics.
    Check the rest of your frame. With a hammer and screwdriver. Someone put some heavy bondo over damage and/or extensive rust.
    I would not be driving that truck.
    BroHon, Bo13R, Black Wolf and 5 others like this.
  3. Mar 1, 2026 at 1:45 PM
    Kenny Loggins
    Heading back out to test it all out.
    Would something like this be repairable?
  4. Mar 1, 2026 at 1:51 PM
    Azblue
    The Dirty T ( ^_^)_且
    My guess is the entire frame is rusted to shit. Yes, it is repairable by getting a new frame.
  5. Mar 1, 2026 at 2:04 PM
    Kenny Loggins
    To find this
    G_unit3000, Yota303 and FrenchToasty like this.
  6. Mar 1, 2026 at 2:05 PM
    Upshot Knothole
    Upshot Knothole This space for rent.
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    I'd recommend checking the rest of the frame very carefully, if they spent that much time hiding that spot, I'm curious to see what else they hid.
    Azblue and FrenchToasty like this.
  7. Mar 1, 2026 at 2:11 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    2004 AC 2wd to 4wd conversion ABS delete
    I recommend wrapping the frame twice with chicken wire and following up with three heavy coats of bondo
  8. Mar 1, 2026 at 3:55 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    If you bought that recently you may want to look into what recourse you may have against the seller. Failure to disclose, and/or concealing a structural defect is actionable.
    Mr Badwrench, PNW15, Sean492 and 3 others like this.
  9. Mar 1, 2026 at 5:00 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    In some states...
  10. Mar 1, 2026 at 5:36 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Holy shit…..thank god you found it before there was a catastrophic failure at highway speeds. That looks terrible and probably the result of extensive rust and/or an accident unreported. That looks like a 10 year tried to patch it.
    Kenny Loggins[OP] likes this.
  11. Mar 1, 2026 at 5:44 PM
    Casper421
    In the woods
    06 DC
    Replace the frame or buy a welder and let the sparks fly! Seriously though, I wouldn’t drive that truck anywhere!
  12. Mar 1, 2026 at 6:43 PM
    shifty` Too bad it took bullets to give you an open mind
    Wow.
    Someone basically welded some shitty patches on the rotten ass frame, then coated it with bondo, and painted it.
    Were you aware you bought something a previous owner hacked together and covered up? That's freaking crazy how rotten it looks.
    I'd be piiiiiissed if I bought that truck a few weeks back, and found that, randomly. Like, someone knew damn well that rot existed, and chose to hide how bad it was. What the hell?
    Yota303 and Kenny Loggins[OP] like this.
  13. Mar 1, 2026 at 7:47 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
  14. Mar 1, 2026 at 8:17 PM
    Kenny Loggins
    Having a guy from the local frame shop stop by tomorrow morning. Gave him a heads up what to expect along with pictures. We'll see if it'll buff out.
    I started chipping away at what I could and noticed a couple more spots but none at bad as this. It must've happened recently because I crawled underneath the whole thing when I bought it and checked all the spots for rust.
    Hoping there's a way forward without parting it out or cut it as a loss. Its crazy too because I've been driving it on the highway and around town but as others have said, I could be one bad bump away from catastrophic failure.
    Any efficient way to getting all the bondo off other than hammer and screw driver?
    G_unit3000 likes this.
  15. Mar 2, 2026 at 5:25 AM
    Did the seller not disclose any of these issues? It's illegal in some states to sell a car with known safety issues.
    We tell folks to look for differences in paint color/finish/texture or shininess on the frame, any texture other than "baby's butt smooth". Any of those are a flag to dig deeper.
    Painters tool, specifically one with a steel hilt, may prove more effective due to the wide face. If you can get under an edge of the bondo, it should come up pretty easy.
    G_unit3000 and whodatschrome like this.
  16. Mar 2, 2026 at 5:50 AM
    Jack McCarthy
    Jack McCarthy You don't need an electrician, you need a plumber
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    You forgot to remove this piece as well. And maybe the one further to the left.
  17. Mar 2, 2026 at 6:04 AM
    hagrid
    hagrid debris-ridden gaijin
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Flew into the Danger Zone with that frame.
  18. Mar 2, 2026 at 6:21 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    This looks like proof of what's we've suspected that these frames can rot from the inside out.
    shifty` likes this.
  19. Mar 2, 2026 at 6:31 AM
    In this case, someone scabbed the frame over in several places to cover holes, and poorly at that. The nasty booger welds in the left side of Bill's red oval two posts up suggest whoever did the work may not have prepped the metal before welding, and definitely did a shit job. The fact their patch sheared the steel, that one plate cracked in half, tells me they either used crap steel, or didn't account for the stress that patch would endure. Sadly, this over to the left is another cobbled-together patch which looks like a mix of steel plate and sheet metal, "lipstick on a pig".
    This shit is bad. Like, bad-bad. I'm not a lawyer-happy person, but I'd be suing the shit out of whever sold this to me if they didn't disclose all this, the frame looks pretty much trashed to me. But then again, it resonates when you look at what a previous owner did to the audio in the truck. It's all starting to come together now. Cobblers gonna cobble!
  20. Mar 2, 2026 at 7:00 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I agree completely but when you look at the frame, it's clear it rusted badly inside.
    shifty`[QUOTED] likes this.
  21. Mar 2, 2026 at 2:35 PM
    Mr Badwrench
    Mr Badwrench New Member
    '01 SR5 4X4 V8
    She'll go 300 hectares on a single tank of kerosene
    People are fucking horrible for selling stuff like that without disclosure. I mean Bondo?!
    Jack McCarthy likes this.
  22. Mar 2, 2026 at 2:56 PM
    shawn474
    MoCo, Maryland
    Bondo is better than the spray foam and spray paint most of these clowns do…..I agree that people who do this suck. Had that happen with a jeep wrangler I was fixing up for my wife
    Upshot Knothole and shifty` like this.
  23. Mar 3, 2026 at 2:11 AM
    w666
    Maryland
  24. Mar 3, 2026 at 5:42 AM
    Dakillacore
    Dakillacore Quantum Entanglement
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    In terms of frame repairs.....
    Toyota, and everyone else, does not allow or authorize welding on frames or heat straightening of frames.
    From CRIB T-CRIB-193-D
    "Frame Repair Precautions: Sectioning of frames is not an approved repair procedure. Sectioning is defined as the partial replacement of components at locations other than an original seam or joint. When a frame is determined to be repairable by the replacement of individual components, installation should be at factory seams or joints and replicate original factory attachment methods with corrosion protection.
    Since all Toyota and Lexus frames are made from High Strength Steel (HSS); Toyota does not approve of any heating method to stress relieve HSS during the repair process. Overheating HSS degrades the integrity, durability, and corrosion resistance of a frame.
    ‘Cold straightening’, defined as pulling, pushing and hammering, are the only approved methods to stress relieve collision damage. If a frame cannot be restored to original contour and dimensions by cold straightening during the repair process, it should be replaced."
    Heating the frame with welding causes the frame to lose even more structural integrity because of it's make up and how it is formed.
  25. Mar 3, 2026 at 5:46 AM
    Dakillacore
    Georgia
    Also, bondo on a frame is absolutely nutso hack shop behavior. I have NEVER seen that done before. The tech that did that should have their hands removed because who the hell knows what other nefarious abominations they have released on the roads.........They absolutely have the mindset of "awh hell they only say you can't do that to take your money. I've done this plenty of times". Just because you can, does not mean that you SHOULD.
  26. Mar 3, 2026 at 5:55 AM
    Man, I've seen it done before. That's a trick that's been around since the dawn of the product. And before that, people would use lead fill and silver solder.
  27. Mar 3, 2026 at 5:56 AM
    Jack McCarthy
    Bill
    North of Boston
    Toyota could make a modular frame just as strong, unfortunately, it’s not economical for them or any other auto manufacturer since they trying to minimize weight and material to save costs and improve mpg to meet CAFE standards.
    You get hit hard and it’s a one and done for your vehicle when the frame is damaged.
  28. Mar 3, 2026 at 6:10 AM
    The Ford F series uses a modular frame.
  29. Mar 3, 2026 at 6:25 AM
    Dakillacore
    Georgia
    If it's an older vehicle yeah. We have replaced frames before in 4Runners and newer Tundra's that still had really high value. Most of the time it just costs too much for the insurance companies to want to pay to replace them VS just paying the value of the vehicle.
  30. Mar 3, 2026 at 7:42 AM
    Jack McCarthy
    Bill
    North of Boston
    Is it just in the front? I was unaware they did that.
