Broken Bilstein
Discussion in '2.5 Gen Tundras (2014-2021)' started by Redstag, Nov 25, 2019.
  1. Nov 25, 2019 at 5:49 PM
    Redstag
    Redstag [OP] New Member
    Summerland B.C.
    2019 Tundra trd offroad
    275/70r18 ko2 Chrome delete grill Chrome delete rear bump caps Tonneau Linex berliner ...old man emu coming
    Bent the shaft on my front right shock this weekend while hunting.
    Wasn't much of a bump but I could tell something hit awkward. Low speed maybe 10-15 mph. Have a 2inch spacer block on top, would this over stress the shock?
    Ordered 6112s this morning to replace. No love from Toyota.
    georgiey22, Rica25 and kparrow like this.
  2. Nov 25, 2019 at 5:51 PM
    Burdturger
    Burdturger New Member
    Where did you order from? On a side note, would this not be covered from bilstein directly? I thought I read something about a lifetime warranty
  3. Nov 25, 2019 at 5:54 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Not with a spacer
    Tundyfundy and ColoradoTJ like this.
  4. Nov 25, 2019 at 5:56 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The issue is that the spacer causes the shock to bottom out and collapse before the rubber bump stop on the lower control arm takes the brunt of the hit.
    Did you order from Essex Distributors? Hopefully the 6112’s aren’t still back ordered like they were for me. If they are, I might be able to help you out, as mine are still waiting to be installed. I’m about 1.5 hours north of you.
    Tundyfundy, Scud and ColoradoTJ like this.
  5. Nov 25, 2019 at 5:58 PM
    Azblue
    The Dirty T ( ^_^)_且
    This is just one of the reasons spacer lifts suck. Actually fairly common with spacers.
  6. Nov 25, 2019 at 6:05 PM
    BigTun
    BigTun New Member
    Christopher
    2016 Black DC Offroad
  7. Nov 25, 2019 at 6:39 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
  8. Nov 25, 2019 at 7:25 PM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Yep. The spacer lift will cause that to happen.
    kparrow likes this.
  9. Nov 25, 2019 at 8:01 PM
    BIGUGLY
    Paul
    2018 Limited
    Short answer, spacer fubar'd the shock.
    Tundyfundy and kparrow like this.
  10. Nov 25, 2019 at 8:07 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Spacer block made the shock into the bump stop instead of the bump stop. It bottomed out the shock because it changed the geometry and bent it. 6112’s will remedy that cause it will put you back into the normal geometry of the suspension
