Breaking down the D.A.P. The What and the Why.
Discussion in 'Performance and Tuning' started by treihing, Sep 30, 2017.
  1. Feb 24, 2018 at 6:43 AM
    #91
    WatTundra
    WatTundra New Member
    Kenny
    FTW, TX
    2016 MGM Tundra
    Stock as a rock minus tint
    I've had his tune for almost a year and my truck has only seen 87. I don't have any knock or anything noticeable. I was told that running premium would net the most out of the tune but 87 wouldn't be harmful. If I wanted to switch to 93 it would take 3 tanks for the computer to learn and adapt or I could disconnect the battery for a given amount of time and not go through 3 tanks before learning.
    BlueBottle[QUOTED] and UTTundra like this.
  2. Feb 24, 2018 at 6:45 AM
    #92
    UTTundra
    UTTundra New Member
    Lou
    Utah
    There have been guys that have used both and claim they didn't notice much of a difference. But it is a tune designed for premium, so if you want to get 100% out of the tune you should stick with premium.
    BlueBottle[QUOTED] and WatTundra like this.
  3. Feb 24, 2018 at 10:00 AM
    #93
    Beep88
    Beep88 New Member
    If you do the remote tune then you can change it back to stock any time you need to and put the tune back in right? Those who have this tune do you feel it is well worth the money and would do it again? I don’t really care about the mpg gain but want a performance gain. I have read where everyone says it is smoother but is it more responsive? With the tune do you have to run it in tow/haul mode to feel it or is it felt without being In tow mode? I really would like to get this but just want to make sure it’s worth the money!
  4. Feb 24, 2018 at 10:09 AM
    #94
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
  5. Feb 24, 2018 at 10:13 AM
    #95
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Yes, if you do the remote you can go back and forth on your own. Whether it's worth it depends. $600 ain't cheap. If you are supercharged or running headers, I'd say no brainer since the gains should be more significant. I did it because my truck was feeling sluggish after going up to a 295/70/18 tire (I will be regearing next week). I'm stock performance wise except for exhaust. After the truck "learns" the tune, it is noticeable and more responsive. You do not have to run it in tow/haul. The tune by itself is not as torquey as being in tow/haul mode. Maybe somewhere in between. When I'm driving normally in town, 30-40 mph, stop and go is more enjoyable. The truck seems to get out of first very quick, then holds second and third longer than stock (and fourth depending on what speed I'm getting up to). My MPG's have stayed the same or maybe dropped a bit since I was using ethanol free fuel before the tune (better for MPGs). One thing I was a little disappointed about was the truck still shifts out of first around 5400 when I step on it off the line. Some guys shift above 6000 out of all gears apparently. According to DAP, my truck is likely seeing some slight wheel spin, causing it to shift early.
  6. Feb 24, 2018 at 10:25 AM
    #96
    Beep88
    Beep88 New Member
    Thanks for the info!! I was debating on driving for 14 hours to get the tune in person but I like the idea of being able to take it out if I have to go back to the dealership. This is why I love this site anything you can imagine doing to your tundra you can get answers before pulling the trigger! Everyone is is great about helping with what they know or have learned by doing it!
  7. Feb 24, 2018 at 10:39 AM
    #97
    UTTundra
    UTTundra New Member
    Lou
    Utah
    14 hours is a long hike! The remote tune is very easy to install and uninstall, as long as the tuner you get is working properly. Mine had some glitches, and it was a pain to get it sorted out. But all is good now.
  8. Feb 24, 2018 at 8:51 PM
    #98
    alpinepro4
    Pat
    Why do they say drive 50 miles after you uninstall the tune? I am going to go with a remote tune too.
  9. Feb 26, 2018 at 7:59 AM
    #99
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    It takes 50 miles for the ecu to re-learn all the new parameters. Util you drive 50 miles, the ecu will be in a "not-ready" state.
    I once took my commuter car in for a smog, and had replaced the battery a day before. When the smog tech plugged the computer into the obdII port it was in "not-ready" state and couldn't be smog'd. I told him i just replaced the battery and he said to go drive it 50 miles and come back.....i did and it was good to go.
    15whtrd likes this.
  10. Feb 28, 2018 at 1:37 PM
    #100
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Got tuned last Monday and previous reviews by others are consistent...Responsive, smoother transitions. I couldn't really test out the tune due to the rainy conditions that evening. At this point I really like the tune and will do some further testing this weekend on a road trip to the central coast.
    1UPPER likes this.
  11. Feb 28, 2018 at 1:44 PM
    #101
    15whtrd
    15whtrd Mr. Blonde
    I did the same thing with my wife’s car except I removed the battery to remove the cold air intake so that I could pass smog. He told me the same thing go drive around for 50 miles and come back. All wasgood after.
  12. Feb 28, 2018 at 5:15 PM
    #102
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
    I’m set to be daptized this Saturday and cannot wait. Originally started with the Bullydog tune then switched over to the TRD reflash. BD was terrible and TRD is tolerable. I’m hoping third times the charm with this DAP tune. Truck is Supercharged btw
    Chefjjdecker and signalbobby like this.
  13. May 21, 2018 at 8:59 AM
    #103
    robstruck
    robstruck New Member
    2016 Tundra Trd
    Pro comp leveling with 305/65r18 bfg ko2, magnaflow exhaust, tanneu cover, alpine speakers
    Anyone towing with the tune? I only went up to 305/65/18 and the difference was noticeable. Im also interested in lt headers, should i wait for the headers before i get tuned? Or is there an adjustment to the tune for upgrades?
  14. May 21, 2018 at 9:06 AM
    #104
    UTTundra
    UTTundra New Member
    Lou
    Utah
    No need to wait for other mods before you get tuned unless you are going to supercharge. I've had the tune for several months and just installed American Racing headers a couple weeks ago. My truck is currently on the lift getting a custom catback with x-pipe and 3" tubing built.
    Cfincke likes this.
  15. May 21, 2018 at 1:16 PM
    #105
    robstruck
    2016 Tundra Trd
    THats awsome! Exactly what i want. So the tune dosent change unless you’re supercharged? And if i can only do one for now would you say tune or LTH?
  16. May 22, 2018 at 7:20 PM
    #106
    alpinepro4
    Pat
    Updated Review, I have put over 1,500 miles on my DAP tune and really enjoying the benefits.
    Shift points are very smooth especially on lower end. Having torq management taken off is a big plus, I have power right now. Low end HP is very noticable. My mpg continues to go up. I filled up today and hand calculated at 17.38 mpg, computer said 17.3 and still climbing ( this is driving 60 mph). Using 91 octane, best we can get in Jackson, WY. I am running stock tires at the moment, that will change this Fall. Those of you who are on the fence don't be. Algorithm Shrek created for this tune is the real deal.
    15whtrd likes this.
  17. May 22, 2018 at 7:57 PM
    #107
    boloson
    boloson New Member
    Would like to hear your lt ARH. Been debating to get arh ot jbl
  18. Aug 8, 2018 at 8:49 AM
    #108
    alpinepro4
    Pat
    I just un installed the tune. Have a visit with dealer tomorrow. Is the modified tune still on my tuner? Or do I need to reload it onto the tuner?
  19. Aug 8, 2018 at 8:52 AM
    #109
    treihing
    treihing [OP] MAGA
    TR
    Washington State
    2018 Black Limited CrewMax
    Getting the DAP voids your warranty, correct?
  20. Aug 8, 2018 at 9:15 AM
    #110
    alpinepro4
    Pat
    Yes if they run a scan and see it on there, but no if you pull it off. Getting my truck serviced tomorrow so I un installed the tune.
    15whtrd likes this.
  21. Aug 8, 2018 at 11:34 AM
    #111
    alpinepro4
    Pat
    I just answered my own question. It was right in front of me on my dim sport tuner.
  22. Aug 8, 2018 at 11:48 AM
    #112
    TundraLuv
    TundraLuv New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    Any updates on becoming available for a FFV? Last I emailed still in the works.
  23. Aug 8, 2018 at 12:22 PM
    #113
    Cfincke
    San Antonio
    He has a tune for FFV, as i have had the tune for 8+ months now.
    He has not released a tune for 2018s
  24. Aug 8, 2018 at 12:22 PM
    #114
    alpinepro4
    Pat
    I guess they are waiting on Toyota to release ECU data for 2018 Tundra. Then Shrek can build a tune from there.
  25. Aug 9, 2018 at 4:24 AM
    #115
    bowhun2r
    bowhun2r New Member
    Scott
    Steeler Nation
    this. I've emailed both DAP and Magnuson (wanting to go S/C) about once a month...and both companies have said the same story. Toyota has yet to release the ECU data required to do the tune for the 2018. In Magnuson's case, they leverage BD for the tune. BD relies on SCT to provide the tune. SCT... told me the (you guessed it) Toyota hasn't released the ECU data.
  26. Aug 9, 2018 at 5:07 AM
    #116
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I spoke with Dap a few weeks ago about doing a SC and Dap tun on my 17 FFV. They said they will not do a SC or tune for the FFV. They actually suggested the Bully Dog if I did a SC on my Tundra. I guess they will do a FFV tune but not the SC? I wish Toyota never made the FFV!
  27. Aug 9, 2018 at 6:22 AM
    #117
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    HPTuners supports our trucks now. Go to any dyno shop that tunes with HPTuners and they will be able to tune your truck.
    I made a thread about it. Click here.
  28. Aug 9, 2018 at 7:29 AM
    #118
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    On the flip side, those same shops have no experience tuning our trucks since the support just came out. Gonna be a couple ginnie pigs out there, but overall good to see more tuning options for our trucks.
  29. Aug 9, 2018 at 7:41 AM
    #119
    the_midwesterner
    Luis
    None, yet....
    I don't disagree, but it's all the same concept: A VE table, a PE table, timing table and fuel control. I spoke with HPT and they confirmed that the format would be similar, if not identical, to tuning an LS engine. The biggest variable would be tuning the VVT-i. LS guys get rid of it, because it's junk, but ours actually functions to aid in engine performance. Anyway, it's ALWAYS better to dyno tuning a forced induction vehicle on a dyno that can control load resistance. While there will be a learning curve, I foresee it to be very very small.
  30. Aug 9, 2018 at 7:46 AM
    #120
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
