Brakes
Discussion in '2.5 Gen Tundras (2014-2021)' started by George14, Apr 30, 2019.
  1. Apr 30, 2019 at 5:55 PM
    George14
    George14 [OP] New Member
    West Virginia
    2014 Tundra SR5 Dc TRD Off Road 5.7L with tow package
    None
    I tow a rv need to replace brakes and rotors. Just wondering would the drilled and slotted rosters be better then the solid ones?
  2. Apr 30, 2019 at 6:44 PM
    AZTundra
    Paul
    Phoenix, AZ
    George14[OP] likes this.
  3. Apr 30, 2019 at 6:56 PM
    bfd300
    bfd300 New Member
    I use and have been using brakemotive on all my cars and trucks for years. Drilled and slotted and ceramic pads. Search eBay for brakemotive.
    KFed and George14[OP] like this.
  4. May 1, 2019 at 2:15 PM
    dittothat
    dittothat New Member
    Nick
    SD
    2016 MGM Platinum
    I used Powerstop rotors and pads on my last truck all the way around. Definitely a big improvement over OEM braking and rotors did not warp after a couple years in New England. I plan on buying a set once my current rotors wear out. Some reviews claim to have a fitment issue; we will see.
    15Yota, Prostar 190 and George14[OP] like this.
  5. May 1, 2019 at 6:06 PM
    black240ct
    black240ct New Member
    Power stop drilled and slotted rotors warped on me within the first 4 months.
    Couldn't stand it any more and got the EBC blank disc/ pad kit. should be swapping them over this week.
    15Yota likes this.
  6. May 1, 2019 at 6:12 PM
    AZTundra
    Paul
    Phoenix, AZ
    Did you follow the bedding procedure when they were installed?
    PROPER PAD BEDDING CAN PREVENT ROTOR WARPING. The break-in procedure is critical to brakeperformance. The reason for a proper break-in is to establish an even layer of friction material deposited on the rotors from the brake pads. It is very important that this initial layer of friction material is evenly distributed
    UNTMatt likes this.
  7. May 1, 2019 at 6:22 PM
    black240ct
    Yeah I went off the power stop procedure.
  8. May 1, 2019 at 6:30 PM
    I have the Power Stop Z36 kit and I am very happy with it.
    AZTundra likes this.
  9. May 1, 2019 at 6:37 PM
    AZTundra
    Paul
    Phoenix, AZ
    MGM's don't really need good quality brakes since they rarely hit the speed limit. I hear AutoZone runs a $9.99 brake pad special just for the MGM's. :boink:.
    OP and I both have white Tundras and therefore need some high quality stuff. :burp:
  10. May 1, 2019 at 6:44 PM
    15Yota likes this.
  11. May 1, 2019 at 6:46 PM
    AZTundra
    Paul
    Phoenix, AZ
  12. May 1, 2019 at 6:51 PM
    AZTundra[QUOTED] likes this.
  13. May 1, 2019 at 6:53 PM
    AZTundra and 15Yota like this.
  14. May 1, 2019 at 6:53 PM
    AZTundra
    Paul
    Phoenix, AZ
    That shade looks much closer to MGM than White.
    Here is a white snail:
  15. May 1, 2019 at 6:56 PM
    So white needs a turbo? MGM is fast while being naturally aspirated.
  16. May 1, 2019 at 6:59 PM
  17. May 1, 2019 at 7:00 PM
  18. May 1, 2019 at 7:46 PM
    offsetplayer2
    offsetplayer2 New Member
    Woods and Fields, NC
    2018 Inferno CM 4WD
    Please we all know inferno is by far the most badass color and fastest.
    Oh and I put the drilled and slotted powerstop from autoanything on my ‘11 taco and they were great. I’ll probably put them in my Camry soon and tundra when needed.
