Brake Lines
Discussion in '1st Gen Tundras (2000-2006)' started by rritch01, Feb 22, 2021.
  1. Feb 22, 2021 at 9:17 AM
    rritch01
    rritch01 [OP] New Member
    Randy
    2000 Tundra Limited
    I have a 2000 Tundra Limited TRD and have fought brake issues since I bought it in 2004. Thanks to this forum, I know about the TSB for upgraded calipers. I ended up having one lock up after a few years and ruin a disc. I replaced both discs and calipers about 18 months ago.
    Our daughter is currently in an auto maintenance school about two hours away and had a disc warp. She talked to the instructor for her brake class, who recommended new lines.
    She has searched herself and through the tools at school and can only find the flexible part of the brake lines.
    Does anyone know where we can find the solid brake line sections?
    Thanks!
  2. Feb 22, 2021 at 9:33 AM
    des2mtn
    des2mtn Third Member
    Where my wheels stop rolling
    2004 Black DC Limited 4x4
    Tonto cover
    I would hold off on the solid hard lines unless they are obviously pinched or damaged. Replace the flexible line first (optionally with a stainless steel line) and then bleed the brakes, see if that makes a difference. Hard lines can be replaced with lengths of line from somewhere such as NAPA, a line bender, a flaring tool and the old fittings.
    N84434 likes this.
  3. Feb 22, 2021 at 9:35 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    You won't find preformed replacement lines pretty much outside of the dealer.
    Any parts store will sell you premade lengths or rolls of tubing and connections.
  4. Feb 22, 2021 at 9:36 AM
    rritch01
    Randy
    2000 Tundra Limited
    Thanks to all! Interesting lesson for her.
  5. Feb 22, 2021 at 9:40 AM
    des2mtn
    Tonto cover
    Also note that the fittings on our lines are metric, not SAE. If you use the latter you'll have a bad time.
  6. Feb 22, 2021 at 11:59 AM
    Turbo_4runner
    Turbo_4runner New Member
    2003 Tundra AC; 1987 4runner; 1971 FJ40; 2015 Golf SW TDI
    Some hard lines are still around, and really aren't that expensive from the dealer. I destroyed on of the rear ones and a replacement was like $17. Not worth my time to bend and flare a line for that kind of money.
    Kgun and Professional Hand Model like this.
  7. Feb 22, 2021 at 12:56 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you get in touch with Solo Motorsorts they sell a stainless braided line that eliminates both the rubber line and the hard line section.
    I don't think new brake lines will help to be honest. These trucks are hard on rotors, especially if the brake balance is light on the rear drums. I would have the rotors replaced with decent quality (Brembo blanks for example) and change the pads (Akebono or Toyota). Then get the rear drums adjusted and fresh fluid.
  8. Feb 22, 2021 at 1:07 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Last summer I was able to purchase the front left and right lines that run from the ABS pump to each caliper, and yeah, they weren't too expensive. Went through toyotaparts.com
    On the other hand, I fabricated the line that runs from the rear brake splitter down to the LSPV. Very easy, as des2mtn stated..
  9. Feb 22, 2021 at 1:15 PM
    des2mtn
    Tonto cover
    I just did my rear axle lines and had two custom 31" stainless steel lines made that go out of the tee-splitter you mentioned, that was fairly cheap too.
    I partially mentioned flaring lines because OP mentioned their daughter is in auto maintenance school, perfect time to learn something new.
    N84434 likes this.
  10. Feb 22, 2021 at 2:15 PM
    Jack McCarthy
    Jack McCarthy Truck repair enthusiast; Rust Aficionado
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Brake lines are never fun. Always buy some extra line to practice if you haven't done it before.
    It always sucks when you have some weird brake line contorted shape that allows you to navigate around other parts and you don't get it right the first time.
    Darkness likes this.
  11. Feb 22, 2021 at 3:33 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    The steel line is a bitch to work with. The copper/nickel is a whole lot easier.
  12. Feb 22, 2021 at 4:11 PM
    Jack McCarthy
    Bill
    North of Boston
    I’ll have to consider switching over from the PVF ones next time. The stuff certainly isn’t cheap though.
