Brake Controller Error Message
Discussion in 'Towing & Hauling' started by rockjockey, Mar 29, 2018.
  1. Mar 29, 2018 at 10:18 AM
    rockjockey
    rockjockey [OP] Per ardua ad astra!
    Spring, TX
    2016 White Tundra TSS
    While driving home from work a few days ago, the end-of-the-world message below appeared on the dash display in my 2016 Tundra TSS.
    The brakes seemed to be acting normally but I took the truck to the dealer to see what's up. They have fiddled with it for 2 days and now say they need to back order a new brake controller. By the way, I have only pulled a trailer once with this vehicle and that was 2 years ago and just for a few miles on a dirt farm road.
    Anyone else ever get this message? Repair? Results?
  2. Mar 29, 2018 at 2:53 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    That's the message I got when I replaced the IBC in my 2016 Tundra. It went away when I disconnected the battery for 20 minutes. My guess your Brake controller disappeared to the ECU.
    chicano1313 likes this.
  3. Jul 28, 2018 at 7:31 AM
    2016tundracrewmax13!
    2016tundracrewmax13! New Member
    Black sr5-trd
    custom headlights by eldobleu 6inch rough country lift 20x12 wheels with -44 offset and 35 inch tires full subwoofers all halogen lights replaced with leds fog lights led from retrofit.com rough country floor mats
    was that the real issue? needing a new brake contoller? i am getting the same error but abs in addition. Ive replaced the abs sensor, connecting wire also up to the 1st connection before it goes into the box up top in the engine compartment. I am thinking of replacing the wheel hub assembly as i think it might be rubbing on the abs sensor. I came to the conclusion about zeroing on the the abs sensor after taking it to the dealership and having them scan it. it came back with a reading a bad sensor wire front passanger. but after all my work i am still getting the exact same error. my braking seems to work fine and no problem driving and i can use cruise control... havent tried 4 wheel drive any as im scared it might mess something up. I also disconnected the battery for 5 minutes and still the same errors. any help will be greatly appreciated. i have a 2016 tundra crewmax
  4. Apr 2, 2019 at 4:21 PM
    chicano1313
    chicano1313 New Member
    Jesse
    2016 CM
    6" Lift
    This this just happened to my truck about 1 hour ago I'm going to go and disconnect the battery when I get home and see what happens.
    I disconnected the battery for about 30m8n . Nothing happened. Same message.
  5. Apr 24, 2020 at 2:28 PM
    So1988
    So1988 New Member
    Anybody know the route cause for this issue? It seems to happen for many 2016 tundras!
  6. Apr 30, 2020 at 8:20 PM
    toyojone
    toyojone New Member
  7. Apr 30, 2020 at 8:23 PM
    toyojone
    toyojone New Member
    Did you get an answer?
  8. Sep 16, 2020 at 12:05 PM
    Bravo66
    Bravo66 New Member
    Any outcome to this ?
  9. Jun 5, 2021 at 8:22 PM
    Ogre86
    Ogre86 New Member
    Glenn
    2016 SR5 Crewmax TSS
    Anyone have any luck figuring this out? Same exact lights on mine.
  10. May 16, 2023 at 3:42 PM
    Fsuriptide
    Fsuriptide New Member
    2016 with just over 40k “Trailer Brake Controller error, see Dealer.” No ABS or other lights. Was intermittent in January this year but now it stays on. Anyone have any luck figuring this out?
