Boat Towing question
Discussion in 'Towing & Hauling' started by BoerboelTundra, May 19, 2020.
  1. May 19, 2020 at 2:21 PM
    BoerboelTundra
    BoerboelTundra [OP] New Member
    2020 Tundra Super White SR5
    Hey guys. I recently bought a boat. When I’m towing (in tow mode) the truck display says no trailer. I also have no brakes coming from the trailer. It’s a 21 foot tandem boat mate trailer. All trailer lights are working. 4E7B0A2E-3344-48FA-B1DE-FF164C410F56.jpg
  2. May 19, 2020 at 2:29 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Ely010606 likes this.
  3. May 19, 2020 at 2:50 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    A lot of boat trailers use a surge brake, which isn't controlled by your trucks controller. If you're not plugged into the big round jack, and only using the 4 pin blade connector then you're not hooked to the trucks controller.
    I just read up on your trailer and even though you're plugged into the 7 pin on your model, it states it uses a surge brake as standard equipment. Electric brake is optional. You can tell if it uses a surge brake by looking at it near the tongue.
  4. May 19, 2020 at 3:27 PM
    AZBoatHauler
    So.Arizona
    What he said. If you can back up without locking up the trailer brakes everything is working as it should.
    Sweet boat.
    BoerboelTundra[OP] likes this.
  5. May 19, 2020 at 3:37 PM
    Nice boat!
  6. May 19, 2020 at 4:19 PM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    Nice boat!
  7. May 19, 2020 at 6:07 PM
    BoerboelTundra
    Awesome! Yes they are surge brakes now that I’m looking at the tongue I see it. I appreciate the feedback guys!!!
    Thanks!!!
  8. May 19, 2020 at 8:41 PM
    Silver4x4trd
    Silver4x4trd New Member
    2017 Tundra SR5 & 2012 Sequoia SR5
    Jba long tube headers, dirty deeds TRD exhaust (2x24), 19+ Pro lights and grill painted sky silver, TRD rear sway bar, TRD reusable air filter, PnP sliders, pnp full set skid plates, 275/70/18 ko2’s, bully dog bdx (trail setting), c4 hybrid bumper with DD lights(sae fog and driving)
    Sick boat!
  9. May 20, 2020 at 5:53 AM
    Cpl_Punishment
    Cpl_Punishment Just live 'til you die
    Neil
    2020 MGM SR5 CM 4X4
    Nice boat!
  10. May 20, 2020 at 7:16 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    If your surge brake cylinder starts to get noisy check fluid and try bleeding. I had to replace mine. You need to check fluid occasionally. Little rubber plug on cylinder. Do not overfill.
  11. May 20, 2020 at 7:22 AM
    wakeboarder
    wakeboarder New Member
    13 Tundra
    Just came to drool over your boat!
  12. May 20, 2020 at 7:23 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    BA Boat.
  13. May 24, 2020 at 11:54 AM
    Wintersun
    Wintersun New Member
    Trailers with surge brakes should also have a special chain that activates the brakes if the trailer comes loose from the hitch. It can be a life saver.
    Cpl_Punishment likes this.
  14. May 24, 2020 at 12:18 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    It can also mess things up when your foreman drives off with the truck after unhitching the trailer but before unhooking that little cable...:rofl:
    GODZILLA and Prostar 190 like this.
  15. Feb 21, 2021 at 10:15 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Love the boat!
    @BoerboelTundra how does the Tundra do while towing the new boat?
    I'll be looking at a used 22' Centurion in a few days, I'm wondering what to expect.
    ColoradoTJ likes this.
  16. Feb 21, 2021 at 10:23 AM
    BoerboelTundra
    @MotoTundra the boat tows great! Electric trailer brakes would be a nice upgrade to have but not necessary. We have a 4 hour drive to the cabin and the truck handles the boat no problem
    MotoTundra likes this.
  17. Feb 21, 2021 at 10:29 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Great to hear, thanks for the info!
  18. Feb 21, 2021 at 12:11 PM
    Dalandshark
    Dalandshark Fortified with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    Yes. And it should be connected to the truck, not the safety chains, lol. I think 90% of them are wrapped up with the safety chain and connected to the chain hooks.
