Bmc needed for toyo 285/75/17?
Discussion in 'Wheels & Tires' started by segelflieger, Nov 7, 2017.
  1. Nov 7, 2017 at 6:09 PM
    segelflieger
    segelflieger [OP] New Member
    Az
    16 TRD DC
    Icons
    Anybody know if a bmc will be required with icon six speeds (17") and toyo 285/75/17's on a 3rd gen tundra leveled? Thx for your help....
  2. Nov 7, 2017 at 6:30 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    That puts you at about 34.8”. Going to be close but I’m going to guess most likely.
    831Tun likes this.
  3. Nov 7, 2017 at 6:35 PM
    segelflieger
    Az
    16 TRD DC
    Icons
    Am i missing a piece of puzzle, according to tiresize .com it puts them at 33.8???
    zcarpenter92 likes this.
  4. Nov 7, 2017 at 6:39 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Oh my bad. I’m so used to adding 18 not 17. You’re right, 33.8. By level, do you mean 2”? I’m sure you’d be okay with 3”, not completely sure with 2”. But I would think you’ll clear.
  5. Nov 7, 2017 at 6:47 PM
    segelflieger
    Az
    16 TRD DC
    Icons
    Eibach level, cant really remember 2.5 or 3, had a touch of bro lean til i put icon aal on rear to get rake back. They are set on top setting
  6. Nov 7, 2017 at 6:49 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    You should be fine. You may have to remove mud flaps and maybe a little trimming on the front liner.
    Bob and Tacotundra like this.
  7. Nov 7, 2017 at 6:49 PM
    segelflieger
    Az
    16 TRD DC
    Icons
    Thx
    joonbug likes this.
  8. Nov 7, 2017 at 7:31 PM
    Tacotundra
    Tacotundra New Member
    Vegas
    2017 Tundra
    Shouldn't need CMC that tire is 11.50 wide correct? If so your fine. Like @joonbug said only front flaps will have to come off. You would be able clear that tire no lift with those wheels.
    joonbug likes this.
  9. Nov 7, 2017 at 7:54 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    UCA's can play a role in this equation. If they're stock then I think you'll be fine.
  10. Nov 9, 2017 at 3:27 PM
    segelflieger
    Az
    16 TRD DC
    Icons
    actually i was wrong, eibach sport, 0,1,2 inch settings so i am at 2 for level
  11. Nov 25, 2017 at 8:08 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    What are everyone’s thoughts on 285/75/18’s. Will have a 3/1 loft on it. Currently running 275/70’s and think they’ll be too small for the new lift (6112’s highest setting currently)
  12. Nov 25, 2017 at 8:21 AM
    Too small. 295/70/18 at the min
  13. Nov 25, 2017 at 8:56 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Is that toward me or op. The 285 is taller than the 295...
  14. Nov 25, 2017 at 8:58 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Don’t aftermarket uca’s Put the tire out slightly further?
  15. Nov 25, 2017 at 9:02 AM
    You good sir. These are when I had 295/70/18..34.41”
    equin and HBdirtbag[QUOTED] like this.
  16. Nov 25, 2017 at 9:03 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Garcis senor’
    T-Rex266 likes this.
  17. Nov 25, 2017 at 9:11 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I'm not 100% sure but I don't think they do. After market UCAs move the top of the wheel farther back creating more caster. But I don't think they move the wheel out in the camber direction. I know that Camburg UCAs create more caster than any of the other common UCAs. I had 6* of caster with Camburg and struggle to get 3* with Icon UCAs. In retrospect, I like the additional caster but am not sure it would work with my Coachbuilder tie rod ends.
  18. Nov 26, 2017 at 6:37 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Btw what are you running now?
  19. Nov 26, 2017 at 6:38 PM
    equin likes this.
  20. Nov 26, 2017 at 6:39 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    My man :muscleflexing: What are the specs on the wheels? Did you have to chop with these?
  21. Nov 26, 2017 at 7:27 PM
    I had the CMC done with the original lift install
  22. Nov 26, 2017 at 7:31 PM
    TheBeast The Beach
    knobby tires... :spy::spy:
  23. Jul 24, 2018 at 8:24 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 Gasser
    Hey @segelflieger, did you ever get those 285/75r17s? I'm debating between those and 285/70s and I'm wondering if you had to do many modifications to keep from rubbing.
    Davesbase likes this.
  24. Jul 24, 2018 at 8:45 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    With that size you'll be lucky to find a "true" 34", they are all small. My cooper at3 in 285/75/17 are probably closer to a 33 once you add vehicle weight and all into account.
    Efit - nvm, didn't load the rest of the posts...disregard
  25. Jul 24, 2018 at 8:46 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    IIRC doesnt Icon advertise these to clear 35s with no major issues, aside from mudflaps and minor plastic trimming?
  26. Aug 11, 2018 at 7:48 PM
    segelflieger
    Az
    16 TRD DC
    Icons
    @BuckWallace . Yep toyo 285/75/17’s with icon 2.5’s up front.....adjustable arms kept caster and camber in specs and set for az road crown herein az. Original mudflaps on with slight mod... no rub
    BuckWallace likes this.
