Blown Fuse
Discussion in '2.5 Gen Tundras (2014-2021)' started by STP, Jul 10, 2020.
  1. Jul 10, 2020 at 6:16 PM
    STP
    STP [OP] New Member
    British columbia
    TRD air intake . Over sized wheels and tires. 4x foot well LED light bars. TRD rear sway bar Front LED light bar behind grill. Back up LED under rear bumper Front leveling kit. Pop out side steps. Three fold taunneau cover.
    replacing the step well light under the drivers side dash. I cut the wires thinking they were on the courtesy lights fuse as I had pulled it just to find out it was not. No problem, I go under the dash, find the blown fuse and replace it. Check all fuses and all are good. Power back in the wires for the LED strip.
    However, I have lost the Radio,Power locks, courtesy lights do not come on when you open the door and I cannot turn off the slippery road traction control. I unplugged the batterie in the hopes of resetting the computer but no luck
    Any ideas
  2. Jul 10, 2020 at 6:19 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Did by you by chance forget to disconnect your battery "before" you snipped some wires???? If not....all kinds of crazy shit can happen. 99.99999% of electrical weirdness posted here happens when the battery isn't disconnected first.
    timdske likes this.
  3. Jul 10, 2020 at 6:22 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2021 Super White TRD Pro
    In progress…
    You may have blown more than 1 fuse. It happens.
    Wero94 likes this.
  4. Jul 10, 2020 at 7:43 PM
    timdske
    timdske Another Old Guy
    Fort Worth Texas.
    2019 MGM SR5 4x4 Tundra TSS Offroad
    Every vehicle today has a multiplex system. Everything is connected through the ECM and BCM. I'd pull up a wiring diagram for the BCM and trace another fuse in the system. I no longer have axcess to Alldata. See if someone does.
    sf319 likes this.
