Bilstein 6112 which hardware
Discussion in 'Suspension' started by ARES, Jun 3, 2018.
  1. Jun 3, 2018 at 12:10 PM
    ARES
    ARES [OP] ARES Fabrications
    God Bless America
    2018 Tundra TRD Cement
    Hey tundra brother quick question just picked up my 6112/5160 kit and kyb top hats kit. The 6112s came with hardware so did the kyb. The washers on the kyb are larger which do I use?
  2. Jun 3, 2018 at 3:05 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    I would use the ones that came with the top hat kit. I just did mine a few weeks ago and I had to get the washers and bushings from the dealership ( 60$, WTF) because I ordered top hats without hardware. And had the long weekend scheduled to do the work and wanted it done ( took bout 1/2 day to build the shocks, install 6112's front , and 5100 rear along with new adjustable UCA's. Actually a lot easier of a job than I expected.
  3. Jun 3, 2018 at 3:36 PM
    ARES
    God Bless America
    Well I ended up using the washers that came with the 6112 kit. They seemed to have a more snug fit on the rubber bushings. I have found out that kyb is the only complete kit to get.
  4. Jun 3, 2018 at 4:07 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    apbreaux likes this.
  5. Jun 3, 2018 at 7:11 PM
    ARES
    God Bless America
    Thanks for the youtube link I followed how he installed them. I ended up going with the 3rd slot on the 6112s that was supposed to give 1.9 lift. My overall was 39.5 both rears, 39.5 passenger front and 39 driver front. Not sure why the driver side is .5 lower then the passenger side
  6. Jun 3, 2018 at 7:44 PM
    stlfan
    stlfan New Member
    DFW
    2017 Tundra SR5 4x4
    2018 OEM LED HEADLIGHTS, BAJA DESIGN FOGS, PRO GRILL & SURROUND, 3M CRYSTALLINE TINT40%, 8" SS BAM EXHAUST.
    fuel tank side, maybe
  7. Jun 4, 2018 at 7:46 AM
    Blackhawk13
    Blackhawk13 New Member
    Justin
    2012 Tundra
    Just curious. Where did you buy your 6112’s. I thought they were on back order everywhere. I’m thinking about putting these on my tundra.
  8. Jun 4, 2018 at 8:47 AM
    ARES
    God Bless America
    4wheelparts.com got my 6112s and 5160s for $900 bucks unassembled. Kyb top hat kit from Amazon. Sm5737 I believe $25.
    To me the smoothness of the ride is night and day compared to the oem suspension
    Watt maker likes this.
  9. Jun 4, 2018 at 9:05 AM
    Rngr188
    Chad
    Harrison AR
    Dumb question but when assembling them how do you orient the top mounting bolts to line up with the lower mounting hole that goes to the LCA?
  10. Jun 4, 2018 at 9:16 AM
    ARES
    God Bless America
    On the top hat theres an arrow that says out. Line that up perpendicular to the mounting hole. Once the top hat is back in the upper control arm. The bottom of the shock will move some if the hole isnt lining up perfect
    apbreaux and (deleted member) like this.
