Bilstein 6112 Height Chart
Discussion in 'Suspension' started by YotaTruckLtd, Mar 6, 2020.
  1. Mar 6, 2020 at 3:07 PM
    YotaTruckLtd
    YotaTruckLtd [OP] Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched metallic grey front and rear bumpershellz Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
    Found this chart online at toytec.com. Can anyone verify if the heights are pretty close to their setup after installation. These heights are without any shims as well. Why the difference between 4x4 and 4x2. Thanks...
    Pomp_Cat115 likes this.
  2. Mar 6, 2020 at 3:12 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Less weight upfront for us 2wd guys. Never saw that chart b4, thx. I did get a solid 3" on the front of mine, wrote the #'s down so for curiousity I will check against the chart.
    YotaTruckLtd[OP] likes this.
  3. Mar 6, 2020 at 3:19 PM
    YotaTruckLtd
    2014 MGM Limited CM
    did you use any shims on either side for the solid 3"??
  4. Mar 6, 2020 at 3:21 PM
    Nm6300'asl
    2022 DC SR5 4x4
    No shims and my truck came out level side to side as well, had a very slight lean on df stock
  5. Mar 7, 2020 at 10:09 PM
    Pomp_Cat115
    Pomp_Cat115 New Member
    Los Angeles, CA
    What were your numbers before the lift?
  6. Mar 9, 2020 at 9:17 AM
    Nm6300'asl
    2022 DC SR5 4x4
    Sorry 4 delay, #'s before 31 1/4 " lf, 31 3/8" rf
    After 34 3/4" both fronts. So right at the 3.3" the chart says.
    All measurements from bottom wheel lip to bottom fender.
  7. Apr 20, 2020 at 7:08 PM
    YotaTruckLtd
    2014 MGM Limited CM
    Chart was correct. Did installation today with 1 @BOSS4x4s shim on DS.
    Now measures 36" from bottom of rim to fender on DS and PS upfront.
    Measures 36.25" on both DS and PS on rear with @BOSS4x4s shackles set at 1.5".20200420_192554.jpg
    Hol Milk and Pomp_Cat115 like this.
  8. Apr 19, 2023 at 5:05 PM
    GreatWhiteGax
    GreatWhiteGax New Member
    2016 SR5 Silver
    Leveling Kit, Wheels & Tires
    Are you running 6112" Option #3 (1.9") or Option #4 (2.5") up front?
    What tire size you running in the photo?
    Like that stance
  9. Apr 20, 2023 at 3:46 AM
    YotaTruckLtd
    2014 MGM Limited CM
    Thanks. Running it at option 4 and currently have the Nitto TG2 (35x11.50R20). Truck looks a little different now.
    GreatWhiteGax likes this.
