Bilstein 6112/5160 Pro Form +2 shakcles
Discussion in 'Suspension' started by Garcia0904, Apr 5, 2020.
  1. Apr 5, 2020 at 4:25 PM
    Garcia0904
    Garcia0904 [OP] New Member
    Charles
    2018 Cement Crewmax 4x4 Limited
    Rhino RB20
    LONG POST LONG POST BILSTEIN 6112/5160 WITH PRO FORM FAB +2 SHACKLES
    So after researching for months and months on the forum, I have came to the conclusion that I will be setting my 18 tundra cement with the Bilstein 6112/5160. I actually have the 5100's and I'm not very happy with them. One of the shocks is already leaking and they only have 15k miles on them...anyways, I have read a lot of good info on this forum and barely anyone is running the +2 shackles from pro form fab. They look beefy AF and great for the price. My main concern is that if I put +2 shackles in the rear, would the 5160 be over extended? Additionally, would +2 shackles in the rear be ass high ?I plan to run the 6112 on the top setting which will give me 2.5 of actual lift. I just need some advice before I drop money on the lift kit and 295/70r18 tires. Thank you guys!!!
  2. Apr 5, 2020 at 5:07 PM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Myself and @xtyfighterx have the pro form 2" shackles. No problems at all. We have fox 2.0 resi's in the back.
    Rica25 and xtyfighterx like this.
  3. Apr 5, 2020 at 5:14 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    2.5 up front I wouldn’t go over 1.5” shackle in the rear or it will be really high. Pro forms are heavy duty can’t beat them for the price. If you’re off roading really hardcore then make sure the shocks accommodate the size lift you’re running. If it’s mild stuff I wouldn’t worry to much about over extending.my fox 2.0’s are rated for 1” of lift and I’m running the 2” shackle.no issues for the trails I run.
    Rica25 likes this.
  4. Apr 5, 2020 at 5:16 PM
    xtyfighterx
    Ty
    North Idaho
    Here’s mine 3/2 with fox suspension and pro form shackles. It has some rake.
    Tundyfundy, equin, Rica25 and 2 others like this.
  5. Apr 5, 2020 at 7:29 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    I have 6112/5160 and run a 1.5 shackle in the rear. Looks and rides great.
    Also running 35s
    Rica25 likes this.
  6. Apr 5, 2020 at 8:18 PM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    +3 shackle in the rear front 6112 set at 2.5 with a shim on both sides. Also have 5160s in rear. 35s with 17s
    TRDblvd and equin like this.
  7. Apr 6, 2020 at 10:14 AM
    Garcia0904
    Charles
    Rhino RB20
    Just called pro form and had them change my shackles from +2 to the 1.5. Thank you guys for all the help.
  8. Apr 6, 2020 at 11:10 AM
    TundraOCC
    TundraOCC New Member
    2020 Metalic Grey Doublecab TRD
    6112/5160. shims. +2 coachbuilder shackles. 275/70/18 BFG KO2. Bora 1.25" spacers
    I used +2 shackles from coachbuilder with 5160s. 6112 on the third notch, not the top one, and 2 of the 1/4" shims on the left, one shim on right. Front is now side-to-side level.
    overall lift is +2.5" in front and +1.25" in back. Rake is not noticeable, less than 1" overall.
    Tundyfundy likes this.
  9. Apr 6, 2020 at 3:29 PM
    xtyfighterx
    Ty
    North Idaho
    That will be perfect. Get some poly bushings to. Coachbuilder sells them.
