Best prices on Bilstein 5100's?
Discussion in 'Suspension' started by Kmaiboy, Jun 7, 2018.
  1. Jun 7, 2018 at 11:51 AM
    Kmaiboy
    Kmaiboy [OP] New Member
    2018 White TRD Sport CM
    Where can I buy and who has the best deal's?
    I noticed some people were saying you will need diff drop kit and bump stop extensions are recommended.
    Thinking about doing middle setting so I won't have the bro lean.
  2. Jun 7, 2018 at 12:18 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    T-Rex266 likes this.
  3. Jun 7, 2018 at 12:19 PM
    Rica25
    Ricardo
    Tulare
    Bump stop ate for 3 inch or higher
  4. Jun 7, 2018 at 12:20 PM
    Rica25
    Ricardo
    Tulare
    I purchased all four 5100s on Autoanything
  5. Jun 7, 2018 at 1:17 PM
    Kmaiboy
    Did you set yours at middle or top setting?
  6. Jun 7, 2018 at 5:36 PM
    Give Toytec a call. We can get ya covered.
    Sean.
    fundra_goes_west likes this.
  7. Jun 7, 2018 at 5:50 PM
    Rica25
    Ricardo
    Tulare
    Set them at top also have rear sway bar with one inch rear lift
  8. Jun 16, 2018 at 9:10 PM
    ab1653
    ab1653 Ew member
    TX
    2014 Tundra
    Has anyone tried out the bilstein 5100s from Amazon? If so are they the same thing. I am unsure if I should purchase them from there. Apparently you can get it with the diff drop kit for under $400.
  9. Jun 16, 2018 at 10:11 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    Bilsteins from Amazon are the same - just search for the correct part number to make sure you are getting the correct ones. I ordered mine from Amazon because I needed them ASAP - had first decided to do a spacer lift and then decided against it 2 days before my install appt.
    I have also ordered parts from Toytec and their customer service is great. They will make sure you are getting what you need. With Amazon you need to know exactly what you need and there is none at Amazon who can guide you.
  10. Jun 16, 2018 at 10:28 PM
    ab1653
    ab1653 Ew member
    TX
    2014 Tundra
    10-4! Since you are using the 5100s... what size tire are you using and did you do anything else. What setting are you on?
  11. Jun 16, 2018 at 10:40 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I did 5100’s on all corners and went with the middle setting and a coachbuilder shim on each side in front - this made the total lift in front ~2”. Front was level with the back. During the summer my bed is loaded with everything for my kid’s swim meets so I just installed Toytec shackles.
    For tires I am running GY Duratrac 295/65 18’s on SCS wheels with a +25 offset. Had to remove the front mud flaps and push the front liners forward.
    Coachbuilder1 and parker44 like this.
  12. Jun 16, 2018 at 10:49 PM
    CaptainJohnnySR5
    CaptainJohnnySR5 Tundra Lifer Now!
    Capt Johnny
    Winter Garden Fl
    2012 Silver Tundra 5.7 SR5 2WD DC TRD Upgraded. 2017 SR5 TSS Off Road 4x4 DC Blazing Blue. 2019 1794 White TRD Off Road 4x4 CM
    I am totally addicted to Tundra Life now!
    Did you do a lift as well or was the 5100's your lift or both?
  13. Jun 16, 2018 at 10:52 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    The 5100’s for the front are adjustable and provided the lift. Shocks alone will not lift the back so I used Toytec shackles for 1” of lift.
  14. Jun 16, 2018 at 11:02 PM
    CaptainJohnnySR5
    Capt Johnny
    Winter Garden Fl
    Ok I have a RC 3" lift level kit now and wonder if I went with 5100 would it get me up a bit more before I add my new rims and tires? My rims are 18x9 with +18. Tires I want are 35x1150 or 1250 18 Nitto Trail Grapplers. I am so stuck right now. Ughhhhh I dont want to rub or give up 35's
  15. Jun 17, 2018 at 3:31 AM
    Tundramoney
    Tundramoney Old school
    Earth
    TRD pros come with a 2” front lift from the factory they don’t have a diff drop or bump stop extensions
    Big J and Kmaiboy[QUOTED][OP] like this.
  16. Jun 21, 2018 at 3:33 PM
    ab1653
    ab1653 Ew member
    TX
    2014 Tundra
    Well... this just happened! Let’s hope I get the look I’m going for. Bilstein5100s front and rear.
    parker44 likes this.
  17. Jun 21, 2018 at 5:45 PM
    CaptainJohnnySR5
    Capt Johnny
    Winter Garden Fl
    Let me know what happens. I am interested in 4 of these but Im so confused about them. I have a 3-1.5 rear RC lift kit I just put in. Will these raise the truck even more more? I have not been able to find a straight anwer on here. I am installing 33x12.50x18 Nitto Trail Grapplers on 18x9 Rims tomorrow. I have stock shocks now. I will be towing a 30 ft Catamaran boat 10,000 lbs. Will these handle it? I need more information so I can buy them already.
  18. Jun 21, 2018 at 8:08 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Adding 5100's to the front won't lift your truck any higher than what it is now. On their own they are adjustable for height but when combined with a lift Bilstein wants the ring in the bottom groove, which is basically the stock height setting. 5100's on the rear should help with overall ride quality but isn't going to help with extra weight support. For a boat that heavy I'd be looking at Timbren springs or airbags.
  19. Jun 21, 2018 at 9:24 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    We normally set the 5100's up on the top setting and then use a few of our Coachbuilder shims to correct the lean in the front left corner and add a touch more height. This is accomplished by using 2 shims on the driver side and 1 on the passenger side. the truck sits level left to right at 3"up front. A front diff drop is great a great idea at this height. We build front bump stop extensions but don't normally use them with the 5100's.
    If only setting them at the middle setting you'll end up with about 1.75", ride quality is great but would still recommend using 1 of our shims on the driver side to correct the lean. No diff drop needed.
    Hope this helps.
    https://shop-coachbuilder.myshopify...ilder-strut-coilover-shim-provides-50-of-lift
  20. Jun 22, 2018 at 4:45 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    As another poster said, I don't think you are supposed to put the "lifted" version of the 5100's on with another spacer kit. Also with the 3/1 kit you have on, you will be fine running the 33's. It would probably start looking like the tires are too small if you go over where you are with the lift.
  21. Jun 30, 2018 at 5:29 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
