Bilstein 5100 stock tires
Discussion in 'Suspension' started by Toyman, Jan 19, 2017.
bilstein 5100 with stock tires
Poll closed Jan 26, 2017.
  1. Top setting
    5 vote(s)
    71.4%
  2. Middle setting
    2 vote(s)
    28.6%
  1. Jan 19, 2017 at 8:57 AM
    Toyman
    Toyman [OP] New Member
    2012 Dc Sr5 5.7
    Anyone have stock 275/65 18 tires with 5100's on top setting? Do they look to small? I want the level look but I do tow a Travel Trailer about 6000# so I need a lil rake. Im considering mid setting it may need a small lift in rear anyway. Any advice? Thanks!
  2. Jan 19, 2017 at 2:07 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    If you need a little rake, and don't add anything to the back. you'll probably want the middle setting.
    Toyman[OP] likes this.
  3. Jan 19, 2017 at 3:15 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    I would do the middle setting if you don't mind a little rake. 6000 lb trailer won't be a problem at all, but you may consider airbags even when running your weight distribution hitch. Just something to research. FYI......A lot of people don't really think about airing up their tires when towing, but I run my 80psi rated tire around 60 psi when towing. Yes, equal air front and rear, cuz if your W/D hitch is set-up correctly, you're distributing equal weight to your front end too. Good luck with all.
  4. Jan 19, 2017 at 3:53 PM
    oul
    oul Old New Member
    Larry
    Huntington Beach, CA
    2017 Tundra White SR5 TRD Off Road CM
    5100's mid setting on front with stock wheels and ko2 275/70R18
    SmokeyTT likes this.
  5. Jan 19, 2017 at 4:45 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    i have 6112's on the 3rd setting and find my tires look a hair on the small side and i'm running 285/55/20's. my next set will definitely be at least an inch larger.
  6. Jan 19, 2017 at 4:47 PM
    SoCalTundra213
    SoCalTundra213 New Member
    07 Limited DC
    I had the 285/65/18s and totally agree that they look too small.
    These 295/70s look MUCH better.
    CM-LENNY and zcarpenter92 like this.
  7. Jan 19, 2017 at 5:55 PM
    Toyman
    2012 Dc Sr5 5.7
    That's tough lookin nice!
  8. Jan 19, 2017 at 6:01 PM
    Toyman
    2012 Dc Sr5 5.7
    Thanks for the replys now I'm thinkin mid setting. Just got new take off stock wheels and tires so I'm thinkin a small wheel spacer to push them out would help them look wider.
  9. Jan 19, 2017 at 6:19 PM
    SoCalTundra213
    07 Limited DC
    Thanks man! Forgot to mention I'm on 6112s on top setting with 5100s in the back.
