BFG KO2's & balancing beads?
Discussion in 'Wheels & Tires' started by Fotnot, May 2, 2019.
  1. May 2, 2019 at 5:11 AM
    Fotnot
    Fotnot [OP] SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    So, I have been informed of balancing beads, but not the typical ones. These are Counteract Balancing Beads. They are EXTREMELY small, and have had good reviews apparently. I have never heard of or much less, had any experience with these. Website says as a rule of thumb, about 1 oz per 16 lbs of tire. Can be added in via the valve stem by removing the core first. A buddy of mine did this with his truck (not KO2's) and said they work very well on his F250...DIDN'T EVEN BALANCE THE TIRES FIRST! Said he just mounted, then put in. Reading online seems to prove it is a good product. I have the KO2's on now, but they're just stock. Once I put on my 6" lift, I'll be getting the same tire, but in a 35x12.5R20. Thinking of trying these out to see how they work. Not sure if anyone else has heard of them or used them. I don't care about this aspect, but the website shows it improves mileage, which I just laughed at....but who knows! Anyone ever try or heard much about them? Thanks for input! Also...they're supposedly TPMS safe!
    Black Wolf and BTBAKER like this.
  2. May 2, 2019 at 5:30 AM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Never heard of them but I could use them. One of my KO2s is bad and still shakes after 8 balance jobs.
    If you use them post back please.
  3. May 2, 2019 at 5:34 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Been in the 4x4 Jeep community for a while now. Never saw it used in anything over 37s and no one ever said the balancing got sketchy as the size (tire) increased. Good way to avoid busy tire shops and those that balk over anything 33+
    https://youtu.be/4qThCEASfy0
    :turtleride:
    Black Wolf likes this.
  4. May 2, 2019 at 6:10 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    It will be a while before I get to put new tires on. My KO2's only have 37k on them, and looks like I got another 25k on them to go (both a blessing and curse of having them...they last a while! lol). What size you running on yours?
    Those are different. I've seen stuff for Dynabeads. Have you seen people use the Dynabeads....or the Counteracts? Just curious to clarify which ones have worked. Also, assuming those jeeps had them used on something between 33s and 35s...they used them on the streets fairly often?
  5. May 2, 2019 at 6:19 AM
    Wiscdave
    Wiscdave New Member
    Northern Wisconsin
    19 Tundra Sport
    Old ride 13 RW BA budget, 3/2 lift JL W7
    Only needed if you can't get using normal weights. Usually only use these if you rim is bent or its a bigger tire than a 35 -Semi's run these quite often
  6. May 2, 2019 at 6:30 AM
    Tierhog
    Tierhog SIG-AHOLIC
    I've never seen the ones you've mentioned. It appears they work the same however.
    The majority of the Jeep guys I know DD their trucks, hence the need. A few folks built super Jeeps and trailered them around like royalty. They never mentioned them. They would be all about beadlocks and slow crawling, a balancing was done at purchase and you never heard about it again.
    I was on 35 MTR Kevlars and balanced them traditionally. If I noticed I lost a weight I'd rebalance them. TBH more folks over inflated tires then anything (road use) but I digress.
    I guess if your rotating, you can balance traditionally. Maybe an overland style Tundra owner will chime in. I'm not in the granite, mud, and trails anymore so my experience isn't vehicle specific.
  7. May 2, 2019 at 6:31 AM
    LML 3500HD
    I tried these before with very crappy results. Some people have good luck, but after 50 mph it was horrible. Wheels and tires balanced before install.
    BTBAKER likes this.
  8. May 2, 2019 at 6:42 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I found some available near me that was at a Love's truck stop. Started thinking it was used primarily for them. Also noticed I've seen them noted in use in motorcycles.
  9. May 2, 2019 at 6:47 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    On my tundras 37s they were bad. Sounds like your experiance as well. The 37s on my excursion have the beads and are smooth as a traditional balance. No idea why..
  10. May 2, 2019 at 6:54 AM
    LML 3500HD
    That whole ordeal cost me dearly. Paid for the beads, then a dismount and vacuum out, remount and balance. I’m not sure they didn’t get all the beads out either.
  11. May 2, 2019 at 7:07 AM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    We use airsoft bbs on our rigs with beadlocks. Work fine for trailrigs that do some street. Have had them up to 65mph and they arent smooth, but they are as good as Iroks on beadlocks are going to get.
    Tierhog likes this.
  12. May 2, 2019 at 8:35 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I’ve used the dyna balance beads before. Worked perfectly with some bfg. I will use them again in the future
  13. May 2, 2019 at 8:41 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    What sizes were you running on your BFG KO2's?
  14. May 2, 2019 at 8:50 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    This was on my 2005 with 285/75/16. I haven’t used them since that truck
    Fotnot[QUOTED][OP] likes this.
  15. May 7, 2019 at 6:39 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    I had something like that when I ran 40 super swapper boggers. Did really well. No to think about it might have been power in them so I wouldn’t have to true my tires
  16. May 7, 2019 at 7:36 PM
    BlueDream
    BlueDream New Member
    2015 Tundra Dbl cab SR5 5.7
    6" procomp stage 3 lift, Method NV 18x9, Cooper STT pro 305/70R18, AFE air cleaner, LED fogs, Ranch hand Grille guard, Rhino liner, retrax bed cover, Flowmaster Duals, 15% Tint, vinyl chrome delete
    From What I understand is these balance beads are to be used Without any additional wheel balance weights. Probably why they didnt work is you still had the other weights on.
  17. May 7, 2019 at 7:46 PM
    LML 3500HD
    I tried both ways. I talked to counteract several times. I gave up.
  18. May 7, 2019 at 9:50 PM
    Tundyfundy
    Southern California
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    The shop installed these on my K02’s. Felt horrible. Had another shop vacuum them out and do a true balance and it feels amazing. 275/70/r18. Will never use beads as long as I can help it. Also apparently they don’t work until your speed is high enough to hold them to the inside of the tire. Also abrupt bumps or jars to the tires unseat the beads. Seemed janky to me.
