Best way to remove tree sap
Discussion in 'Detailing' started by Freezy, Aug 1, 2019.
  1. Aug 1, 2019 at 3:56 AM
    Freezy
    Freezy [OP] New Member
    Anyone have any tricks to remove tree sap from a tonneau cover? Soap and water just isn't doing it. Thanks
  2. Aug 1, 2019 at 4:00 AM
    stewtopia
    stewtopia 4RunningTundra
    Stew (nickname)
    Masshole
  3. Aug 1, 2019 at 4:03 AM
    War Machine
    War Machine SSEM # 5 3MW
  4. Aug 1, 2019 at 4:21 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    WD 40 on the cover if its vinyl. On the paint Goof Off works great. I just wash the area and re-wax to be safe. I have a vinyl cover and I never used Goof Off cause I never have sap on it. If you try it be careful for fading etc, not sure if it will or not. Hope this helps.
  5. Aug 1, 2019 at 4:23 AM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    I use rubbing alcohol on the paint or glass.
  6. Aug 1, 2019 at 5:04 AM
    stewtopia
    Stew (nickname)
    Masshole
    Oops, my bad
  7. Aug 1, 2019 at 6:04 AM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    WD40 works great even on the paint. Had a pine tree in front of a house for awhile and did this often.
  8. Aug 1, 2019 at 6:06 AM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    Hot hot water on a rag put the rag on it let it sit for a couple mins will take a bit
    But your not using chemicals which is good
    Pudge likes this.
  9. Aug 1, 2019 at 3:00 PM
    Freezy
    Never knew that about the dryer sheets. It's on the cover so maybe i'll give WD40 a try. just didn't want to fade it, it's on the vinyl.
  10. Aug 26, 2019 at 10:40 AM
    WhiskeyVictor
    WhiskeyVictor New Member
    Vermont
    2019 Tundra Limited MGM
    Go Rhino RB20, DiamondBack HD Coated, Black Badges
    Pine tree sap is pretty easy using alcohol. The 91% isopropyl from Walmart or CVS works very well. It will melt in a few seconds of rubbing (even old dried stuff), but try not to rub more of an area than you need as it spreads a thin film of sap that still requires alcohol to dissolve. I typically use three paper towels for the initial dissolve, heavy cleanup and finally the finish as it isn't pulled into a cloth/towel as much as other things you might be used to cleaning up. Don't spare the alcohol.
    -WV
    Freezy[OP] likes this.
  11. Oct 21, 2019 at 4:16 PM
    AYANG
    AYANG New Member
    Ontario, CA
    2016 Black Tundra Crewmax
    Great info, gonna try the WD-40 this weekend on some that have been stuck for like a month
  12. Oct 21, 2019 at 4:19 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Cut down the damn tree:rofl:And problem solved :thumbsup:
    NUDRAT and T500 like this.
  13. Oct 23, 2019 at 9:59 AM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    CHAIN SAW
    T500 likes this.
  14. Oct 25, 2019 at 6:21 AM
    briarpatch
    briarpatch New Member
    unscented hand sanitizer
    Pudge likes this.
