Best place to tap into dash light circuit?
Discussion in 'Lighting' started by NewImprovedRon, Nov 25, 2015.
  1. Nov 25, 2015 at 10:59 AM
    NewImprovedRon
    NewImprovedRon [OP] Hey! Get off my grass!
    Ron
    Bentonville, AR
    2015 Radiant Red TSS Doublecab 4X4 Off Road
    Deck rail system, Bed divider, door sill protectors, LED reverse light bars, Aries Bull Bar with 28" 180 watt LED light bar, LED step lights, LED bed lights, driver-side grab handle, TRD Rear Sway Bar, BedRug bed mat and tailgate mat, Morimoto Fog Lights, more to come.....
    I'm getting my plans in order to install a Stealth 32" light bar, from Headlight Revolution, in my 2015 Tundra grill. I plan to use all the components with the kit, except for the light switch, which I plan to get from AirOnBoard to give the install a more OEM look. My question is where is the best place to tap into the dash light circuit? I want to have the switch illuminated along with the rest of my dash/switches when I have my lights turned on. My initial plan is to tap into the circuit at a neighboring switch's location (door light switch or headlight leveling switch unless the blank switch location has wiring connector behind it for the blank) and to find the power wire by checking the wires to it with a multimeter when the lights are turned on. The new switch would be on the lower left side of the dash to the left of the steering column. That way I only have to unscrew the lower left side bolt that holds the lower dash on to gain access. Is this a good plan or is there a better place to tap into my dash light circuit? Thanks for any help!
  2. Nov 25, 2015 at 2:46 PM
    Cutter29
    Cutter29 ...
    Utah
    2015 Super White TRD PRO
    Subbed for the same info. I haven't got around to hooking that wire up yet.
  3. Nov 25, 2015 at 6:48 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Pretty much every OEM switch on your dash has an illumination wire. I usually just tap off of the nearest OEM switch to where I'm installing the new one.
    NewImprovedRon [OP] likes this.
  4. Nov 25, 2015 at 8:53 PM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    I just shaved off a little bit of insulation from the tow haul button, Soldered the light bar backlight wire to the tow haul one and electrical taped it back up.
    I used a volt meter to figure out which was the back light, I wanna say it was a green color.
  5. Nov 25, 2015 at 8:54 PM
    TNTundra08
    Blake
    2008 DC 4x4
    A tap would probabLy be simpler but the wires were suuuuuuper little and I didn't have any on hand so I did it that way
    MyFj08 and NewImprovedRon [OP] like this.
  6. Nov 26, 2015 at 7:54 AM
    NewImprovedRon
    Ron
    Bentonville, AR
    Thanks for the replies and pictures, Gents! Does anyone know if the blank switch locations have wiring connectors behind them in the harness?
  7. Nov 26, 2015 at 7:55 AM
    NewImprovedRon
    Ron
    Bentonville, AR
    Is that an AOB switch you used? Looks great, by the way.
  8. Nov 26, 2015 at 1:02 PM
    TNTundra08
    Blake
    2008 DC 4x4
    Yes AOB, I wanna say $23 a piece. I thought I had a picture of them lit up. I did red back lighting to match stock, then the image lights up green when turned on.
    Then for your question when you pop the square piece out that has the blanks there was nothing back there, a cluster of hires maybe 4 inches away and only the 2-3 wires needed to reach the tow haul button. There is plenty of room to work with. I used a coat hanger to shove my wiring down below the dash and did most my work under the pedals since my light at wires ran through the rubber grommet on the driver side(if that's what you meant)
  9. Nov 26, 2015 at 1:52 PM
    NewImprovedRon
    Ron
    Bentonville, AR
    Thanks for the added comments, Blake. I was wondering if the blank/unused switch locations have the wiring harness for the switch/option that would normally be in that location. Doesn't sound like it is... I'll proceed with my plan to tap into a neighboring switch illumination wire. Thanks again for all the help!
  10. Nov 26, 2015 at 1:55 PM
    Cutter29
    Cutter29 ...
    Utah
    I didn't see any extra wires behind the blank on mine. Access and install was pretty easy to figure out by using common sense. I ran my wire harness through the firewall plug, hooked up the switch to test then pushed it into where the blank was. Super easy. Just haven't taken the time to hook up the back light yet.
  11. Nov 26, 2015 at 2:10 PM
    NewImprovedRon
    Ron
    Bentonville, AR
    Thanks Cutter29!
  12. Aug 23, 2017 at 6:01 PM
    Kmd
    Kmd New Member
    Which one was the switch illum wire?
  13. Aug 23, 2017 at 6:50 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  14. Aug 23, 2017 at 7:02 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    BlueBottle likes this.
  15. Aug 23, 2017 at 7:26 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    LoL lmao
  16. Aug 23, 2017 at 7:58 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    How did you get the blank out?
  17. Aug 23, 2017 at 9:03 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    best to remove the entire lower panel and unclip It from the back. Its only held by 2-3 screws and the rest are clips.
  18. Aug 24, 2017 at 3:10 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I am guessing that the screw on the left side is behind the kick panel since someone said to take kick panel off
  19. Aug 24, 2017 at 6:05 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yes I do remember taking off the kick panel.
  20. Aug 24, 2017 at 6:22 AM
    NewImprovedRon
    Ron
    Bentonville, AR
    light blue wire in neighboring switch.
    Kerch71 likes this.
  21. Feb 1, 2018 at 1:08 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    This helped me a lot. Now I can backlight my camera switch.
  22. Jul 24, 2018 at 10:53 PM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    Is it the light blue wire on all the neighboring switch?
  23. Jul 25, 2018 at 7:12 AM
    NewImprovedRon
    Ron
    Bentonville, AR
    I believe the VSC Off Switch, Interior Dome Light Switch, Cargo Light Switch, and Headlight Leveling Switch all have a light blue illumination wire.
    Kerch71, Pudge and nk1794 like this.
  24. Jul 25, 2018 at 9:43 AM
    SpeshulED
    But won’t be controllable via dimmer?
  25. Jul 25, 2018 at 10:12 AM
    NewImprovedRon
    Ron
    Bentonville, AR
    Just checked mine and the back-lit switch I used does not dim with the other switches when the dimmer control is turned.
    SpeshulED likes this.
  26. Sep 30, 2018 at 6:07 PM
    neoblueb
    neoblueb New Member
    2015 Tundra Platinum
    -Southern Toyota wheels with Nitto Ridge Grappler 295’s - Aries bull bar with xprite 26” led bar -All lights upgraded to LED -Custom switches for all Accessories - Grill mounted Radar/laser detector - Light strips in bed
    Just finished woring up mine. Used a fuse relay box from eBay so I could run all small wires back to the cab. Also bought the replace right panel made to house a brake controller and put a 3gang switch in it. Worked out perfect and couldn’t look any better imo.
  27. Dec 7, 2018 at 4:01 PM
    TheBeast The Beach
    some good info here
  28. Dec 7, 2018 at 6:21 PM
    zlaneb
    zlaneb New Member
    Austin, TX
    very good info! I bought a couple of switches to change out my stocks (better/fun graphics) now I feel a little more secure about how to pull the OEMs out and replace them.
  29. Jun 3, 2019 at 4:21 AM
    2011crewmaxplatinum
    2011crewmaxplatinum New Member
    What about the TOW haul is that the same as well? I saw someone write above that it was the brown wire. I just hooked up my lights but that’s the only thing I haven’t wired yet.
  30. Jun 3, 2019 at 4:48 AM
    :threadjacked:
    Welcome from NY.
