Best LED light bar for bumper DIY
Discussion in 'Lighting' started by GABoy, Feb 20, 2021.
  1. Feb 20, 2021 at 3:41 PM
    GABoy
    GABoy [OP] New Member
    2014 Limited TRD CM Magnetic Grey
    What’s the best and brightest LED light bar to fit down inside bumper area? Looking for size, brand, and install instructions. Thanks!
  2. Feb 20, 2021 at 4:06 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    How much do you want to spend? I got one for $150 and it lasted a month before it filled with condensation. Have had this 42 inch rough country for a couple years with no problems. Bright as hell. This one was $400. Install is easy. Takes 30-45 minutes
  3. Feb 20, 2021 at 4:22 PM
    GABoy
    Looks great! I’m looking into the Caliraised or some brand of 32” for under the bumper inset area. Want the brightest and best quality fir that fit. Read great reviews of your RC 42 bar.
    War_Wagon312 likes this.
  4. Feb 20, 2021 at 4:26 PM
    War_Wagon312
    Rich
    2016 Pro MGM CM
    Can’t go wrong with caliraised. Some guys luck out with $100 Amazon ones. Luck of the draw. I have learned buy once cry once because I never luck out lol.
  5. Feb 20, 2021 at 6:34 PM
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    I can’t help with what size would fit the best in that area. But I highly recommend you check out Black Oak Led. It’s a smaller
    family/Vet owned company out of Florida. I’m not affiliated with them in any way, I’ve just had fantastic experiences with their customer service and quality of their lights. They throw ridiculous amounts of light. You won’t be disappointed.
    GABoy[OP] likes this.
  6. Feb 20, 2021 at 7:12 PM
    Kdogg77
    Kdogg77 If it ain't broke, it will be...
    Ken
    Central Cali
    2017 Tundra Crewmax
    6" RC suspension lift, 18" Pro Comp wheels, 35x12.5x18 tires, RC front/rear bumpers, RC Grill insert, Spider No Drill Roof Rack, Lighting by RC and Cali Raised. Interior mods include AJT Designs, Pioneer, and Rockford Fosgate.
    I have the RC light that fits in the spot you are looking at (hint hint). Just bought a brand new harness for it so I can sell it. Came out of my truck after 2 months because I bought the RC front bumper that had a light in it.
  7. Feb 21, 2021 at 12:51 PM
    ToyotaManager
    ToyotaManager Toyota GSM
    Corey
    Georgia
    2020 Tundra Double Cab 4x4
    3”x1” Lift Painted front end to match. Painted back of mirrors. LED light bars, upper and Lower front. LED running and Fog Interior LED’s. LED tail lights and 3rd light. Underneath LED’s. LED strip for braking and turn signals. Lock and Roll power Tonneau cover. Locking tailgate. Swing out tool box in rear. Bed step. Leather Heated seats. Amplifier with upgraded speakers with 2 Subs. Carven R mufflers Emblem black outs TRD sway bar. Red Caliper covers. Parking sensors Blind spot monitor. X Series Black 20” Gunner wheels with 37” all terrain Ridge Grappler tires.
    I Used Nilight. Very bright! 41” for the hood and 31” for the lower. I used the CH4x4 push button.
    Vang530 likes this.
  8. Feb 26, 2021 at 2:23 PM
    WhiteStar20
    WhiteStar20 New Member
    Dennis
    Okotoks, AB., Canada
    2020 Tundra Platinum CM
    Rockstar XD 20” rims, BAK Bed cover, TRD Dual Exhaust, etc., etc...
    Do you have a build site with pics for these installations? Thanks
  9. Feb 28, 2021 at 7:33 AM
    Asolo
    Asolo New Member
    2020 MGM Platinum CM
    BD Squadron pros,S2 pros, S1, 30” ONX6+, SwitchPros
  10. Feb 28, 2021 at 8:03 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Eyourlife from eBay going on 8 years now no issues was on my Tacoma for two years before the tundra. The relay harness it came with started to corrode at the connectors so I had to cut them off off and add new ones after 8 years also a ch4x4 switch both light bars are on the same relay harness and switch no issues. For the lower bumper I had to drill a lower hole in the foot brackets they all come with them drill them straight into the aluminum crash bar behind the bumper lined up perfect super easy and fast install took me 45 min to pull the center valance off drill the holes and tap the two bars together since the relay harness was already ran for the grill light bar.
    AZTundra likes this.
  11. Feb 28, 2021 at 8:19 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Step 8, “Patience will be required for this step.” That is a massive understatement lol. But those instructions are about the best I’ve seen and pretty much how I ended up hacking my way through my own install.
  12. Feb 28, 2021 at 8:29 AM
    xtyfighterx
    Ty
    North Idaho
    You don’t even have to remove the bumper to install just remove the center valance there’s a couple plastic clips that connect to the bumper ends that ended up breaking but it’s held in by multiple bolts and screws so really those clips don’t do much for support if you don’t mind that. I tried a flat head screwdriver carefully and got like two the rest just snapped very easily so I completely left the ones I saved out and didn’t by replacements. if that bothers you then remove the whole bumper. I did it this way for ease of accessing later on if there’s issues with the light bar or if I want to remove or replace it. there’s a YouTube video online I can find if anyone wants to try this route.
    edit: that baja designs instruction link is perfect like everyone said to be patient with the plastic clips if they break no big deal it won’t affect anything.mine installed back like factory not loose anywhere.
