Been changing oil every 10k. Did this affect my car?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ealxele, Jan 24, 2023.
  1. Jan 26, 2023 at 8:47 AM
    #61
    TundraClayDigger
    TundraClayDigger New Member
    2018 Crewmax Limited 4X4
    If you have tow hooks you may safely go 10K mile oil changes.
  2. Jan 26, 2023 at 9:23 AM
    #62
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    We see reading comprehension is not a prerequisite for this forum.
    akmerle and Leo's first like this.
  3. Jan 26, 2023 at 10:01 AM
    #63
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    :rofl::rofl:
  4. Jan 26, 2023 at 10:14 AM
    #64
    Wallygator
    I follow the recommendation from Toyota for my use case. I change the oil every 5000 miles.
    Saltyhero13 likes this.
  5. Jan 26, 2023 at 10:51 AM
    #65
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I saw a video where the guy talked about Super Tech (WalMart) synthetic oil. He said WalMart buys oil in bulk and it could be Pennzoil or Mobil 1. He said you can tell which one by the container. Last time I changed my oil I used it because they did not have what I normally buy.
    Wallygator likes this.
  6. Jan 26, 2023 at 11:00 AM
    #66
    king.cong.1119
    king.cong.1119 New Member
    it's a long video but very very good information. I started doing 5k interval after I watched this.
  7. Jan 26, 2023 at 11:52 AM
    #67
    kevine0001
    kevine0001 New Member
    Kevin
    5k. mine is pretty dark after 5k. i only put about 7-8k miles on my truck per year as it's not my daily. but when i use it, it's mainly for hunting/fishing and camping. not the hardest miles but the oil is usually pretty dark. oil is cheap
  8. Jan 26, 2023 at 12:13 PM
    #68
    Abos
    Abos Long live 5.7L V8
    2014 SR5 Crewmax
    Funny you mention that. I just got my truck at the end of 2021 and I had a year of free oil changes. I put about 10k on my truck so it did work out to a little less than 5k between changes but I noticed the last sticker they put on, they only put it for 5k out from the mileage at the time. It's funny, the previous sticker actually had a higher mileage than the new one they put on. Lol. It's like, yeah, now that they aren't free, you'll say 5k but when they were free, it was 10k or 6 months.
    Going forward, there is no way I'd go 10k.
  9. Jan 26, 2023 at 12:23 PM
    #69
    Shamrock92
    Shamrock92 New Member
    Why not ask a less controversial topic like which oil should you use OP ?
    Just kidding - it’s a common debate and everyone has an opinion. Here’s mine:
    - Change oil as often as you can reasonably afford and as your use dictates with the best quality product that YOU trust.
    - Everyone will tell you XYZ brand is better because….the truth is most are very similar and a few are legit not as good. The price paid has very little effect on the quality of name brands - the cheap stuff is probably cheap for a reason and the super pricey stuff is expensive for a reason and that reason is likely profiteering and advertising.
    - 5k for conventional oil under any use/condition - 2x yearly.
    - 5k synthetic under dirty conditions/heavier use and short trips - 2x yearly. Even more if towing 50% of those miles shorter distances frequently.
    - You can get by with 10k synthetic on highway miles - light use - but likely best to do it at least 2x yearly.
    Bottom line / if you can DIY - it’s a $25 investment in your vehicle and takes less than an hour. No reason to cheap out in a vehicle and too much that can go wrong.
    My old Chevy - I changed it 2-3x yearly and I probably only put 1500 miles on it before each change. Overkill - likely - but it was a 2012 Silverado 1500 with a V6 that was notorious for mechanical issues if you didn’t keep fresh oil in them. Better to “waste” a little oil than replace an engine to me - and I’m a lot better at changing oil than doing “real” mechanical work.
  10. Jan 26, 2023 at 1:22 PM
    #70
    CTundraForMe
    CTundraForMe New Member
    I agree with you Shamrock. Except for the $25 investment? $3.125 a quart, not including the oil filter?
    The only thing I'd add is if you're willing to spend $50,000 or more on a truck, why go cheap on fluids??
    Henry1jg, Shamrock92 and Saltyhero13 like this.
  11. Jan 26, 2023 at 2:08 PM
    #71
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    If you've been using your truck as a DD it's probably fine to stick with 10k. Best way to determine that is an oil analysis.
    I have about 14,500 miles on my 2021 right now. I've DIY'd the maintenance from day one. First oil change was at 2500 miles on the odometer and the second was at 7500 miles on the odometer with 5w30 Pennzoil Platinum. Globally the exact same 3UR-FE uses 5w30; 0w20 is to help gives these big beasts a fuel mileage bump. I noticed a drop of about 1 mpg while empty but the engine is a lot quieter with the 5w30. I tow a 5k travel trailer about half the time and while towing there was no difference in MPG between 0w20 and 5w30. I'm going to do an oil change at 15,000 (total of 7500 on the PP 5w30) and send a sample to Blackstone for analysis. If it comes back good to go running through the heat of summer and cold of winter I'll likely keep 7500 miles intervals.
    The 3UR-FE is supposed to be pretty easy on oil. Between the oil cooler and nearly 8 quarts of oil this is not surprising.
  12. Jan 26, 2023 at 2:15 PM
    #72
    CTundraForMe
    I just ordered 9 quarters of 5w30 amsoil. I would think something with a higher second number might be best for the temps I get down here in southern AZ, but none of the oils listed on the spec pages I've seen go above 30.
    But it's better than 20! Will see how it goes...
    NewImprovedRon likes this.
  13. Jan 26, 2023 at 2:27 PM
    #73
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I switched to 0W-30.
  14. Jan 26, 2023 at 4:12 PM
    #74
    Retired...finally
    This is why I take anything on YouTube with an Ohio Turnpike salt truck load of salt. Look at the moola this guy rakes in. Controversial subjects get hits.
    https://socialblade.com/youtube/c/thecarcarenut
    Black Wolf and Leo's first like this.
  15. Jan 26, 2023 at 5:39 PM
    #75
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    You are certainly evidence of that.
    People who use their truck as a truck will meet the maintenance guide’s definition of “special operating conditions” and will require a 5,000mi OCI.
  16. Jan 26, 2023 at 5:55 PM
    #76
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    The spec sheet I posted shows 15w40 and 20w50 right on it. I have run 15w40 in the summer no problem. I wouldn't suggest 20w50 unless you're in Saudi Arabia though.
  17. Jan 26, 2023 at 6:04 PM
    #77
    Wallygator
    Good for him! He is using his experience as a Toyota master tech to make serious side money on YouTube. :thumbsup:
  18. Jan 26, 2023 at 6:16 PM
    #78
    Wallygator
    His best video on the subject IMO
  19. Jan 26, 2023 at 6:47 PM
    #79
    eagleguy
    eagleguy New Member
    I say the trans cooler and change oil at 5K, just because.
  20. Jan 26, 2023 at 7:13 PM
    #80
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    I crawl under my truck at each gas station refuel and change it right then and there.
    5000 mile oil is way dirtier and less protective than changing at 500 miles - FACT.
    It’s just money!
  21. Jan 26, 2023 at 7:37 PM
    #81
    Ericsopa
    Ericsopa Old man and the sea
    Some gonna have OCI OCD. That's just the way it is.
    Leo's first likes this.
  22. Jan 26, 2023 at 7:54 PM
    #82
    Leo's first
    Groton ma
    :rofl::rofl:
    Do you at least buy the oil from the same gas station?
    2WD[QUOTED] likes this.
  23. Jan 26, 2023 at 8:03 PM
    #83
    2WD
    2WD New Member
    Great question. I get it through Amazon with their subscription option. Always carry 12-18 qts in the bed.
    Forgot to also mention when that first maintenance minder light comes on 7-10k miles, I head straight back to the dealer. It's time to trade it in for a new Tundra. That engine is cooked! So much wear at that point vs new.
    It's just money!
    hagrid likes this.
  24. Jan 26, 2023 at 8:37 PM
    #84
    Terndrerrr
    Terndrerrr guzzling dealer repellent
    Music City
    Dual 5.7s
    TRD Fox, RAS, 285/75 DTs, dual battery, SS3 Pro
    Yes, changing at 0.5k miles is unnecessary. That doesn’t mean that changing at 5k miles is unnecessary.
    If you tow, use a car top carrier, drive while heavily loaded, take less than 5 mile long trips in freezing temps, drive on dirt roads or dusty roads, excessively idle your truck, or use 5w20 oil, Toyota recommends 5k/6mo OCI per the maintenance guide.
  25. Jan 26, 2023 at 10:47 PM
    #85
    Joe333x
    Joe333x Member
    Boston
    This is also right in Toyotas FAQ
    Source: https://support.toyota.com/s/article/What-are-the-oil-chan-7604?language=en_US
    People just dont want to hear it and Toyota doesn't really want to advertise it for two main reasons. People are lazy and cheap and dont want to change it more often and number two, they would have to foot the bill for more oil changes on cars that they sell advertised with free maintenance. Will you destroy your engine not changing it every 5k, no. Will your engine be cleaner and more likely to last longer if you do, yes. To the knuckle head talking about changing their oil every 500 miles to be a smart ass. You're actually correct, changing your oil every 500 would be even better than every 5k but its about cost and benefit, obviously changing every 500 miles is a crazy cost with out much benefit, but changing every 5k provides a solid benefit with a minimal cost. I could really care less at what milage anyone decides to change their oil, if you want to pay for an oil analysis that costs as much as an oil change to hear that you can change your oil every 20k, go for it. But for people to tell others they shouldn't change it sooner is just silly.
  26. Jan 27, 2023 at 5:33 AM
    #86
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    Talk to any professional engine builder, precisely zero recommend going even 5k on your very first oil change. There is a lot of very fine metal particulars floating around in the oil from all the new internal parts seating and breaking in. There’s also a lot of engine assembly lube getting washed off the parts and ending up in the oil. Can you be sure the oil filter is catching all of the metal parts? I’d rather spend an extra $100 to change the oil a few extra times when an engine is new to ensure a long life span. Oil is cheap, engines are not.
    stevesgraytundra likes this.
  27. Jan 27, 2023 at 5:41 AM
    #87
    king.cong.1119
    I don't see anything wrong with that, if he can use his knowledge to make him dough while keeping me educated, so be it. The subject matter is why would one need to change oil every 5k and he makes several solid/valid points. I can careless of how much money he makes from his youtube channel.
    Wallygator and Terndrerrr like this.
  28. Jan 27, 2023 at 6:33 AM
    #88
    Redline870
    Ian
    Central NY
    Agreed. It’s a free market, and mechanics generally are paid poorly so good on him for creatively using his knowledge to better his and his family’s financial situation. Just because he’s making money doesn’t make him lose credibility either. He’s not a BS artist, the guy is very knowledgeable. It’s pretty easy to sniff out the bull shitters when you have been a technician yourself, and I don’t get any of that from him. His channel never would have grown as large as it is if he was full of crap.
  29. Jan 27, 2023 at 6:44 AM
    #89
    Redline870
    Ian
    Central NY
    Just for reference, here’s some (not all) of the larger of the metal shards that were caught by the oil filter and settled in the bottom of the oil filter housing on a Tacoma with only 500 miles on the odometer. That’s just what I could pour into the catch pan, the rest had to be blasted out with brake parts cleaner. The oil that dripped off the filter itself looked like metallic black paint. I don’t know about you, but I don’t want that floating around in the engine of a new vehicle I just paid 40-$50k for.
  30. Jan 27, 2023 at 6:47 AM
    #90
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    My first three (or was it four?) engine oil change oil analysis by Blackstone Labs they suggested that I should put 12,000 miles on the oil. Maybe they're just looking for suuuuuuuuuuuckers to carry out R&D. :playball:
    NewImprovedRon and Leo's first like this.
