Bed Rust
Discussion in 'General Tundra Discussion' started by cwcore, Jan 20, 2021.
  1. Jan 20, 2021 at 8:47 AM
    cwcore
    cwcore [OP] New Member
    2007 SR5 DoubleCab Long Bed
    Dropped truck off to get line x
    Facility called telling me they found rust on the frame rails and not worth doing the line x
    What are my options?
    2007 tundra with long bed
  2. Jan 20, 2021 at 9:06 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Do they mean the FRAME or the bed supports? Bed floor and be support rust is a pretty common issue on 2nd gens (and from my quick search apparently some 3rd gens now too)
    https://www.tundras.com/threads/the-speed-of-rust.73034
    https://www.tundras.com/threads/2nd-gen-bed-rot.74723
    https://www.tundras.com/threads/rusted-bed-need-your-opinion-please.74014
    https://www.tundras.com/threads/patch-panels-for-bed-rust.54530
    https://www.tundras.com/threads/bed-rust-issue.68880
    https://www.tundras.com/threads/do-...responsibility-for-the-2nd-gen-bed-rust.61770
    Options to fix this are find a non-rusty bed, buy a new entire bed floor and supports, separate bed sides and attach to new floor, or cut out rust and weld in patch panels.
    If they mean the actual frame then you might have missed the frame inspection - spray or replace campaign.
  3. Jan 20, 2021 at 9:20 AM
    cwcore
    Frame was sprayed previously
    He said rusted where frame rails support the bed, bed looked good to me when plastic drop in was removed
    Truck only has 41,000 miles on it so really don’t want to get rid if it considering the price of new ones I have been looking at
  4. Jan 20, 2021 at 10:55 AM
    blackoutt
    Indy
    OEM+
    Usually the bed doesn't look too bad because it works its way up from the bottom to the top. My linex is bubbled/blistered around the bed bolts on my 07 and it'll be getting pulled off to replace bed support rails and patch panels on the floor in the spring.
  5. Jan 21, 2021 at 3:19 AM
    cwcore
  6. Jan 22, 2021 at 3:03 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    If you are really concerned, try looking up camper shell and flat bed dealers in the are. A lot of times they have a bed on their showroom floor just to stage a truck cap that they will let go for cheap.
    Funny story, backed into a stall at the hospital years ago to visit with my mom. When I left, I forgot that I was parked next to a huge cement wall. I made a hard right to turn out of my spot, F350 lifted 6" with 37". I couldn't bring myself to look at it until I got home. The next day I called a few truck cappers in town and within an hour I had a replacement bed for $300. The guy was happy to get rid of it since it was a long bed. It took up too much room on his show room floor.
    des2mtn likes this.
  7. Jan 23, 2021 at 2:48 PM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    If it is really flaking maybe a problem, depends. I have used some really old and roughed up trucks well beyond their days. As long as the bed is not likely to fly off while driving I would spray a little undercoating on it and roll on with my business.
