Bed rail Unistrut system question
Discussion in 'General Tundra Discussion' started by Tracker, Feb 13, 2018.
  1. Feb 13, 2018 at 2:11 AM
    Tracker
    Tracker [OP] New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    I have seen some tunneau cover systems that ask if I have the deck rail system. I have added unistrut and have been told it's virtually the same thing. So the question is do I say yes to having the deck system or are there enough differences to be cautious of an install requiring the deck rails?
  2. Feb 13, 2018 at 4:11 AM
    Smiley
    Smiley New Member
    08 Tundra TRD
    Use the rail system to avoid clamping to the bed. I added the rails to my truck and used them to secure my cover, its an improvement.
  3. Feb 13, 2018 at 4:13 AM
    Tracker
    Shane
    I have the custom unistrut installed. Im making sure it is going to work exactly the same as the deck rails.
  4. Feb 13, 2018 at 4:25 AM
    Smiley
    Smiley New Member
    08 Tundra TRD
    It will, you may have to supply your own T-nuts if your strut is oversized.
    Sunnier likes this.
  5. Feb 13, 2018 at 4:37 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Different covers use different types of brackets to tie the cover down, so it depends on what cover you get. Some covers come with brackets that you have to use to lower the rail system, while some comes with little machined brackets that slide into the rail and then the cover latches to that, while yet others clamp to the rail itself.Are the unistruts the same size as the OEM rails? If not, the ones that comes with the brackets might not work well.
  6. Feb 13, 2018 at 4:51 AM
    Boerseun
    Ferdie
    Sarasota Florida
    Tracker[OP] and Smiley like this.
  7. Feb 13, 2018 at 7:03 AM
    Tracker
    Shane
    I think im getting closer to the Diamondback HD. Its $2k though but i should be happy with it.
    NewImprovedRon likes this.
  8. Feb 16, 2018 at 6:29 PM
    rodm1
    rodm1 New Member
    With the DB get the rail system bracket.
