Bed Rail Track System Question
Discussion in 'General Tundra Discussion' started by APatt, May 25, 2019.
  1. May 25, 2019 at 5:39 AM
    APatt
    APatt [OP] New Member
    2019 Cement SR5 CM 4x4
    Diamondback Bed Cover, Voodoo Steel Max Modular Bed Rack, iKamper Skycamp
    Morning everyone,
    I have a quick question. The dealer I purchased the truck from a few weeks back owes me a spray-on bed liner (long story). I recently purchased the bed rail track system and installed it. The service department is telling me to leave it on when I bring in for the spray-on work.
    Does that sound right? What about the space above the track on sides? Not much there with regards to surface area but I want the spray-on to go all the way up the sides...
    Any info is appreciated.
  2. May 25, 2019 at 5:44 AM
    EglSctAndy
    EglSctAndy MGM Crüe
    Andrew
    Arizona
    2019 MGM Crewmax TRD Sport
    Icon Stage 5 17” Icon Rebound Wheels TOYO Open Country A/T 35 12.5 RCI Heavy Duty Side Step Weathertech Mats 4” Stubby Antenna Fyre Flys Interior LED Lights Plastic Dipped Badges Decked tool box Baja Designs Squadron Sport fog lights
    I have the factory bed liner and it does not go all the way up above rails. I’m sure there must be a reason they do it that way but I’m not sure what it is.
  3. May 25, 2019 at 5:46 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    To me no, unless they are going to remove it for you. I wouldn't trust them to mask it off. Take it off and let them do the liner. My liner goes all the way up to under the rail, how they do that with the rail installed would be a mystery.
    NewImprovedRon likes this.
  4. May 25, 2019 at 5:47 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Factory liner, is it really done at the factory or dealer?
  5. May 25, 2019 at 5:51 AM
    EglSctAndy
    EglSctAndy MGM Crüe
    Andrew
    Arizona
    My understanding is that there are some done from the factory and they are different (have Tundra stamped in them) than aftermarket versions. I doubt it’s actually done at the factory but probably happens somewhere between the factory and the dealership. There were some at my dealership that were aftermarket and didn’t have Tundra stamped in them. It’s a nice look
  6. May 25, 2019 at 5:56 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    That makes sense, mine doesn't look like "dealer" install although i'm sure my dealer would do a good job. I guess the window sticker would tell us where it was done?
    Tundra stamped in the bedliner...never seen that. Anyone got that post it please.
  7. May 25, 2019 at 5:58 AM
    APatt
    I'm leaning towards removing them and then installing the track back. Hopefully cleaning the threads out won't be a pain.
    Pinay likes this.
  8. May 25, 2019 at 6:00 AM
    EglSctAndy
    EglSctAndy MGM Crüe
    Andrew
    Arizona
  9. May 25, 2019 at 6:01 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    I've seen liner jobs where the bed mounting bolts were removed and reinstalled so no, should not be a problem.
  10. May 25, 2019 at 6:02 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    I feel...cheated.
    So now I think my liner was done at the dealer.
  11. May 25, 2019 at 6:04 AM
    Dontra
    Dontra Newer
    Don
    AR
    2021 Ram Big Horn
    2021 Ram Patriot Blue, Lonestar or Bighorn, Crew cab 4x2, 5.7 bed, 5.7 Hemi etorque, Level 2, anti-spin 321 rear end, Air ride, 33 gal tank, 18 in wheels, Multifunction tailgate, Ram box, Wheel liners, MT Brown Deluxe bucket seats, 8.4 no navigation, Trailer brake controller. Front and rear rubber mats. Mopar power steps,8 yr 85K extended Mopar warranty.
    Just put the bolts back in the holes so any spray does not get in the hole
  12. May 25, 2019 at 6:04 AM
    APatt
    That looks awesome, but I'm not too concerned with getting a Tundra logo in the bed.
    My bed will be covered at some point so I wouldn't get to see it outside of removing the cover.
    EglSctAndy[QUOTED] likes this.
  13. May 25, 2019 at 6:06 AM
    APatt
    I thought about that too, but my luck they would remove them and then my bolts would be lost.
  14. May 25, 2019 at 6:07 AM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Tell them to leave the bolts alone, you're the customer. If they lose them they can replace them. Get REDNECK...but only if you have to. :rofl:
  15. May 25, 2019 at 6:07 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I would put the bolts back in. Take pictures
  16. May 25, 2019 at 6:13 AM
    APatt
    Thanks for the responses everyone.
    Moon Puppy and NewImprovedRon like this.
  17. May 25, 2019 at 6:13 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Not to tread jack- but I have an SR that didn’t come with rails- I would like to get them at some point- were did u get/ at what cost?
    If I were u I would remove and put bolts back in holes to make ur life easier to re- install
    JM2C
    Good luck
  18. May 25, 2019 at 6:22 AM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    I used the same shop the dealer uses, but after the fact. They removed all bolts and tracks before spraying and reinstalled them after wards. They block the holes while spraying.
  19. May 25, 2019 at 6:27 AM
    APatt
    I found one locally on craiglist that was gently used. Paid $80. Looked brand new. Guy was parting out tundra to buy a new one. They go for $150-$200 on several websites. Good Luck!
  20. May 25, 2019 at 6:29 AM
    Midnite72
    Bill
    Northern MD
    18 SR 5.7 4x4
    Thx bud
  21. May 25, 2019 at 6:17 PM
    Midnite72
    Bill
    Northern MD
    18 SR 5.7 4x4
    Gotcha thx Ron
  22. May 25, 2019 at 6:33 PM
    TheBeast The Beach
    local dealer has them coated at Line-x shop nearby. They come with line-x lifetime warranty as well.
  23. May 25, 2019 at 7:09 PM
    Remove it so they don't miss any spots.
  24. May 25, 2019 at 8:55 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Only on the TRD pro
  25. May 26, 2019 at 2:35 PM
    EglSctAndy
    EglSctAndy MGM Crüe
    Andrew
    Arizona
    I don’t have a PRO and it’s stamped in mine. Just a SR5 with the TRD Sport pkg
    Tundyfundy[QUOTED] likes this.
  26. May 26, 2019 at 3:46 PM
    Tundyfundy
    Bay Area, CA
    I stand corrected
