Bed Drains?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jota21, Sep 28, 2019.
  1. Sep 28, 2019 at 2:41 PM
    Jota21
    Jota21 [OP] New Member
    Can i use this to route a drain hose under tonneau? I feel like i've seen a thread where someone did, but i'm not sure what this hole is for, and dont want to send water where it shouldn't go. I do like the idea of keeping the drain hose discrete and out of the way vs. not all the way to the bottom of the bed, through the plastic factory caps....
  2. Sep 28, 2019 at 2:50 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    The rubber knock outs on the bottom corner are there for that purpose. I wouldn’t drain it into a metal compartmented are
  3. Sep 28, 2019 at 2:55 PM
    Jota21
    i was under the impression that those were there for manufacturing purposes - like access to mounting bolts or something like that. Mine have been rhino-lined over, and i'd prefer not to drill through it if the circled location is acceptable.
  4. Sep 28, 2019 at 2:57 PM
    Danman34
    Danman34 New Member
    Danny
    No. There’s nothing behind those haha. They are just rubber caps. It’s an empty gap between the cab and the bed. You can cut through it with a razor and slide the drain through. Don’t go drilling into the truck when there’s a paper thin piece of rubber meant for this purpose right next to it.
    bulldog93 and bdpeelgren like this.
  5. Sep 28, 2019 at 3:07 PM
    EAK
    EAK New Member
    KY
    ‘15 White 1794
    BAMuffler 8” SS Bilstein 6112/5160 Icon UCAs
    I did the same
    OR18TRD[QUOTED] likes this.
  6. Sep 28, 2019 at 3:07 PM
    Danman34
    Danman34 New Member
    Danny
    Same. No need to reinvent the wheel here.
    OR18TRD likes this.
  7. Sep 28, 2019 at 3:56 PM
    Jota21
    Thanks, all, may just do that, but back to my original question - what is the purpose of the circled hole in my OP?
  8. Jul 19, 2020 at 7:14 PM
    TRDpro4x4
    TRDpro4x4 New Member
    2016 TRD DC 5.7V8
    Though its an old post that came up during my search for answer, when my tonneau is open & it rains, i see puddle in the bed means no drain hole on the bed, So today went & drilled a 5/8in of hole in the front right corner & all was drained. NOW it stays dry. So for those who may have leaks thru the tonneau the water can collect under the plastic liner causing rust...just a caution .
  9. Jul 20, 2020 at 10:39 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Those are called stake pockets. If you were to trim back the plastic rail caps, a "stake" can be inserted into that pocket, and the access hole used to secure it with a lag bolt.
    NewImprovedRon likes this.
  10. Apr 23, 2022 at 11:29 PM
    Capt. Trips
    Capt. Trips New Member
    Utah
    2020 TRD Pro
    None. Yet.
    Do the make a cap or plug to fill these? My Tundra is missing a few.
