bed bounce on dbl cab
Discussion in 'General Tundra Discussion' started by swede78, May 15, 2017.
  1. May 15, 2017 at 7:58 AM
    swede78
    swede78 [OP] Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    I know this has been talked about before,but what is the fix? Go with the toy tech shackle or airbags,I tow a 24' camper and have a weight distribution hitch. For those who drive on concrete roads in colorado, you what I mean.
  2. May 15, 2017 at 8:39 AM
    Vizsla
    Vizsla ☠️☠️☠️
    I've tried Fox and Bilstein shocks, airbags, add a leafs, different lift blocks, and none helped, just made it feel a little bit different. I was gonna try these, but it just doesn't bother me much anymore.
    http://www.chaosfab.com/2007-2017-Tundra-Bed-Stiffeners-48677
    Never tried shackles, imo they are not the problem, and see a few people flatten their springs from them.
  3. May 15, 2017 at 8:47 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    SDHQ makes a hidden bedside support system. I have not had a change to test this out on the concrete highways yet.
    https://www.tundras.com/threads/sdhq-2007-tundra-hidden-bedside-support-system.10175/
    https://www.tundras.com/threads/diy-hidden-bedside-support-install.12910/
    This may help but ultimately it is the design of the leaf springs that is causing the issue.
    Toytec Boss shocks with Toytec shackles have helped but not completely alleviated.
    I have heard that weight in the bed of additional 200-300lb range will also reduce or eliminate the bed bounce.
  4. May 15, 2017 at 9:09 AM
    Vizsla
    Vizsla ☠️☠️☠️
    I am curious to hear how much the bed stiffeners help, was told it would make a big difference.
  5. May 15, 2017 at 9:29 AM
    chphilo
    chphilo Tundra addict
    Western PA
    You may want to try Willybar. http://www.willybar.com/Video.html
    Of course, a cheaper option is to have a couple of sand bags in the bed. Tundra tends to run smoother with some load in the bed.
    Law323 likes this.
  6. May 15, 2017 at 9:39 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    BOSS rear resi's all but eliminated bed bounce for me. Only way I've eliminated it is by putting a load in the bed. A couple of sandbags should do the trick if it bothers you too much.
  7. May 15, 2017 at 4:13 PM
    csuviper
    Broomfield, CO
    Flat metal is a good idea without compromising bed space. The price is crazy though. Pick up a few thick steel sheet metal pieces and paint them with bed liner for way cheaper.
