Battery disconnect for seats
Discussion in 'Detailing' started by TXRailRoadBandit73, Mar 9, 2017.
  1. Mar 9, 2017 at 8:31 AM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Hey fellas jus curious I'm sure I have to but better to be safe than sorry I wanna vacuum under seats n sides next to center console n I wanna remove seats do I need to disconnect neg batt terminal before disconnecting cables under seats I'm sure I do jus double checking
  2. Mar 9, 2017 at 9:22 AM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
    I've heard of guys unplugging under seats with battery still connected and getting an airbag warning light come on after things were hooked back up. When I took mine out to clean I didn't disconnect battery and I had airbag warning light come on. But, I checked connections and one wasn't clicked in fully and that solved the problem.
    As Ron said, better safe than sorry especially as its pretty quick to disconnect a battery. That being said, if you have an aftermarket stereo, be sure to go through and take pics of all your setting if you are happy with how things sound.
  3. Mar 9, 2017 at 9:26 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I do not disconnect the battery for stuff like that. Especially with a plug where the connections are not at risk of touching and grounding out.
  4. Mar 9, 2017 at 9:53 AM
    Thanks fellas
