Bailey's 2010 Tundra - Adventure Build & Photos
Discussion in '2nd Gen Builds (2007-2013)' started by Bailey, Dec 20, 2017.
  1. Dec 23, 2017 at 5:42 PM
    Bailey
    Bailey [OP] Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    I didn't! The previous owner did. I need to put slides on the drawers since they are pretty heavy. Considering selling the setup and making something instead
    Rica25 likes this.
  2. Dec 23, 2017 at 5:43 PM
    Bailey
    CO
    There were a few immediate changes I had in mind. Now it'll be ready for the first Mammoth trip after New Years
  3. Dec 23, 2017 at 6:35 PM
    TheBeast The Beach
    I'll be up there too end of January..shredding it
    Eclipsed & Floating likes this.
  4. Dec 25, 2017 at 4:23 AM
    AlexWV
    AlexWV Trophy Husband
    Alex
    WV
    2014 White SR5 TRD CrewMax
    ARE CX Series shell Rhino Rack cargo basket Leveling Kit 35x12.5 Thunderer TracGrip tires Rough Country 30" light bar
    I’d ask how much, but I’m on the other side of the country and shipping would cost more than buying one new
  5. Jan 1, 2018 at 6:53 PM
    Bailey
    CO
    SnowB0und, Rica25, omaguz and 4 others like this.
  6. Jan 1, 2018 at 7:14 PM
  7. Jan 1, 2018 at 7:21 PM
    Bailey
    CO
    Thanks. Planning on adding the Ski / Fishing Rod holders up there and MTB mount. That'll be down the road. Already spending enough :facepalm:
  8. Jan 1, 2018 at 7:22 PM
    I know the feeling all too well. Lol
  9. Jan 1, 2018 at 7:23 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
  10. Jan 1, 2018 at 8:36 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
  11. Jan 1, 2018 at 8:50 PM
    Eclipsed & Floating
    Voluptuous Whitey
  12. Jan 1, 2018 at 8:53 PM
    Eclipsed & Floating
    Voluptuous Whitey
    What’s the bar coming from under the passenger seat?
    Stormtrooper81 likes this.
  13. Jan 2, 2018 at 7:19 AM
    Bailey
    CO
    I believe it's 250lbs
    dcsleeper408[QUOTED] likes this.
  14. Jan 2, 2018 at 7:22 AM
    Bailey
    CO
    Previous owner included some equipment and already had the mounts on the roof. Stubby antenna is a 4G/LTE Antenna and the other is a commercial VHF antenna. Saving up for a nice radio which I'll run the VHF antenna off of, for now it's adapted to a Baofeng mobile
    Mount for a Dual Band Radio. I'll probably reuse when I purchase a radio.
  15. Jan 2, 2018 at 7:23 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    ok. I'm thinking of ditching my rack and tent setup and going with a camper shell setup.
  16. Jan 2, 2018 at 7:33 AM
    Bailey
    CO
    I'm sure it can handle more since the ratings were with the factory Thule gear installed. The snugtop pro shells have been tested at 500lbs without issues.
  17. Jan 2, 2018 at 9:14 PM
    Bailey
    CO
  18. Jan 3, 2018 at 8:57 AM
    TheBeast The Beach
    [NatGeo narrator voice on] and here we have the Tundra in its natural habitat [NatGeo narrator voice off]
  19. Jan 18, 2018 at 3:13 PM
    #49
    Bailey
    CO
    FrontRunner Outfitters Ski Racks came in!
  20. Jan 23, 2018 at 2:03 PM
    #50
    Bailey
    CO
    Updated the OP with the latest list of goodies
  21. Jan 31, 2018 at 8:17 PM
    #51
    Bailey
    CO
    Messing around with the Camera today. Pics of the truck :)
  22. Feb 1, 2018 at 9:02 AM
    #52
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    Looks nice, are the tires 285/75/17s?
  23. Feb 6, 2018 at 12:44 PM
    #53
    Bailey
    CO
    Correct! 285/75/17 or 34x11.50 (sticker says both)
  24. Feb 6, 2018 at 12:44 PM
    #54
    Bailey
    CO
    Shared from:
    https://www.tundras.com/threads/switch-pros-sp-9100-install.21280/
    ____________________________________________________________
    Hey Everyone!
    I wanted to share a few photos of my Switch Pros SP-9100 Install on my 2010 Tundra.
    I plan on adding a small variety of accessories down the road and this makes it very easy to do so. This also makes it easy to run the fog lights anytime (I'll get there :cool:). For those that aren't aware, the Switch Pros SP9100 is a very high tech solid-state power module that features 8 circuits for lighting and electrical accessories (4-35A, 4-18A). These circuits have a nice amount of programmable features like momentary, flash, dim, strobe :goingcrazy:, and more). All you have to do is install the power module under the hood, run the very thin switch cable inside, and mount the switch panel... It's that easy! But I wanted to make it a little bit easier.
    What's all included (color coded wires on SP-9100, was red on SP-8100):
    I went ahead and mounted the Power Module to the underwood fuse box cover. I also picked up a distribution block from Frys and ran the individual wires to that. This allows me to simply unscrew the block hardware and attach the accessory wire. No crimping, soldering, or splicing.
    The wires are color coded as follows:
    Switch 1 - Brown (18A)
    Switch 2 - Red (18A)
    Switch 3 - Orange (18A)
    Switch 4 - Yellow (18A)
    T1* (Trigger) - Pink
    Ground - Black
    LT** (Interior Lights) - White
    Ignition*** - Blue
    Switch 5 - Green (35A) 2 Wires
    Switch 6 - Blue (35A) 2 Wires
    Switch 7 - Purple (35A) 2 Wires
    Switch 8 - Grey (35A) 2 Wires
    *Trigger. Allows a trigger to control up to 4 circuits. I am going to run the Baja Designs fog lights to switch 1 and the OEM fog wire to T1 (Pink). When I activate switch 1 I will be able to turn on the fogs anytime. I will also have control over the fogs using the factory stock on the steering column.
    **Interior Lights. This allows the backlighting to be dimmed when your headlights come on. You can pre-set the color and brightness in the switch pros app.
    ***Ignition. Gives power to panel when vehicle is started. Prevents lights or accessories from being left on without the car on or keys inside. Run directly to battery if you want to bypass.
    Here is how everything looks mounted underneath the hood:
    For the Switch Panel I decided to mount it somewhere that could easily be reversed or changed. I chose the cubby directly in front of the shifter. Here is how it looks mounted:
    Vehicle OFF
    Vehicle Running (backlight on full brightness)
    Vehicle Running and Headlight ON (backlight dimmed to match interior)
    And a zoomed out pic showing how it sits compared to the other interior lights. I'll be fine tuning the color and brightness when it gets dark tonight.
    Hopefully this helps give some people ideas of how or where they'd mount their SP-9100. So far I'm very happy with the product and plan on messing around with it more once I get more lights!
    Can't wait to see what the strobe, flash, and dim do.... dance party? :taco::kona::jellydance::dancingbacon::broccoli:
  25. Feb 6, 2018 at 1:17 PM
    #55
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    They are great tires, I am running them on my JKU, over 30k miles and they have never needed to be re balanced, they still have a ton of tread left, nice even wear thought I rotate them every 5k.
  26. Feb 6, 2018 at 10:04 PM
    #56
    Bailey
    CO
    Good to hear! I've only got 1,500 miles on mine so far
  27. Feb 6, 2018 at 10:06 PM
    #57
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Dibs on the rack.
  28. Feb 18, 2018 at 6:38 PM
    #58
    Bailey
    CO
    A few photos from the trip out to CO. These are mostly taken in UT
  29. Feb 18, 2018 at 6:40 PM
    #59
    Great pictures!:thumbsup:
  30. Feb 20, 2018 at 2:31 PM
    #60
    Bailey
    CO
    Thank You! :hattip:
