Badge Removal Technique
Discussion in 'General Tundra Discussion' started by OHP, Feb 8, 2019.
  1. Feb 8, 2019 at 11:36 AM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    2018 Tundra TRD Sport
    Current Mods: JL Audio Stereo System, Truxedo Bed Cover, Console Organizer, Tint, Matt Gekko bed lights, tailgate auto lock, black badges Upcoming Mods: Level, Leather, Remote Start
    I just ordered a set of the black badges for my 18 Sport. In the past I have used fishing line to "cut" the adhesive to remove badges but this leaves a good deal of gunk on the paint. Anybody have a good technique they'd like to share or point me to an existing thread?
    Thanks
    TokerJoker likes this.
  2. Feb 8, 2019 at 11:42 AM
    TundraXPLover
    TundraXPLover New Member
    Clif
    NC
    2018 CM 4x4 XP
    Use a heat gun prior to taking the badges off, then use fishing line as you would. Buy some Goof Off in a spray can, but use sparingly, with a microfiber towel to wipe off. Polish the clear coat well after it is complete.
    They make black overlays that fit perfect over the stock chrome badges. That's what I have.
    I have done the removal on other trucks before using the technique I just spoke of.
    Heat gun can damage the clear also, so keep at a good distance on low heat.
    Bongskie, htw_hawaii and TokerJoker like this.
  3. Feb 8, 2019 at 11:49 AM
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    BD Squadron Sport Amber WC Fogs
    Piggybacking on this, any tips for removing bedside decal stickers without ruining the paint?
  4. Feb 8, 2019 at 11:50 AM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    Yea, those are coming off too, so any suggestions there would also be appreciated.
    Thanks
    dmiller[QUOTED] likes this.
  5. Feb 8, 2019 at 11:58 AM
    Booradly
    Booradly New Member
    Brad
    Regina, Saskatchewan
    2018 Tundra Platinun
    Rubber eraser wheel. Or a plastic razor blade with a heat gun for the decals.
  6. Feb 8, 2019 at 11:58 AM
    brad.bateman
    brad.bateman New Member
    Brad
    2018 Tundra TRD Offroad Limited
    I want overlays, but I'm finding them for $165 and that doesn't include the "limited" one that is an extra $60 on Ebay. Making me think I will remove and replace with new black ones. Did you find a better deal anywhere?
    TundraXPLover[QUOTED] likes this.
  7. Feb 8, 2019 at 11:58 AM
    ussdgates
    ussdgates New Member
    Dave
    2018 TRD Sport
    TRD Pro Exhaust
    Those come off pretty easy depending how old your truck is. I was able to get my finger nail under it and pulled it right off. I then wiped it down and used some spray wax to clean it up.
  8. Feb 8, 2019 at 12:02 PM
    TundraXPLover
    Clif
    NC
    2018 CM 4x4 XP
    Mine happen to come with my XP edition.
  9. Feb 8, 2019 at 12:05 PM
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    What booradly said. 3m eraser wheel does wonders. Safe for paint. It defies logic. But it works great. Youtube is your best friend with eraser wheel videos.
    TundraMash and TheBeast like this.
  10. Feb 8, 2019 at 12:12 PM
    TheBeast The Beach
    yep. works great
  11. Feb 8, 2019 at 12:14 PM
    Booradly
    Booradly New Member
    Brad
    The 3m one works great but it's very pricey. If you can find this pro-tek one it will be much cheaper. We sell them for about $8 canadian.
    Brownsfanhere[QUOTED] likes this.
  12. Feb 8, 2019 at 12:17 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    A heat gun will be your best friend....just have to find the sweet spot between not hot enough for the glue and too damn hot to touch.....a bit of goo-gone if needed and some good was and you are set!
    TundraXPLover likes this.
  13. Feb 8, 2019 at 12:22 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Wd 40 removes adhesive also.
    AZTundra and Brownsfanhere like this.
  14. Feb 8, 2019 at 12:23 PM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    I bought the set off of eBay for $116 but it does not include the limited badge. Says they are oem Trd Pro badges. Found the link in another thread on here.
    TRD Pro Badges eBay
  15. Feb 8, 2019 at 12:23 PM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    Thanks for all of the responses. Good info.
  16. Feb 8, 2019 at 12:26 PM
    wigsplitter
    wigsplitter New Member
    DFW Texas
    2018 SR5 TSS Crew Max
    Hair dryer is a safer bet and cheaper than a heat gun
    Booradly likes this.
  17. Feb 8, 2019 at 12:28 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Mine too ^^^^^^^
  18. Feb 8, 2019 at 12:31 PM
    TundraXPLover
    Clif
    NC
    2018 CM 4x4 XP
    Heat gun... Best and only way really...
  19. Feb 9, 2019 at 7:46 AM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    I've watched a couple of you tube videos on the removal process and I have a question. Since I'm putting the exact same badges back in the exact same spot, do I really need to completely strip the old adhesive? Seems like it would serve as a perfect template to get the new badge exactly where it's supposed to be.
    Thanks
  20. Feb 9, 2019 at 8:05 AM
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    I could be very wrong about this, (and someone feel free to tell me how dumb I am, I can take it, my wife says it all the time) but I would think the new adhesive would bond better to a smooth, clean surface rather than to an uneven surface of the old adhesive.
    To mark the spot, you could probably put a piece of painters tape just below the old badge and mark edges with a sharpie to mark your place.
    Brownsfanhere and NewImprovedRon like this.
  21. Feb 9, 2019 at 8:35 AM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    Makes sense. Definitely using tape of some sort to mark the spot.
  22. Feb 9, 2019 at 9:21 AM
    ussdgates
    Dave
    2018 TRD Sport
    TRD Pro Exhaust
    Absolutely. You don’t want to stick the new adhesive to the old stuff it will not sit flush and you could even run the risk of having the new badges fall off.
  23. Feb 9, 2019 at 2:14 PM
    Snowcat4360
    Snowcat4360 New Member
    Derek
    2018 TRD Sport Crewmax
    Century topper, bed rug, ultimate rod case
    3M eraser wheel for sure for emblems. I used heat gun and goof off for TRD Sport decals. Came off very easy!
  24. Feb 9, 2019 at 6:08 PM
    atl1glf
    atl1glf New Member
    ‘07 SR5 CM, ‘12 SR5 DC Supercharged, ‘19 Limited CM
    Too many TRD parts
    I used blue painters tape on bottom and sides of emblem so I knew where to put emblems exactly back.
    To take off, I used a hair dryer and an old credit card since I didn’t have any plastic razor blades.
    NewImprovedRon likes this.
  25. Feb 12, 2019 at 12:46 PM
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    Welp, just noticed that the very corner of one of my bedside decals appears to be peeling up. Guess that makes up my mind for me on whether to take those off or not.
    I wonder if I can get the dealership to remove them for me due to this?
  26. Feb 12, 2019 at 12:55 PM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    As already stated all yo need is a heat gun/hair dryer, fishing line, and Goo B Gone. Did mine this way and it turned out perfect, quick and easy
  27. Feb 12, 2019 at 1:51 PM
    brad.bateman
    Brad
    Is it true that goo gone takes off the wax and you need to re-wax as well?
  28. Feb 18, 2019 at 10:11 PM
    RoujePN
    RoujePN New Member
    2019 Platinum CM 4x4 5.7L 1G3
    After all is said and done, what adhesive is best to reapply badging?
    divinguy likes this.
  29. Feb 19, 2019 at 5:42 AM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    I did this project this past weekend and everything worked perfect. Went ahead and bought a heat gun and it was worth the $22 on Amazon. Didn’t use fishing line though. I have a set of plastic pry tools that popped the badges right off after I heated them. The black badges look great.
    Brownsfanhere likes this.
  30. Feb 19, 2019 at 6:34 AM
    tlr641
    tlr641 New Member
    Robb
    Oregon
    2018 Tundra Sport
    Trd dual exhaust, bilstein 5100’s, tint
    Took all mine off including the sport bed decal...used fishing line and heat but still had lots of adhesive left, especially where the 5.7 badge was. Tried goof off and still had quite a bit of residue.
    YouTube search found a dude who said gasoline will get the rest off.
    Truck had about 2000 miles so I was nervous big time the gas would screw up the paint or clear.
    Took a rag saturated is gas, wiped down the residue, immediately used a bucket of hot soap to clean the area after using the gas. Worked flawlessly, all the residue came off and no damage to the clear or paint.
