Bad vibrations at 1400 to 1800 RMP
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sammyschil, Jan 11, 2021.
  1. Jan 11, 2021 at 6:47 AM
    Sammyschil
    Sammyschil [OP] New Member
    Sam
    2018 Toyota Tundra Platinum
    I have a 2018 tundra platinum with 40 000 kms on it.
    When in park I have a Consecutive bad vibration between 1200-1800 RMP.
    You can feel it in the steering wheel. when the truck is cold you can also feel it in the seat. Does anyone have this issue? Did you solve the problem?
    thank you for your time
  2. Jan 11, 2021 at 7:01 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome from Ontario Canada . I’m confused , is it when it’s in park or when it’s being driven or both ?
  3. Jan 11, 2021 at 7:37 AM
    Sammyschil
    Sam
    Only when it is in park or neutral.
    When driving there is no issue. (Can’t feel it due to the road vibrations maybe)
  4. Jan 11, 2021 at 7:45 AM
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    A vibration when not moving usual indicates a miss or other issue with the engine that increases vibration. Does it still do it if you drive it a while and get it good and hot?
  5. Jan 11, 2021 at 7:46 AM
    Sammyschil
    Sam
    I took the truck to a dealer. There was no codes and the dealer said it was fine.
    I Did own a 2007 tundra TDR 5.7. I put 400 000 kms on it. Mostly towing and never had the vibration issue when in park at 1200-1800 rpm. (Cold start warm up or reving it to 1400 RMP)
    My father has a 2013 tundra TRD 5.7 and does not have this issue.
    I’m taking it to a different dealer this Wednesday. It is still under warranty.
  6. Jan 11, 2021 at 7:48 AM
    Sammyschil
    Sam
    When the truck is good and hot. I put it into park. Rev it up to 1400 rpm. Hold it there. I still feel the consecutive vibration. I Feel it more when I let off the gas.
    If it was miss firing you think a code would come up. Could it be a loose engine mount??
  7. Jan 11, 2021 at 9:10 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I notice a vibration in my driver's seat when my truck is warming up but I figured it's normal.
  8. Jan 11, 2021 at 9:31 AM
    Sammyschil
    Sam
    Cpl_Punishment
    I did not have it in my 2007 truck. my fathers 2013 truck does not have it either.
    going to get to the bottom of it one way or another. Or at least get it in Document With Toyota (whole it is still under warranty) just in case I run into issues at a later date.
  9. Jan 11, 2021 at 10:01 AM
    blanchard7684
    blanchard7684 New Member
    I’ve noticed this in my 19 pro.
    it seems to be worse when cold which indicates the mounts are contributing a bit.
    ive also noticed every overhead cam engine I’ve ever spent appreciable time with ( mostly fords) had this same issue at nearly same rpm.
    it isn’t present while driving at speed with load in engine and transmission.
    I think it’s a unique confluence of rotor and valve dynamics that isn’t getting damped ( enough) by mounts
  10. Jan 11, 2021 at 10:14 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Have you compared it to any other "3rd gen" (2014-2021) trucks? Maybe they changed something in 2014? :notsure:
  11. Jan 11, 2021 at 10:52 AM
    TXTundra2722
    2015 Black Tundra
    Why do we keep seeing first posts without an introduction? Either way hope you get this figured out and welcome from TX!
    :burp:
  12. Jan 11, 2021 at 12:32 PM
    timsp8
    NY
  13. Jan 11, 2021 at 1:22 PM
    Sammyschil
    Sam
    Hi TX.
    Wxraider it is a mild vibration only in park or neutral.
  14. Jan 11, 2021 at 2:11 PM
    Sammyschil
    Sam
    Timsp8 thanks for the information. In context that guy too.
  15. Jan 11, 2021 at 3:30 PM
    Sammyschil
    Sam
    Thanks WxRaider. I will look at the belt and mounts. I going to the dealer Wednesday. I will let you guys know the outcome.
  16. Jan 12, 2021 at 6:31 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    I believe the complaint is a very high frequency vibration. Like a tuning fork. My 4runner does it as did 5 others on the lot. My Tundra does ever so slightly. You can do create the vibration at the 6 oclock steering wheel position sitting in park and revving the engine. Lexus had the same complaint and they went with weighted steering wheels and I believe a different steering rack. If its the vibration I think it is, its characteristic of the vehicle caused by something hitting its natural frequency.
    14burrito and pickeledpigsfeet like this.
  17. Jan 16, 2021 at 7:19 PM
    Sammyschil
    Sam
    Hi guys. Sorry for the late reply. The dealer checked the engine mounts. They were good.
    The computer system show no issueswith the Ignition ignition system. There was no other codes or issues. The dealersaid he put the issue into there system.
    there is no vibration in the steering wheel when I’m driving.
  18. Jan 16, 2021 at 7:51 PM
    Airn890
    Airn890 New Member
    airn
    2021 tundra
    Ya that’s exactly what all the dealers are doing. Frustrating
