Backup screen
Discussion in 'Audio & Video' started by ChrisA, Nov 26, 2020.
  1. Nov 26, 2020 at 11:24 AM
    ChrisA
    ChrisA [OP] New Member
    2009 5.7L V8 Crew Max
    What's up y'all. Firstly, apologies if this question has been answered elsewhere. I have been looking and have not found the answer anywhere.
    Can I replace this:
    .jpg
    with this:
    The connectors appear to be the same from what I can tell based on my research, but I'm reluctant to spend a hundred dollars or so if they're not compatible.
    Apologize again if this is covered elsewhere. Thanks for any help!
    .jpg
  2. Nov 26, 2020 at 11:25 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    It would be helpful if you listed the part names or identified the connector types.
  3. Nov 28, 2020 at 11:52 AM
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    I ran mine into an after market head unit, all the screens if not oem should be regular composite style yellow video plug. if oem the factory harnesses are all the same molex plug in the first iteration (07-09) of the second gens...
    definitely need more info on specific part #'s. the rear view mirror set up looks like the 2010 and up oem factory, are you trying to go that route?
  4. Nov 28, 2020 at 11:58 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    You should be able to swap it no prob...
