Backup Camera
Discussion in '2nd Gen Tundras (2007-2013)' started by Danny3737, Feb 23, 2021.
  1. Feb 23, 2021 at 5:56 PM
    Danny3737
    Danny3737 [OP] New Member
    2012 Tundra Limited Platinum
    I ‘m looking to replace the factory NAV unit in my ride with an Apple CarPlay one and want to retain the factory backup camera. I’ve checked Crutchfield and the only units they have that can do that are over $1000. Does anybody know of a workaround to make it work?
    Thanks
  2. Feb 23, 2021 at 6:19 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
  3. Feb 23, 2021 at 6:34 PM
    Danny3737
  4. Feb 23, 2021 at 7:02 PM
    RepeatPete
    RepeatPete New Member
    Pete
    2008 Tundra SR5
    I just did the same upgrade, and was in the same boat with budget too. I got the Boss BE7ACP head unit, which was the cheapest one that Crutchfield had that had apple CarPlay.
    For cameras, I wanted to use the factory wiring that most trim levels have (mine is an SR5 and didn’t come with a backup camera but does have the wiring) but couldn’t do it cheaply. I ended up with an Amazon camera, that works really well. You can get the Boss head unit with a camera for only $20 more from crutchfield, I did that and used it as a forward facing camera.
    There are more details and pictures here, at the bottom of page 1 and top of page 2.
    Good luck!
    Danny3737[OP] likes this.
  5. Mar 4, 2021 at 2:16 AM
    Texas_Cowboy
    Texas_Cowboy New Member
    2011 Tundra Limited Platinum
    XB LED Headlights, 1k lumen reverse lights
  6. Mar 4, 2021 at 4:45 AM
    ljburns
    ljburns New Member
    I have a Kenwood Excelon DNX995S. I purchased it from Amazon for $650 because Crutchfield cost a little more. It works with the factory camera and has apple car play. It looks like it is discontinued, but can still be found online. But the price has gone through the roof if you can find one. I assume the newer model, whatever it is, will also work the same.
    https://www.crutchfield.com/S-VENTm...8kw4hzr_42XT2quPIvh74qt7hRQlA12BoCnC0QAvD_BwE
  7. Mar 9, 2021 at 5:23 PM
    qqtip2
    qqtip2 New Member
    Fort Worth TEXAS- Ketchikan Alaska
    2013 White Tundra Crew-Max 5.7L 4X4 Off Road Package
    2nd Gen Tundra Crewmax here. I bought the Phoenix PX6 Fast boot unit to replace stock radio. This radio rocks once you get speakers in your truck. I got a Kicker Hs10 sub and infinity speakers in the doors. It's not as loud outside the truck as is inside the truck but you can tell it's not stock. I am installing a 360 camera set up but ran into a few issues. I will be trying to get this handled soon.
    Jego likes this.
  8. Mar 9, 2021 at 5:39 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 TRD Off Road Solar Octane
    I got a Sony HU from Crutchfield with CarPlay for under $500, and added an aftermarket backup cam for $20. Maybe that would be an option instead of trying to work around the OEM cam? Not sure why it's so expensive to integrate with the OEM camera.
  9. Mar 9, 2021 at 5:46 PM
    Texas_Cowboy
    For me it's a matter of physical issues, and not wanting to fight my body to properly wire a new camera in, and not being able to afford having someone else do it for me.
  10. Mar 10, 2021 at 4:21 AM
    Danny3737
    I bought Sony unit from them as well and the OEM camera was plug and play for me
  11. Mar 12, 2021 at 7:53 PM
    bingdude
    bingdude New Member
    I got a Soundstream HU (carplay and android capable) with install kit/wires for about ($360) from Crutchfield about 2years ago. The kit kept my steering wheel buttons and let me used stock camera that came with the truck. I had the JBL/Nav Headunit. If you installed car stereos in the past it should be no problem.
    Danny3737[OP] and Texas_Cowboy like this.
  12. Oct 20, 2022 at 10:05 PM
    Seattle996
    Seattle996 New Member
    LX470.. future Tundra owner
    Hey buddy.. can you pull up your crutchfield order and see what install kit they had you buy? I'm in a pickle.. headunit (Alpine) works fine w/ my JBL system but can't get the rear view camera to connect.
