backup camera not working on '07. pls help with troubleshooting.
Discussion in 'Audio & Video' started by dishdash, Sep 26, 2018.
  1. Sep 26, 2018 at 7:42 PM
    dishdash
    dishdash [OP] New Member
    I bought an '07 Tundra Limited and the backup camera screen stays looking off/black and nothing happens when i shift into reverse. It's located just above the rearview mirror. Any ideas on what might be going on, and what i can check to see where the issue is? I'm not sure where to start.
  2. Sep 26, 2018 at 8:11 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Are you sure the camera has power and is connected to the system? You might have to start camera side and trace back wires for power, ground and video out to screen
    TheBeast likes this.
  3. Sep 26, 2018 at 8:16 PM
    TheBeast The Beach
    aftermarket install ? check the wires. they usually run them on the door sill passenger side. that's where mine is.
  4. Oct 6, 2018 at 4:37 PM
    dishdash
    I don’t know if it’s aftermarket or where to look for wires. Here’s a pic of it.
  5. Oct 22, 2018 at 8:05 PM
    incredibillhulk
    incredibillhulk New Member
    Bill
  6. Oct 30, 2018 at 7:22 PM
    dishdash
    Not resolved. It looks like the same product, I’m just still unsure how to troubleshoot and figure out what the problem is. If anyone has other ideas please share. Thanks.
  7. Oct 2, 2019 at 4:57 PM
    Ethan withrow
    Ethan withrow New Member
    2014 tundra
    I have a 2014 tundra and my backup camera will randomly come on on the dash and flicker when driving forward down the road any ideas on what might b the problem i haven't hurd of anyone else having this problem
  8. Oct 2, 2019 at 5:51 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Most of these cameras have a wire that runs to the reverse tail light from the head unit or mirror. That way the vehicle knows you're in reverse. I would start there because the wire connector/splice may be corroded. Or, your camera may be bad if nothing appears on the screen when you're in reverse.
  9. Oct 2, 2019 at 7:59 PM
    kgb4187
    kgb4187 New Member
    Open the access panel on the tailgate and make sure the camera is connected on the handle
  10. Oct 2, 2019 at 9:49 PM
    Civiceg94
    Civiceg94 New Member
    NYC
    2007 Toyota Tundra Crewmax 5.7 Limited
    Horn baffle delete Fox 2.5 DSC Setup DAP TUNED RW WHEELS 285/75/17 AT3 LTX
    Its funny this popped up. My 07 rear camera also stopped working awhile ago. I couldnt find information on how to fix it. It just stopped out of no where. Never flickered.
