Backup camera delay problem
Discussion in '2.5 Gen Tundras (2014-2021)' started by SMILE, Jul 10, 2019.
  1. Jul 10, 2019 at 2:37 PM
    SMILE
    SMILE [OP] Drink, Smoke, and Smile!
    SOUTHEAST PA
    2016 TUNDRA CREWMAX SR5 5.7L V8
    Weather tech mats, to be continued.........
    Searched around and couldn't find any info. My backup camera works fine sometimes, then sometimes it takes up to a minute to turn on. I have the entune radio with a Frac harness. I took the Frac harness out and it worked fine for a day then started doing the same thing. No rhyme or reason to it, dry / wet, hot / cold outside, sunny / dark. I am at a loss. when it does come on it works fine, no stuttering or glitches so I doubt it is a loose connection, although I checked all of them by the radio. Same issue whether I shift into reverse or use the Frac harness button to turn it on.
    At this point I use the frac harness switch to turn it on about a 1/4 mile before i will need it, but it sucks when I forget. Any ideas?
  2. Jul 11, 2019 at 9:37 AM
    SMILE
    SOUTHEAST PA
    Bump.....
  3. Jul 13, 2019 at 7:50 AM
    SMILE
    SOUTHEAST PA
