Axel replacement
Discussion in '1st Gen Tundras (2000-2006)' started by Feralcat, Jul 17, 2017.
  1. Jul 17, 2017 at 1:35 PM
    Feralcat
    Feralcat [OP] New Member
    Bob
    2000 tundra
    New member from Colorado. I have a 2000 Trina that I am trying to replace right front axel. Cannot get axel into housing. Tightened axel nut on axel & now cannot get axel out of hub to totally remove axel. Any help would be appreciated. Axel looked identical without mikeing.
  2. Jul 17, 2017 at 2:34 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome Bob from Parker CO. And thanks for your service.
  3. Jul 17, 2017 at 6:18 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Welcome from TN!
    I'm not terribly familiar with axels, you should try @LOTSOFTOYS
    Dude knows his stuff he's the yota whisperer, dontcha know??
    NewImprovedRon likes this.
  4. Jul 17, 2017 at 7:39 PM
    Welcome to the site. Where are you at in CO?
    Ok, so your axle isn't coming out or you did get it out and can't install the new axle?
    You shouldn't need a micrometer to see if it will fit, but stranger things have happened.
    autosport209 likes this.
  5. Jul 20, 2017 at 7:53 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I'm confused as well
  6. Sep 8, 2017 at 6:10 AM
    churbo
    churbo New Member
    Aaron
    2000 Tundra AC
    Did you ever get this?
    I had the same issue and used a rubber hammer. Lined it up so it was in the housing, lined it up as straight as possible, line up the splines, pushed in to compress the cv joints, then hit the other end of the axle three or four times until it was seated.
    Hope this helps.
    Not sure where you are in Colorado but I'm in Colorado Springs, wouldn't mind helping if you are close.
