Automatic transmission selector lever indicator
Discussion in '1st Gen Tundras (2000-2006)' started by Shellback, Oct 13, 2018.
  1. Oct 13, 2018 at 1:47 PM
    Shellback
    Shellback [OP] New Member
    Pink/Silver 2001 Tundra TRD
    Peeling door window trim.
    Little green light that shows what gear you are in. All gears (P, R, N...) have a light when I've selected the corresponding gear, except the "D". Is this normal?
    Looking at possibly taking instrument cluster apart and checking bulbs...
  2. Oct 13, 2018 at 1:50 PM
    15whtrd
    15whtrd Mr. Blonde
    TRD Pro suspension, +2 Coachbuilder shackles, 2015 TRD Pro headlights, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats front and rear, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, aluminum oil filter canister, Real truck tailgate seal, Pop-n-lock tailgate lock actuator, rear diff breather relocate.
    I was wondering the same thing. My 03 sequoia, the D does not light up. I figured the light was just out because it’s in that position the most often.
  3. Oct 13, 2018 at 2:29 PM
    simonmiles
    simonmiles New Member
    The "D" gear lights green on my 2006 Tundra DC. I think your bulb might be dead. Hope this helps.
    15whtrd likes this.
  4. Oct 13, 2018 at 2:50 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Can you change it so they all light up as blue?
  5. Oct 13, 2018 at 4:15 PM
    Shellback
    Interesting. Is that to match your interior lighting?
  6. Oct 13, 2018 at 4:24 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    :spy: Exactly my thought either blue or white. Just not that green color
  7. Oct 13, 2018 at 5:28 PM
    lsaami
    lsaami Redneck Toyota boi with a rice-burner Honda
    Minnesota
    2000 Tundra Limited 4x4
    2" lift Grille Guard, Cab Visor 265/75/16 Kumho AT51s
    Dead bulb. My dads 02 has D out, and my 00 has the P and D out.
  8. Oct 13, 2018 at 5:30 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    I assume it’s just a light but under the letters is a clear color tape. Hmm
  9. Oct 13, 2018 at 7:28 PM
    Professional Hand Model
    Professional Hand Model Fred Brookes
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Post pics of repair. My ‘D’ is out also. Sounds like they should all be replaced at the same time if the panel comes off. Would be nice to change color!
  10. Oct 13, 2018 at 7:30 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    :rofl:Google “my d is broken”:rofl:
  11. Oct 13, 2018 at 7:31 PM
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Scared.
    15whtrd likes this.
  12. Oct 13, 2018 at 7:33 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    It's just a bulb for each gear selection. If memory serves a NEO4. I just moved the bulb from 1 to the D position.
    The instrument cluster is pretty easy to remove 6 or so screws all together.
  13. Oct 13, 2018 at 7:37 PM
    15whtrd
    15whtrd Mr. Blonde
    JoshuaA likes this.
  14. Oct 13, 2018 at 7:40 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    722365D3-C9D5-4948-B408-5E5B957883BE.jpgMaybe?? I’ll look when I take that section off again to repaint or change something else.
  15. Oct 13, 2018 at 7:41 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
  16. Oct 13, 2018 at 9:01 PM
    bmf4069
    bmf4069 New Member
    TX
    02 AC sr5 4wd v8
    There's a vid on YT how to replace them.
  17. Oct 13, 2018 at 9:53 PM
    Shellback
    Heading to ER with broken D. Expect to have a cast mounted and rest it in a sling.
    Thanks for the bulb info.
    15whtrd and bmf4069 like this.
  18. Oct 14, 2018 at 7:08 AM
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Wonder if these will hyper blink?
    Already have two led bulbs in my cargo light. Added the 3rd brake led bulb and turn signals went hyper flash. Ended up taking the brake bulb back out and reinstalled regular.
  19. Oct 14, 2018 at 7:46 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    They shouldn't. Try a different brand of LED in your brake lights, I've got no issues with hyper flash with no resistors. I can't remember off hand if they were the Phillips or Sylvania, I gave up with the cheap bulbs after a bunch of issues.
  20. Oct 14, 2018 at 8:32 AM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    Yeah cheap bulbs off Amazon eventually stop. I bought all new sylvania I think from auto zone. 10$ a piece. It’s lake is a operating room inside the truck at night lol I laugh every time I turn them on bc they’re too bright and I’d rather laugh then get mad
  21. Oct 15, 2018 at 10:58 AM
    because_v8
    because_v8 TTC #036
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    3rd gen taco TRD OR wheels, flowmaster 44, LEDs and stickers
    How much of the dash did you have to remove to get to it? In my first gen tacos I had to remove the stereo surround, the piece under it and the ash tray, the steering collumn and bottom of dash to get to the gauges
  22. Oct 15, 2018 at 11:05 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Pretty much just the cluster surround. It's flexible enough to get out with out removing anything else. It'll take you longer to unplug the connectors from the cluster than anything else.
