Auto Folding Mirrors?
Discussion in '2.5 Gen Tundras (2014-2021)' started by thewoo81, Nov 19, 2018.
  1. Nov 19, 2018 at 6:45 AM
    thewoo81
    thewoo81 [OP] New Member
    Scott
    Dumas, TX
    2014 Toyota Tundra 1794
    I am possibly purchasing a used Tundra and the button for the folding mirrors doesn't work. They are trailer mirrors that manually extend out. Is there a easy way to see if they were an addition to the truck after original purchase and may not be auto folding?
  2. Nov 19, 2018 at 7:43 AM
    thewoo81
    Scott
    Dumas, TX
    Would it help if i had pictures of the mirrors themselves? also, i can fold them manually, i don't know if that makes a difference whether they are auto or not..
  3. Nov 19, 2018 at 7:46 AM
    LML 3500HD
    Welcome Scott.
    They will never fold in. Only the regular non-towing mirrors power fold in.
    Once the previous owner swapped to tow mirrors, the vehicle lost that function.
    landphil likes this.
  4. Nov 19, 2018 at 7:57 AM
    thewoo81
    Scott
    Dumas, TX
    Toyota sells oem power fold mirrors? how can i tell these aren't those?
  5. Nov 19, 2018 at 7:59 AM
    LML 3500HD
    Power folding mirrors were on platinum trim levels if I remember correctly....maybe limited. Some people have tried to get power folding mirrors in lower trim packages.
    If you have the tow mirrors that manually extend out, you don’t have the foldable mirrors.
    Take a pic if you can.
  6. Nov 19, 2018 at 8:04 AM
    thewoo81
    Scott
    Dumas, TX
    ok, its on the 1794 edition..
    ColoradoTJ likes this.
  7. Nov 19, 2018 at 8:10 AM
    thewoo81
    Scott
    Dumas, TX
  8. Nov 19, 2018 at 8:19 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    The 1794 would have came with power folding mirrors. Somebody removed those and replaced with manually extending towing mirrors. You can’t have both features...sort of...if you want both features, buy a set of power folding mirrors (take-offs) and add those mirror extenders which fasten to your existing mirrors for towing and you’ll be set. Etrailer.com sells them...
  9. Nov 19, 2018 at 8:40 AM
    Cfincke
    San Antonio
    Yes toyota has power folding tow mirrors, they are $700+ and you will loose blind spot monitoring. Toyota does not make a tow mirror with BSM, so those are likely A1auto or other non-oem mirrors. I have a 1794 as well and i have not bought tow mirrors because i would have to sacrifice something.
  10. Nov 19, 2018 at 8:47 AM
    LML 3500HD
    @Jrharvey02 covered it.
    Just noticed you're in Dumas, TX. Man that’s Ford and GM territory. Lol
    Been there a lot, have a military buddy there, races altered.
    If you see these, slap them for me...ACACF0CF-FFEB-4180-8E5D-BEF69738B059.jpg
  11. Nov 19, 2018 at 9:08 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    I'm not sure why you guys are saying there are no power folding, manual extending tow mirrors. I have them on my Platinum. I removed the factory power fold mirrors, added the power fold tow mirrors, and now have power folding tow mirrors.
    My guess is that the previous owner didn't want to shell out the $$ for power folding tow mirrors and went with regular tow mirrors instead.
  12. Nov 19, 2018 at 9:10 AM
    LML 3500HD
    Learn something new everyday.
    Jrharvey02 likes this.
  13. Nov 19, 2018 at 9:25 AM
    Jrharvey02
    Do these still retain the heated defrost function of the OEM mirrors too?
  14. Nov 19, 2018 at 9:28 AM
    thewoo81
    Scott
    Dumas, TX
    Can you send me a pic of the power folding ones? i just want to know if there is a problem or if they are just not power..
  15. Nov 19, 2018 at 9:31 AM
    thewoo81
    Scott
    Dumas, TX
    I know Joe and most of the Still Crazy team personally..
  16. Nov 19, 2018 at 9:46 AM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Power folding tow mirrors is news to me... I sell the trucks...
    Would like to see them in action, so I can also get some.
    Jrharvey02 and ColoradoTJ like this.
  17. Nov 19, 2018 at 9:48 AM
    LML 3500HD
    Same here. Cool if they do now.
    Krezz[QUOTED] likes this.
  18. Nov 19, 2018 at 9:51 AM
    LML 3500HD
    Small world. Shane (Smokey) is a good friend of mine from Bad Company race team. I may have met Joe once. He’s the one with a built up Duramax right? They all run freightliners now anyway.
  19. Nov 19, 2018 at 9:56 AM
    thewoo81
    Scott
    Dumas, TX
    I'm not sure, i thought Still Crazy ran freight liners.
  20. Nov 19, 2018 at 10:04 AM
    LML 3500HD
  21. Nov 20, 2018 at 4:45 PM
    SOB
    SOB Big Member
    Ohio
    My PF tow mirrors have heat, memory, and turn signal. They are not OEM. OEM are $800 vs $350 for aftermarket. You can now get them with BSM aftermarket but not OEM. You lose auto dim, puddle lights, and BSM (if you go OEM). They also have side markers but I think they only work on SR5s. Tons of threads out there about these. I’ll take a pic if I think about it but they literally look the same. Not sure how you would tell the difference visually.
