Auto-fold mirrors 2017 Limited
Discussion in '2nd Gen Tundras (2007-2013)' started by mike508, May 26, 2019.
  1. May 26, 2019 at 6:53 AM
    mike508
    mike508 [OP] New Member
    michael
    2021 TRD Pro
    I'm going to try this mod. My tundra came with bsm on the mirrors . I wanted to upgrade to turn signals and puddle lights. I'm hoping it is basically plug and play adding the mirrors and a switch. Does anyone know if there is any additional wiring needed to power the folding mirrors ?
    SpeshulED likes this.
  2. May 26, 2019 at 7:43 AM
    TXTundra2722
    2015 Black Tundra
    There is at least one thread already covering this. I believe if your vehicle did not come with the option then you have to run the wiring(which wouldn't be hard at all). But with your trim level I'd be very curious if you'd even have to do that(is probably already wired for it). Either way it seems to be a fairly easy mod.
  3. May 26, 2019 at 10:36 AM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    https://www.tundras.com/threads/installing-puddle-lights-on-factory-sr5-mirrors.44755/#post-1149110
    and maybe
    https://www.tundras.com/threads/diy-tow-mirror-puddle-lights.42359/#post-1149135
    Best two I've seen on wiring/installing mirror additions. I don't know personally as I haven't done this, but I hope it helps.
    I know I have seen labeled diagrams on this site from members about where to wire in folding mirrors if I'm not mistaken - hopefully someone in the know chimes in for the assist...
  4. May 27, 2019 at 8:09 AM
    mike508
    michael
    2021 TRD Pro
    84870-0D050 84870-02040 Rear View Mirror Switch for Toyota Tundra
    Mirror
    • Power glass
    • Heated
    • Memory
    • Turn signal
    • Puddle light
    • Power folding
    • Blind Spot Detection
    • Chrome cap
  5. May 27, 2019 at 8:47 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    I guess we'll be rowing the same boat...
    I've got a set of '16 limited mirrors (heated, turn signal, puddle lamps and power fold) in route, should arrive this week.
    I'm hoping the plugs were already wired, and it will be a simple swap.
    Where did you source these part numbers?
    I found the switch part numbers to be; 84870-0C040 and 84870-0C050
    The ….040 is for '07-'14 Tundras
    The ….050 is for '08-'18 Tundras
    As much as I can determine, the 050 may be for the trucks with blind spot detection? Or one was on the limited, and one on the platinum?
    Either way, the switch functions are all the same; L/R mirror adjustments and folding.
    Anyone know what/if any differences there are in the plug/wiring?
  6. May 27, 2019 at 9:01 AM
    mike508
    michael
    2021 TRD Pro
    I got the part number from Toyota for my year truck with the options I have. BSM and the tow package could have something to do with it. My mirrors will be in tomorrow. I ordered one of those cheap switches from China, that will take about a week to come in. I'm going to mount the mirrors tomorrow and i am thinking everything should work but the folding option. Hopefully popping in the switch next week will take care of that.
    GAknight likes this.
  7. May 27, 2019 at 10:30 AM
    mike508
    michael
    2021 TRD Pro
    • Genuine:
      [​IMG] [​IMG]
    • SKU:84870-0T020-C0
    • Other Names:Switch Assembly Outer M
    • Description:
      TUNDRA; W/TOW PACKAGE
  8. May 27, 2019 at 10:31 AM
    mike508
    michael
    2021 TRD Pro
    parts.toyotaoemdirect.com that's where I look for part numbers
  9. May 27, 2019 at 12:17 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Yea...I've looked there too. I have the tow package...just not tow mirrors.
    I wonder if the switches are different for the tow mirrors (which I know fold) vs. the stock design with the folding capability (off the limited/platinum).
    I guess I'll give one of the switches off ebay a go. I figure I can go through a couple of them and it be less than half of a Toyota OEM switch (which the cheapest I've found was $128!!)
    Thanks for the all the input!!
  10. Sep 14, 2019 at 11:53 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    Did this end up working?
    Sorry I’m new and searching the forum. I have a 2019 limited hoping it’s as easy as adding the switch.
  11. Sep 15, 2019 at 10:58 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    First, welcome!
    Here's a link to the mirrors I worked up.
    I don't know if it's as simple as adding the switch. You have to have the power fold motor in the mirror itself. I'm not sure about the limited models. I believe they're standard on Platinum and 1794. As mentioned in the linked post, I bought some Platinum mirrors.
    You'll need to check the part numbers on your mirrors to see if the ones you have include the power fold motor.
    The part numbers on mine were:
    Driver: 87940-0C440-00
    Passenger: 87910-0C420-00
    I also bought my switch off ebay. I think I gave about $35 for it.
    If you click on the above link, there's another link within that post that connects to another site, that has the "how-to" that I followed. That how-to goes over the switch you'll need (notice the extra pins), and the wiring and connectors that you'll need to build. The how-to post also has references to where to buy the wire and connectors.
    Let me know if you have other questions. Good luck with it! :thumbsup:
    TreeCat likes this.
