Auto door lock? Key fob range sucks?
Discussion in '2.5 Gen Tundras (2014-2021)' started by nyybrandon, May 4, 2019.
  1. May 4, 2019 at 9:07 AM
    nyybrandon
    nyybrandon [OP] New Member
    Brandon
    2018 Blue Tundra XP
    Hey everyone, so yesterday my 2018 CM was “broken” into, in other words just opened the door and helped themselves. I’ve been having my key fob not wanting to lock/unlock when you are more than a few get away. Is this just a tundra feature or does yours work at a larger distance. Seems like you almost have to touch the vehicle for it to unlock at times.
    If this really is just how the tundra key fobs operate, is there a way to auto lock the doors after leaving the vehicle? I know a lot of other vehicles have this feature but can’t seem to find it on the truck menu. Also might not help that they store my owners manual so it’s a little tougher to look up. Thanks in advance, I’m a little discouraged.
  2. May 4, 2019 at 9:09 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Did you replace the cargo lights with LED bulbs by chance? Some brands are known to cause interference with the antenna, as they moved that into the brake light housing in 2018+ models.
  3. May 4, 2019 at 9:13 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Good point on the led bulbs.
    Also make sure battery in fob is good, maybe replace it.
    If you hold the fob against your chin the range is increased. I swear this works and I'm not just messing with everyone so they go around holding their keys to their chin. It does work, I use this method to remote start my truck at work, it easily doubles the range
  4. May 4, 2019 at 9:24 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I don't want to believe you, but I'm still going to look like a jackass trying it later today anyway...
  5. May 4, 2019 at 9:26 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I can confirm the chin thing works. You could get an aftermarket 2way system that way it would tell you what function you did. If you had an lcd 2way, you could see the status of your truck. Also you can program aftermarket's to lock so many seconds after the last door is closed. Just make sure you have your keys
  6. May 4, 2019 at 9:30 AM
    Pudge
    CT
    Oh I forgot to mention you have to do a stand on 1 foot statue of liberty pose while doing it;)
    Lol JK it really does work
  7. May 4, 2019 at 9:49 AM
    nyybrandon
    Brandon
    2018 Blue Tundra XP
    I didn’t know that, and actually I did. Replaced them with VLEDs. Any idea if they cause the issue? Looks like I might be getting a cheap incandescent set and seeing if that changes anything.
  8. May 4, 2019 at 9:51 AM
    nyybrandon
    Brandon
    2018 Blue Tundra XP
    I just assumed the battery was good with it being a newer truck, still can’t hurt to check though. Definitely try the chin thing as well
    Pudge[QUOTED] likes this.
  9. May 4, 2019 at 9:52 AM
    Pudge
    CT
    I believe it was infact vled bulbs that were giving guys issues with remote start. I have cheap Amazon jdm astar LED bulbs in my cargo lights and I dont have any issues
    GODZILLA likes this.
  10. May 4, 2019 at 10:03 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yep, the older version of VLEDs were one of the brands causing issues, along with a few others. Reach out to them and they may replace them for you with the new version. I've also got the JDM astar LEDs and haven't had issues, so that's another option for you.
  11. May 4, 2019 at 11:28 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Just turn the cargo light completely off to test. ;)
    Cthulhu likes this.
  12. May 5, 2019 at 8:54 AM
    Ps3udonymous
    Ps3udonymous Who is the smart ass that changed the title?
    This works due to the shape of your skull amplifying the signal.
    TundraDude18 likes this.
  13. May 5, 2019 at 11:05 AM
    Cthulhu
    And fillings, don’t forget the fillings...
    HO LEE SHEYAT. Just turned off my cargo light, and lo and behold, I have keyfob range again!!! Thanks @landphil!!
  14. May 5, 2019 at 6:36 PM
    nyybrandon
    Brandon
    2018 Blue Tundra XP
    Low and behold it’s the cargo lights. Turned them off and it easily 3-4 times the range. You guys are the best as always! Going to give VLEDs a call tomorrow and see how the customer service is.
  15. May 10, 2019 at 11:45 AM
    2018TundraLimited
    2018TundraLimited New Member
    2018 Silver Tundra Limited TRD
    Which JDM astars do you have? I noticed a few different types on Amazon. TIA
  16. May 10, 2019 at 11:47 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I posted the wrong bulbs. Just a min and let me find the right ones.
    I actually bought Auxito branded ones for my cargo lights: https://www.amazon.com/gp/product/B0728DYR9H/ I think they're the same as the reverse light socket.
    EDIT 3: These JDM Astars will work: https://www.amazon.com/JDM-ASTAR-Extremely-Bright-Reverse/dp/B01CRGU91Y/
  17. May 10, 2019 at 11:52 AM
    2018TundraLimited
    Thank you sir!
  18. Jul 21, 2019 at 8:08 AM
    sea_weathered
    sea_weathered New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    Holy shit! My key fob started acting up this week, and I couldn’t figure out what was going on. Changed the battery, still no improvement. Called Toyota and made an appointment to have it looked at. Then stumbled across this post. Low and behold, I’d replaced my cargo lights earlier in the week with these from Amazon. I’m not around my truck at the moment, but I will be swapping the original bulbs back.
    https://www.amazon.com/dp/B075K4DPFY/ref=cm_sw_r_cp_api_i_i5hnDb0G5FK80
    Trooper2 and landphil like this.
  19. Jul 21, 2019 at 8:17 AM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    I 2nd the iJDM cargo lights...they're very bright and no issues with the keyfob with them!
  20. Jul 21, 2019 at 8:43 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    That's because the signal goes thru your head and shoots out your eyes like freaking lasers. Your key fob turns you into the Superman of car alarms.
  21. Dec 9, 2019 at 11:23 AM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    Thank god I found this thread. I swapped cargo lights with some ALLA lighting LED 921 bulbs from Amazon... my FOb and remote start have sucked ever since but i didn’t put 2 and 2 together. I will try disabling the cargo light on Lock/unlock to see if it fixes. Next step will be to replace those bulbs with another brand.
    Trooper2 likes this.
  22. Dec 9, 2019 at 2:04 PM
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    Going to give these Auxito’s a try. I have COMPUSTAR remote start and I was having issues with the factory fob... but I’m starting to think it wasn’t the bulb + remote start combo, but actually the bulb + fob. I have to hit lock, unlock, lock to remote start and that 3rd lock was messing up.
    it wasn’t until today I noticed the issue of just being able to lock the truck while standing right next to it.
    BravoDeltaRomeo likes this.
  23. Dec 9, 2019 at 3:13 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I dont have any aftermarket LEDs, but tried the @Pudge chin method to start my truck today and it worked at a longer distance. Really surprised. Nice tip!
    I did get some funny looks in the parking lot at work.
    Pudge likes this.
  24. Dec 9, 2019 at 3:30 PM
    Batel
    Batel New Member
    2019 Tundra SR5 TRD Offroad
    I've got the Sylvania leds in my cargo lamps and haven't noticed any problem with reduced range.
  25. Dec 9, 2019 at 3:32 PM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    I actually have ridiculous range with my key fob.
  26. Dec 9, 2019 at 4:15 PM
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    LEDs in the 3rd brake light housing cause the issue. Turn them off so that they're never on unless you manually turn them on yourself and the issue will disappear.
    GAknight and BravoDeltaRomeo like this.
  27. Dec 9, 2019 at 4:19 PM
    Pudge
    CT
    :thumbsup:
  28. Dec 11, 2019 at 9:56 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Yup, this worked for me after reading your post....thanks!
    I noticed range wasn't great but didn't know why. LEDs were installed on interior, LP and the 3rd breaklight/truck bed. After turning the bed lights to always OFF, my range is exceptional.
    Will switching out the LEDs for a different brand or only replacing the Bed Lights (not the center brake), make any difference? Of is the only fix to put the original bulbs back in?
  29. Dec 11, 2019 at 10:02 AM
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    It sounds like the only one that causes issue is the cargo/bed light. I turned mine off and remote start / fob seem to be back to normal
  30. Dec 11, 2019 at 10:16 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    There are a couple brands/models listed in the thread that fix the issue. There are specific chips on LEDs that affect the antenna, so swapping to another brand that is known to work without jamming the antenna will take care of this.
