Assistance/guidance to remove front bumper “snap in” grill/trim piece
Discussion in '2.5 Gen Tundras (2014-2021)' started by mambo143, Dec 8, 2018.
  1. Dec 8, 2018 at 12:37 PM
    mambo143
    mambo143 [OP] New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    4D7EED7D-8CFB-4656-95DA-76DEC5EF583A.jpg 7D8A13F0-E518-448D-84F5-B3CCCAB3A69A.jpg I would appreciate a little guidance to remove the small trim piece to install my Westin brush guard support bracket. The pic is above. Surrounded by tape.
    Instructions say use a trim removal tool and press away while pushing in the location of the snaps. It’s a PIA and I do t want to break it. I have the tools but it’s stubborn.
    Figured I would have access from the inside from beneath so did an oil change to remove the skid plate. So I have accomplished something . And that’s where I am at... temp is about 26 degrees here so it’s no party LOL.
    Anyone have insight into removing this.
    Thank you! Patience is a virtue when you have a big goodie to install and get stuck. No vids available on this installation that I could find.
  2. Dec 8, 2018 at 12:39 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I used a plastic trim tool remover. Inserted it between the bottom of the grill and the bumper and pushed the grill up. And push the top to the rear of the truck.
    Fishman57 and mambo143[OP] like this.
  3. Dec 8, 2018 at 12:45 PM
    mambo143
    Phil
    Maine
    Thanks for the quick reply. I will give it a shot! My upper grill grill is still installed but sounds like I do t have to go that route. Will let you know!
  4. Dec 8, 2018 at 12:57 PM
    mambo143
    Phil
    Maine
    99F95ECD-BE7E-414A-91D3-C0B44DE7C015.jpg A8F9395B-B745-4249-B9CE-6F0482656A73.jpg Success!!! You made this piece very easy!!
    Thank you sir!!! You made my day
    4x4_Angel likes this.
  5. Dec 8, 2018 at 1:11 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    What are you installing? I put a diode dynamic 42” bar in there.
    KFed and NewImprovedRon like this.
  6. Dec 8, 2018 at 4:43 PM
    mambo143
    Phil
    Maine
    Wow! Do you have a link? It’s a grill guard. I think this might work. Very clever. I would have lights installed within the body of the truck.
  7. Dec 8, 2018 at 4:48 PM
    mambo143
    Phil
    Maine
  8. Dec 8, 2018 at 8:15 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  9. Dec 22, 2021 at 7:03 AM
    Track Day
    Track Day New Member
    Yes I know this is an old thread but I’m in the same boat trying to remove this trim piece to install a ranch hand. I’m prying from the bottom and pushing the top to the rear as stated above but it don’t seem to be budging.
  10. Dec 22, 2021 at 7:08 AM
    clarkritchie
    clarkritchie New Member
  11. Dec 22, 2021 at 7:12 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I've noticed that some of the clips are a little more difficult to pop that others - my grille insert came out with almost no issues, but when we installed a bar on @BiggHertz truck, all but a few were stuck. You can see the cutouts where the clips meet the grille - just work those one at a time, starting at the outside and working to the middle from each end, pressing in on the grille and using the trim tool to push the bumper out from the grille... hope that made some sense.
  12. Dec 22, 2021 at 7:17 AM
    Track Day
    I’ll keep at it. Gonna go find a trim tool or small nail puller. Thanks
  13. Dec 22, 2021 at 7:19 AM
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    Whatever you do, don't push on the grill like @TRDFerguson suggested to me. You need to use a trim removal tool to undo the latches. He wasn't very clear in his instructions to me when he and I were working on @BiggHertz truck. I may have borked something.
    :anonymous:
  14. Dec 22, 2021 at 7:38 AM
    Track Day
    Yeah I keep referring back to the above photos trying to figure out how the little triangle tab pieces clip into / snap into (whatever) the lower part of the bumper. Are there tabs in the top edge of the grill trim piece that also hold it or is it merely those triangle shaped tabs on the bottom
  15. Dec 22, 2021 at 7:46 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The lower triangles are just there for added support but don’t provide any attachment points. But yes, the same tabs exist around the whole perimeter of the grille. Here’s a full look at the grille removed.
  16. Dec 22, 2021 at 2:10 PM
    Track Day
    That’s what the clips look like from the inside for anyone having the same issue as I. I have pried, pulled, tugged, cussed, skinned a knuckle, cussed some more and …..nothing.
  17. Jul 27, 2023 at 6:46 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Has anyone put the grid back in? Wondering if it was hard to attach.
