ArmorFlex Problem
Discussion in 'Tonneau Covers, Caps and Shells' started by direland69, Jul 25, 2020.
  1. Jul 25, 2020 at 9:49 AM
    direland69
    direland69 [OP] New Member
    Hi all. I recently installed an ArmorFlex cover on my 2020 Tundra. I'm noticing that the rails are pushing up on the plastic bed caps. Doing this on all four corners. Wonder if anyone else has this and what you did to resolve it...
  2. Jul 25, 2020 at 9:53 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Do you have pics from the inside angle?
  3. Jul 25, 2020 at 10:51 AM
    AZTundra
    Paul
    Phoenix, AZ
    pictures of how it's mounted inside the bed would be helpful to ensure it was installed correctly.
  4. Jul 25, 2020 at 11:49 AM
    direland69
    These help? Many thanks.
  5. Dec 28, 2020 at 9:16 AM
    splitfuse
    splitfuse Dr. Tundra
    AB-CAN
    2020 Cement Tundra Crew TRD
    What was the conclusion on this little dilemma? Just a matter of adjustment?
  6. Feb 13, 2021 at 8:28 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    Interested as well, as I am considering this same tonneau...
  7. Oct 25, 2021 at 2:25 AM
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    2020 Magnetic Gray CM SR5 4WD
    Console tray/dividers, Interior LED's
    Having the same issue and my install looks identical. Did the OP get this resolved and if so how?
  8. Oct 26, 2021 at 2:21 PM
    splitfuse
    AB-CAN
    I'm not sure what the OP found but after tinkering with my install I could never completely eliminate those bed rail caps from climbing up over time. In the end, I installed a stainless pop rivet (after applying touch up paint to the holes) at the front and rear of each bed rail cover (the caps were climbing at all four corners for me). The rivets were installed in the 1" vertical return flange on the inside of the truck box. Not my ideal solution, but problem solved and the fix is clean.
