Are these OEM tow mirrors?
Discussion in 'General Tundra Discussion' started by BuckWallace, Feb 26, 2019.
  1. Feb 26, 2019 at 7:18 PM
    BuckWallace
    BuckWallace [OP] Ball don't lie.
    Oregon
    Sierra 3500 AT4 Gasser
    I ordered a pair of used OEM tow mirrors off eBay and received them today. I didn't really notice in the pictures, but when I got them they just seemed really smooth and glossy, whereas I thought the OEM Toyota mirrors were a little more matte based on pictures I've seen. They were definitely advertised as OEM mirrors, not "OEM style", and they even had the Toyota sticker with the part numbers on the inside rubber seal. Am I just going crazy?
    Pic next to stock non-tow mirrors for reference.
  2. Feb 26, 2019 at 7:58 PM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Probably not.
    I’ve owned 3 generations of Tundras and don’t recall smooth and shiny black plastic.
    Unless it was painted mirrors
    TXDrifter likes this.
  3. Feb 26, 2019 at 8:03 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Yeah those look pretty smooth and shiny compared to the OEM mirrors I've seen.
  4. Feb 26, 2019 at 8:07 PM
    BuckWallace
    Oregon
    @Roman, any thoughts? The date on the sticker says 5/23/08. Part numbers on stickers are 87940-0C220-00 and 87910-0C220-00. I noticed the "current" tow mirrors are 879x0-0C221. Did the early 2nd gens have a different part number/style?
  5. Feb 26, 2019 at 8:11 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Led lights on the side?
  6. Feb 26, 2019 at 8:20 PM
    BuckWallace
    Oregon
    Yes on the LEDs. I mean, they feel solid and I took it for a drive after I installed them and they didn't vibrate or anything, so they seem fine. I looked up that part number and it looks like the earlier 2nd gens had a different tow mirror part number, so maybe they were more glossy back then. The seller also could have wiped them down with Armor All or 303 or something. Or he just slapped the rubber seals from actual OEM tow mirrors on these aftermarket mirrors and scammed me. I also noticed most aftermarket mirrors have the defrost symbol in the top outside corner while the OEM mirrors have it in the bottom inside (as these do).
  7. Feb 26, 2019 at 9:21 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    definitely gotta get @Roman on the case #TundraBusta
    Roman and BuckWallace[OP] like this.
  8. Feb 26, 2019 at 9:26 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    This is the second set today I see that are being called OEM and I’m pretty sure they are not. All the info I have seen these never came with led lights from Toyota. Also ur lens looked smoked not and actual amber. But I tried tagging Roman on the other thread but maybe he will see this 1 and we get an answer
    Krezz likes this.
  9. Feb 26, 2019 at 9:29 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    its late, he always replies...just relaxing a bit for a change im sure
    BuckWallace[OP] likes this.
  10. Feb 26, 2019 at 9:38 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I'm pretty sure the OEM are leds for the side marker.
    https://www.ebay.com/itm/Toyota-Tun...=item468ebee87f:g:hUMAAOSwjKFZTUsw:rk:52:pf:0
    fisherman951[QUOTED] likes this.
  11. Feb 26, 2019 at 9:51 PM
    fisherman951
    Tony
    2017 crewmax 4x4
  12. Feb 26, 2019 at 10:04 PM
    jessenavarro
    jessenavarro New Member
    Jesse
    Oak Glen, CA
    2018 White Tundra TRD Off-Road 4x4
    Front Fox 2.5 Coil-over shock with adjustable reservoir -- DSC Rear Fox 2.5 shock with adjustable reservoir -- DSC Total Chaos Fabrication UCA -- tubular Method Race Wheels MR701 18x9 + 25mm -- Matte Black BFG KO2s - 35x12.5x18 Demello Sliders RetraxPro XR bed cover Yakima Roof Rack setup Baja Designs S8 40" light bars x2 (amber and white LED) Baja Designs Squadron Pro ditch lights Baja Designs Squadron Sport fog lights Switch Pros SP-9100 Midland MXT400 GMRS radio
    Mine are dull. OEM ordered from dealer.
  13. Feb 26, 2019 at 10:31 PM
    BuckWallace
    Oregon
    The pics from Roman's OEM parts thread show LEDs on the tow mirrors. My lenses also are definitely amber and not smoked. Hopefully Roman chimes in tomorrow, though.
    https://www.tundras.com/threads/ultimate-oem-toyota-parts-thread.10707/
  14. Feb 27, 2019 at 6:50 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    The earlier part numbers were changed from 0C220 to 0C221 on the non-power folding mirrors, so those stickers are accurate as far as part numbers during that time period. I've never seen the tow mirrors in that glossy color except when someone has had them painted or armorall'd the crap out of them. The original finish is a flat black color.
  15. Feb 27, 2019 at 7:40 AM
    BuckWallace
    Oregon
    Thanks for the reply, Roman. I sent the seller a message, so we'll see what he says. I'm not so concerned about the finish (although I'd prefer they were flat I instead of gloss) as I am that they're OEM. I saved about $150 vs buying new, so I won't complain too much, but I might try to get some money back if he had them painted or something. Thanks again!
    Pudge and Roman[QUOTED] like this.
  16. Feb 27, 2019 at 1:36 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Since you mentioned they were used maybe they clear coated them to keep them from fading out. They have a heck of a reflection for just being straight plastic.
    Keep us updated!
  17. Feb 27, 2019 at 1:58 PM
    BuckWallace
    Oregon
    Yeah, possibly. I sent the seller a message this morning but haven't heard back yet. I did go inspect them a little more closely and it looks like he may have tried to clean them up with Armor All or something like that. The seller normally sells old police/military patches and memorabilia and has a 100% seller rating with over 3k sales, so it's not like it's a brand new account/seller. He said he took these off his truck after the first year he owned it. I don't necessarily think he's trying to scam me or anything, because it would have to be fairly elaborate to go find some rubber seals from actual OEM mirrors with the part numbers and mfg date, then swap them over to some used aftermarket mirrors.
  18. Feb 28, 2019 at 6:46 AM
    BuckWallace
    Oregon
    So here's what I've learned: The seller said they were his late uncle's and came off his 2009 Tundra. I asked if they were ever painted or clear coated and he doesn't know. He did say his uncle "bought them from the dealer" (not sure how he'd know they much detail if his uncle is no longer with us) and only had them on for one summer.
    My concern, besides the obvious glossy finish, is why would his uncle pay so much for tow mirrors from the dealer only to keep them on for a summer? I suppose he could have sold the truck or something and took them off.
    I wonder if there are any other identifiable features to differentiate between OEM and aftermarket? Would anyone with OEM mirrors be able to take a picture of your mirrors at the joint/hinge when they're folded in?
  19. Feb 28, 2019 at 4:31 PM
    superslif
    superslif New Member
    NE. Ohio
    2014 Tundra Double Cab 5.7 Limited
    Firestone bags, Toyota tow mirrors, TRD sway bar
    For me when I ordered my 14' Tundra in the fall of 13' they were a $40 option for OEM tow mirrors. Personally I like the fact they are manual. Less to fail in the future. My brothers tow mirror on his Ford failed and it sent him back $750...Yes, mine are flat black. I will use 303 on them a few times a year. Yukon Provincial Park campground near Dawson City Yukon. IMG_2887.jpg
  20. Feb 28, 2019 at 6:11 PM
    BuckWallace
    Oregon
    Does anyone know how to read these? I popped this off the hinge cover on the mirror and assume it's some sort of manufacturing date.
  21. Feb 28, 2019 at 7:35 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Crazy how its only a $40 charge when from the factory, after the fact were on the hook for around $400.
  22. May 22, 2019 at 8:17 AM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    Reviving this thread. Can anyone tell me of these tow mirrors look oem? I don’t have part numbers and the guy selling claims they were on the truck when he bought the truck new from Toyota.
  23. May 22, 2019 at 9:19 AM
    BuckWallace
    Oregon
    A lot of times there will be a sticker on the sail panel seal with part numbers. Otherwise, it's a good sign that the defrost symbol/icon on the mirror is in the bottom inside corner—it seems like most aftermarket mirrors have the symbol up in the upper corners.
  24. May 24, 2019 at 9:15 AM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    Here is the sticker.
  25. May 24, 2019 at 10:02 AM
    BuckWallace
    Oregon
    That's the old OEM part number for the tow mirrors, so I'd say those are OEM. I think they changed the part number slightly in 2010 or something, but those look to be OEM!
    Roman likes this.
